Old Oct 05, 2012, 03:27 PM
Polishchris is offline
Find More Posts by Polishchris
AMA 905510
United States, NY, New York
Joined Aug 2009
@UAV.Pilot
Would you mind sending me the contact information with whom has helped you from DJI? I would like to contact them directly and get my S800 tuned in
And would there be a school near by NYC?
Polishchris is offline Find More Posts by Polishchris
Old Oct 05, 2012, 03:28 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Originally Posted by uav.pilot View Post
some good posts guys...very interesting indeed
ferdinand sweet landing gear mod! I have the same thing in mind, would you share pics and possibly a build list of parts?
I got a lot of white flashed right before mine flipped as seen on my vid, now that i have been in communications with dji directly they are certain that in my case i did not use their supplied double sided sticky tape with the installation of the imu, causing vibrations and making the imu erratic.
Im not buying it completely because its the same tape we have used in all of our other builds for tens of years 3m adhesive foam core 1mm tape, very stout...now this wkm is susceptible to vibrations unlike other similar systems...just dont sound right to me. But possibly so? I did not notice any vibrations in my flights. In fact i think i even made a comment how smooth it actually flew.
Dji has stated that the imu must be installed using their double sided sticky tape provided in the kit, and in no way should any substitute be used. Including gel ext...
Having said that, dji did take care of me and spent a good amount of time with my ship, and dialed it in! It's on its way back ready to work, and for this i am thankful! They did back up their product better than other companies i have seen. For me customer service is #1 on my list, over performance, in any product i buy if i cant get good service if and when i need it, then its worthless!
I ordered props from robert the other day and i gotta say he also took very good care of me! His customer support is right on par
all of this adds up to great customer service from dji, and this alone is what i look for when i invest my hard earned money in any company. Had i been treated differently it would have been my last dji purchase and many other's that are peering onto me and my flying machines.
We are a uav university now established in conjunction with asu and plan to have a fleet of uav systems, this s800 was purchased to do the safety trials for the school. It has yet to fly in front of anyone and this delay almost made us go to another well known platform.
Once i get this s800 back i will report what i received and how it flies, looking forward to it! With any luck this thing will be right and we will be using it for our flight school.
unmanned university
:d
UAVProducts is offline Find More Posts by UAVProducts
Old Oct 05, 2012, 08:30 PM
piscaj is offline
Find More Posts by piscaj
piscaj's Avatar
United States, MA, Boston
Joined Dec 2011
Im not buying it completely because its the same tape we have used in all of our other builds for tens of years 3m adhesive foam core 1mm tape, very stout...now this WKM is susceptible to vibrations unlike other similar systems...just dont sound right to me. but possibly so? I did not notice any vibrations in my flights. in fact i think i even made a comment how smooth it actually flew.
DJI has stated that the IMU must be installed using their double sided sticky tape provided in the Kit, and in no way should any substitute be used. including Gel ext...
I've been using Zeal Gel for years, and I really never took caution to DJIs warning to use there supplied tape, I guess this is because I used to fly nitro helicopters and Zeal Gel was the extra insurance to eliminate vibes. I also have never experienced the white flashes like a lot of other people here, yes I have seen them, but not during flight and I always thought it might be from the Gel. Is anyone else here using Gel? I'm a little nervous hard mounting it with the supplied tape given my good track record with Zeal Gel, but if I run the risk of DJI not standing behind there product if I do (in your case they did, but for others they may not), I may switch to there supplied tape.
Does anyone have any thoughts on this? Should I switch to the DJI tape?
piscaj is offline Find More Posts by piscaj
Old Oct 05, 2012, 09:52 PM
AMA 905510
Joined Aug 2009
Right... So im looking for results just as everyone else is...
DJI requires us to use their double sided tape because the vibrations will be eliminated by IMU dampening and IMU needs to be firmly attached to the S800
So my plan is to do some trial and error tests! Did a little shopping and I ending up buying rolls of scotch permanent tape
Now the tape that was provided by DJI has written 3M VHB on it. Does anyone has more specifics on this tape provided from DJI?
The scotch tape in the pictures I will use in tomorrow test to see which one eliminates the white flashes. I am first starting off with DJI tape. If that doesn't work, I will use clamps to clamp down the IMU. Then I will try the other tapes and see which one has the least flashes!
Any comments before I do this?
- I will keep away from zeal tape for this experiment
Old Oct 06, 2012, 12:29 AM
piscaj is offline
piscaj's Avatar
Joined Dec 2011
Clamping it down to the S800 with all the vibes from the stock props might not be a good idea, but I'm interested in the results none the less.
