sorry for the duplicate jdm66 |
Joined Mar 2012
http://www.rcgroups.com/forums/showp...postcount=1253 |
Also started lamination. But first I've added an other wire for the ESC signal, and paralleled the two separate wires, just like the other two wires. This way it's not a problem if the insulation from the thick (high current) and thin (signal) wire wears down. The new Signal wire is flexibel.
Now there are two pair wires for the higher currents. ![]() ![]() ![]()
Also, could you provide a picture of the work you did? Thanks, AEM |
United States, NY, New York
Joined Aug 2009
Hey Guys! Been following most of the posts in this thread and decided to finally be a part of this thread help. I haven't read all 120 pages of posts but i been reading from time to time most, so maybe some of the points i want to point out might already be covered...
So I had crashes of my own s800 twice (lucky without my z15 mounted), my first crash was with the av200 (gimbal survived) cause the battery died in flight and second crash cause of some glitch (no gimbal mounted). Landing gear is falling apart but it still stands my s800 even after two crashes I am having the same problem with my WKM as everyone else with the white flashes. Haven't had FOD yet but had many flights already +30. My S800 has v2 WKM MC and v4 ESC now (replaced to the latest when notified about the recalls). So after each flight (+10min) the motors and escs are cool to the touch. But the white flashes are always constant from 2 to 3 flashes and I am having a very hard time flying in atti with +5kg total takeoff weight. I can not achieve the 16min at 6kg 10000mah like DJI has specified. From reading this thread and learned about the vibrations could be the blades. So I bought blades from cnchelicopter and they fly nice and are really stiff (unlike the flexiable stock blades). Just giving a heads up, the core is wood wrapped in carbon fiber and need to drill the screw holes larger. So far the Zeal Gel has done its magic to eliminate the white flashes. Only would have a white flash when i do hard flying or have a heavier take offweight +5kg. But I am still trying to eliminate the white flashes for good. So my next conclusion would be the big motors. Has any tested what frequency the motors give off? Maybe the motors vibration frequency might be passing the dampening in the IMU... I have considered buying the motor adapter to try other brand props, but most of you guy seem that you prefer to stick with the stock blades, as would I because they are light weight and seem the s800 feels better on the sticks even after I only tried two different CF blades. I haven't seen anyone try this or haven't seen in the thread, I decided to wrap the wires in choke core between the s800 and MC. Since in a rc helicopter esc you would have a choke core on the cable, why not on the s800? Also why not remove the red power cable? The power cable is useless, there is no connection with the power cable between the esc and the MC (you can check for yourself). The arms only has 1x Main Power, 1x Signal, and the 2x Grounds are together. The power cable from the MC has no purpose and might cause interference if the voltage is noisy as the signal and ground are wrapped around the power cable. I am thinking of removing the ground between the S800 and MC to prevent a ground loop. Maybe leaving the ground between the s800 and MC might eliminate any noise in the ground coming from the battery. I might be going over board but I have added choke core on the IMU and PMU cable as well. Maybe try eliminate as much interference in the electrics as possible... And last but not least the Futaba SBE-1 with spektrum rx. I read online most people doing it, so I wanted to stand out that I am doing it as well and added a picture of it. I fly with spektrum DX18 and the 18-channels are useful when using the S800 with the z15. So I am using the futaba SBE-1 with my spektrum rx and so far so good it works great! I don't see in the configuration of the RX channels twitching like it did in traditional wiring. With the sbus, the channels are solid! I'm not considering to reinforce the arms. I have done tests like hanging 6s 5000mah packs from different locations throwing the CG off and flying the s800 the fastest it can fly. So far it handles good to an extend where its controllable with the white flashes and manages to stay in the air. The arms are really easy to break if you hit the ground. Had to replace a few of the arms already.... And its always good to keep those connectors clean between the socket of the center frame and the arms. I use some connector cleaning solvent to remove any residue Hope this helps... Ill add more after my next flights with the choke cores and the zeal gel. Maybe will decide to change the motor mount plates with my own custom and replace the brushless motors with some other motors when I get the budget for new motors |
Guys, the red cable stops at the connector, since the pins are dead there. The important cables to remove are the black lines (from the plate to the WKM), this avoids the "ground loops" (six of them). So (like you should do on every multicopter) only connect the esc´s via the signal lines. (the most easy way to do so is use only two kable to connect the WKM to the plate, and place this two kables "sidewards").
![]() Please only try this if you know what you are doing, furthermore this is not recommended by DJI, so better position the cables as shown in the manual. best regards Ferdinand |
| Thread Tools | |
| Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble | jasper7821 | Multirotor Talk | 219 | Oct 16, 2012 05:11 PM |
| New Product DJI Spreading Wings S-800 Hexa multi-rotor | sidneyw | Multirotor Talk | 930 | Jun 22, 2012 10:14 AM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters | QuadcoptersUk | Multirotor Talk | 8 | May 14, 2012 01:27 PM |
| Discussion Dji Spreading Wings (S800) coming | Huluhulu | Multirotor Talk | 7 | Apr 27, 2012 03:11 AM |
