Old Oct 08, 2012, 08:03 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by plingboot View Post
slightly off current subjects, but could anyone advise on a suitable solution for mounting an AV130 to an S800.
my purchasing power is limiting me to just the S800 initially and then a zenmuse at a later date, so i plan to use the AV130 i already have as a stop gapů
This adapter plate works great.
http://www.multirotorsolutions.com/d...-carbon-fiber/
Sid3ways is offline Find More Posts by Sid3ways
Old Oct 08, 2012, 08:24 AM
TruckBasher is offline
Find More Posts by TruckBasher
TruckBasher's Avatar
Joined Oct 2011
Originally Posted by UAVProducts View Post
Denny, you are huge help to the S800 and its customers. I personally appreciate everything you have done. Yes, I'll do the best I can to help you on your next purchase.
Can't wait for the adapters so I can try many different props also. 14" graupners will be here today it looks like.
Waiting for the custom drilled Xoars to arrive in a week or so.
Here is a sneak peak.
Thanks AEM for the help.
Okay, I have to get to work and get orders out. Monday's are busy.
Looking forward for results of this, I might get an order or this as well to try...
by the way any news on the custom case you mentioned for s800+z15?
TruckBasher is offline Find More Posts by TruckBasher
Old Oct 08, 2012, 08:48 AM
piscaj is offline
Find More Posts by piscaj
piscaj's Avatar
United States, MA, Boston
Joined Dec 2011
Originally Posted by Sid3ways View Post
Keep an eye on the plastic clamps, they will break after awhile. I have the heavy duty battery tray this company makes and it uses the same plastic c clamps. Luckily for me I found them at ACE Hardware . I wouldn't even try using these clamps in cold weather, since they broke during the summer.
I'm sure some of you have found an aluminum clamp that fits, could someone direct me to some?
piscaj is offline Find More Posts by piscaj
Old Oct 08, 2012, 09:05 AM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
I really need to get around and get some pics of them.
We also have to get to the foam cutting place to get the landing gear with Z15 cut out. I would do it personally but I just don't have time. Soon.
UAVProducts is offline Find More Posts by UAVProducts
Old Oct 08, 2012, 10:26 AM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
Any news on the OSD
Spyde is offline Find More Posts by Spyde
Old Oct 08, 2012, 12:00 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Originally Posted by Spyde View Post
Any news on the OSD
in what way ? when available or if one of us tested it already ?
I was lucky and already have one.
DJI OSD test S800, workaround for 6- 16v ImmersionRC VTX (0 min 22 sec)
Boris
BorisSA is offline Find More Posts by BorisSA
Old Oct 08, 2012, 12:44 PM
piscaj is offline
piscaj's Avatar
Joined Dec 2011
https://vimeo.com/50778672
Boris
Was this free for being an ESC victim?
What RF Uplink(Tx) are you using?
Old Oct 08, 2012, 01:00 PM
iheli22 is offline
Find More Posts by iheli22
Wings that Swing
iheli22's Avatar
United States, NC
Joined Jan 2012
Originally Posted by a1ik View Post
Nobody knows what the other motors will do when one comes to a complete stop. It all depends on how WKM is programmed. My point is that WKM is widely used on many different multirotors but only s800 fall from the sky at such rate. That suggests that the problem is in the frame or motors or ESCs. Motors and ESCs have been around for dozens of years already, but the detachable arms is the something really revolutionary. I have feelings the the bug is there even though it looks very well engineered.
I had a #6 ESC / Motor failure last week (See video a few posts back) The #6 Prop froze in mid-flight. Maybe not a classic FOD, but I quickly caught it, and with full left cyclic was able to get it back to the ground in one piece BTW: I am on FW 5.08
Upon trying to restart (CSC) the motors, smoke pored from the #6 ESC / Motor. The Arm was toast...
iheli22 is offline Find More Posts by iheli22
Old Oct 08, 2012, 01:08 PM
Joined Mar 2004
Originally Posted by dennyrowland@mac View Post
Thanks Robert
I have only run the Graupners and the APC and I liked them both. Others are saying that the Xoars are even better. Just be careful not to use too much pitch angle at the tips. 14" dia will probably be the best for stability in strong winds.
Hmmm....that is a good point. So you think I should change the Xoar order to 14" instead?
Old Oct 08, 2012, 01:12 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Well guys a lot of feedback from around the world since using the adapters and nobody has yet to report a FOD. so I guess we are on the right track.
Got loads of alum. 6 to 8mm inserts BTW.
Sounds good!
Can't wait for mine to come in... The last batch of adapters shipped with the inserts, right?
c3d76 is offline Find More Posts by c3d76
Old Oct 08, 2012, 01:22 PM
c3d76 is offline
Joined Mar 2012
Originally Posted by c3d76 View Post
Thanks Bob,
I'm just worried that if I FOD and don't have the exact same tape as the original, DJI might blame it on "user error".
I have just emailed this link to DJI, and hopefully they can tell me which one it is:
http://www.uline.ca/Grp_239/3M-Doubl...ign=3M%20Tapes
Maybe the "3M 442KW" ?
Well, this is the reply from DJI concerning the tape...
My message:
"Hi,
I have an S800/Z15 with WKM, and I have run out of double sided tape for the WKM IMU. Kindly let me know which one of these is the right tape so I can order: http://www.uline.ca/Grp_239/3M-Doubl...ign=3M%20Tapes
Thanks"
DJI Reply:
"Hi, Cedric,
Good day!
Actually any double sided tape that can fasten it will do. No need extra vibration-resistance.
Thanks!
BR//Bruce"
Old Oct 08, 2012, 01:44 PM
rruiz is offline
Find More Posts by rruiz
rruiz's Avatar
Joined Oct 2012
Thanks Robert
So Denny we could say that you have found a real solution to the concerns... were can you post or let us know a summary of your findings and a way to resolve them... PLEASE HELP US !!!
Regards
rruiz is offline Find More Posts by rruiz
Old Oct 08, 2012, 02:01 PM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
Sounds good!
Right.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Oct 08, 2012, 02:05 PM
Joined Aug 2005
I'm hearing that 15" is good but that doesn't fit my theory so I am staying with 14's
Old Oct 08, 2012, 02:08 PM
Joined Aug 2005
Regards
Lets be clear on this. Not all S800 have a problem. of the guys who are using my adapters with different props they have not seen any FOD since. As far as I know.
I have temporarily exhausted the entire stock of 3mmx8mm cap screws in Cyprus, But Robert has some sets on the shelf.
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 06:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 11:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 04:11 AM