Old Oct 06, 2012, 03:06 AM
plingboot is offline
Find More Posts by plingboot
Joined Oct 2010
i'm guessing the clamps are just to hold it in place, some tape suggest leaving the item you've just 'stuck' for 15mins. i doubt whether he's planning to fly with clamps ;-)
plingboot is offline Find More Posts by plingboot
Old Oct 06, 2012, 05:11 AM
Capo Creative is offline
Find More Posts by Capo Creative
Joined May 2012
Does anyone else feel like this is crazy? Still no official response from DJI about the obvious FOD issues? People are reporting white flashes, which seem to be coming from vibrations caused by overly flexible arms or unbalanced stock CF props. Is this the cause? To use Zeal Tape or not to use Zeal Tape... that is the question. Tahoe Ed thinks this will only confuse the sensors in the IMU, others say rock the Zeal Tape and drop the IMU in the center of the center plate. Denny seems to think the FC can be overloaded with information. Is that the cause? We've got UAV.Pilot with a feel good customer service story, but double sided sticky tape was the cause of his FOD? Really? That's how sensitive this FC is? Robert has direct contact to DJI, has he heard anything from them about this? They are clearly aware of it. Are they working on a more comprehensive fix? Sitting on our s800 while these issues get resolved is not my idea of "feel good customer service".
Capo Creative is offline Find More Posts by Capo Creative
Old Oct 06, 2012, 05:22 AM
fsimao222 is offline
Find More Posts by fsimao222
fsimao222's Avatar
Portugal, Faro, Loulé
Joined Jun 2012
Originally Posted by capo creative View Post
does anyone else feel like this is crazy? Still no official response from dji about the obvious fod issues? People are reporting white flashes, which seem to be coming from vibrations caused by overly flexible arms or unbalanced stock cf props. Is this the cause? To use zeal tape or not to use zeal tape... That is the question. Tahoe ed thinks this will only confuse the sensors in the imu, others say rock the zeal tape and drop the imu in the center of the center plate. Denny seems to think the fc can be overloaded with information. Is that the cause? We've got uav.pilot with a feel good customer service story, but double sided sticky tape was the cause of his fod? Really? That's how sensitive this fc is? Robert has direct contact to dji, has he heard anything from them about this? They are clearly aware of it. Are they working on a more comprehensive fix? Sitting on our s800 while these issues get resolved is not my idea of "feel good customer service".
+1.
fsimao222 is offline Find More Posts by fsimao222
Old Oct 06, 2012, 07:41 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
+2.
jab is offline Find More Posts by jab
Old Oct 06, 2012, 07:42 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
One has to assume that the latest 5.14 version has been given the all clear. I am as satisfied as I can be that this model is safe to fly. I have been testing with different props. this week and no white flashes. Thus far it has been reliable...... My personal choice is the 14x4.7 APC's but some say they prefer Xoars. Either way I am not seeing any vibration problems. Standard IMU Mounting.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Oct 06, 2012, 07:55 AM
Huddo is offline
Find More Posts by Huddo
Australia, SA, Adelaide
Joined Aug 2011
Better than the Graupner 14x8' ?
Huddo is offline Find More Posts by Huddo
Old Oct 06, 2012, 09:41 AM
Joined Mar 2004
Beginning next week (after Chinese Holiday) I will do my best to get answers etc.
I have Denny's adapters coming next week and a ton of the 14 Graupners.
I have 15" Xoar" being custom drilled to fit stock motors.
I'm going to do everything I can to find the best prop solution for the S800 or at the very least provide the tools for others.
IMU Mounting:
The Imu's have internal dampening. They like to be hard mounted. They have all been like this and recommended to do so.
As crazy and simple as it might sound, I still want to stuff memory foam in between the frames and/or around the IMU and see if that makes a difference for soaking up these high freq vibes.
FOD: I have no idea on the cause. The majority don't have this issue but yet some do.
As soon as I hear something I will post it for sure.
Old Oct 06, 2012, 10:49 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Compliments are in place, this is customer service!
Aaalie is offline Find More Posts by Aaalie
Old Oct 06, 2012, 11:43 AM
Raggarn is offline
Find More Posts by Raggarn
Photographer in Stockholm
Raggarn's Avatar
Joined Sep 2012
@UAVProducts,
What about Dennys adapters for the graupner 14x4.7props. Does XOAR 15x5 props fit? Or do you prefer xoar with two extra drilled holes?
Raggarn is offline Find More Posts by Raggarn
Old Oct 06, 2012, 11:51 AM
Joined Mar 2004
Originally Posted by Raggarn View Post
@UAVProducts,
The adapters will fit the Graupners and what I will be testing first.
Xoar is just doing a special batch for us to test.
Once I get everything I'll figure it out.
Denny is really the expert on this right now.
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 06:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 11:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 04:11 AM
