Old Sep 26, 2012, 12:12 PM
yeehaanow is offline
Find More Posts by yeehaanow
United States, VT, Bristol
Joined Sep 2010
Originally Posted by Aaalie View Post
I'll preprag the cloth with 4 grams resin. Then put it over the (light sanded) arm, put a piece of heat shrink over it en shrink the total. During the hardening I'll rotate the arms so the resin (and carbon cloth) is forced to the heat shrink wrap by the centrifugal force. When the resin is hardened, I'll cut away the heat shrink, leaving a slightly glossy surface (7 grams cloth, 4 grams resin and the surface of the heat shrink).
Thats the idea, hoping it will work like that (otherwise I'll have another failure project ).
@ Ferdinand:
Carbon cloth, we use. I feel, great result... we have.
May the Zen be with you.
Sounds like a really good technique. I bet the reinforced arms with prop adapters will be a killer combo, but then you have basically built a cinestar with removable arms.
yeehaanow is offline Find More Posts by yeehaanow
Old Sep 26, 2012, 01:27 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
@ Ferdinand:
very good idea . and look nice !
where did you find the carbon?
flytahiti is offline Find More Posts by flytahiti
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
Which is AWESOME
Iceman575 is offline Find More Posts by Iceman575
Old Sep 26, 2012, 02:06 PM
fsimao222 is offline
Find More Posts by fsimao222
fsimao222's Avatar
Portugal, Faro, LoulÚ
Joined Jun 2012
You have carbon Supplies here:
http://www.carbonmods.co.uk/Default.aspx
fsimao222 is offline Find More Posts by fsimao222
Old Sep 26, 2012, 02:18 PM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
http://www.rcgroups.com/forums/showt...8#post22422773
Aaalie is offline Find More Posts by Aaalie
Old Sep 26, 2012, 03:00 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
They wont ship to North America
bcollydas is offline Find More Posts by bcollydas
Old Sep 26, 2012, 11:17 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Originally Posted by c3d76 View Post
So you haven't seen white flashes since you installed the Graupners, but you had them before with stock props?
I hadn't seen them before either.... But I don't know if they came after screwing with the firmware or the double sided tape for the IMU, or if I was just "blind/didn't notice...
Well it turns out I was blind... I checked my maiden vid and I have had white flashes (fair atti) the whole time
I will try the IMU in central position without modding arms or props and post the results. Has anyone else tried the IMU in center with a completely stock S800?
c3d76 is offline Find More Posts by c3d76
Old Sep 26, 2012, 11:55 PM
fsimao222's Avatar
Joined Jun 2012
You have done a currect calibration after arms reinforcement?
Old Sep 26, 2012, 11:58 PM
c3d76 is offline
Joined Mar 2012
Hey Flavio,
No I didn't do any arm reinforcement yet, still flying it stock to see if I can get rid of white flashes without modding
So I will try IMU in center with my non-modded S800, and just wanted to know if anyone else had tried that...
Old Sep 27, 2012, 12:04 AM
fsimao222's Avatar
Joined Jun 2012
Hey Flavio,
Sorry, I dont have read your prev post. Where you bought the adaptors for graupners?
Old Sep 27, 2012, 12:13 AM
c3d76 is offline
Joined Mar 2012
I don't have Graupners either
But maybe these are the ones? http://www.rcgroups.com/forums/showp...postcount=1301
Old Sep 27, 2012, 12:18 AM
fsimao222's Avatar
Joined Jun 2012
Forget it. Here its 6 Am. Its time to go to bed
Old Sep 27, 2012, 12:20 AM
c3d76 is offline
Joined Mar 2012
Haha
Old Sep 27, 2012, 01:42 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
Hi Guys I 'd like to say thanks to the many people who have bought the adapters I was not expecting such a response but fortunately we have a good machine and am keeping up ok.
Just a quick word about the requests for 8 mm shafts. This is not possible to do because the PCD of the four 3x8mm screw counted bores is too tight around the shaft. The next batch will have our own insert set for 8mm.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Sep 27, 2012, 01:51 AM
Joined Aug 2005
I am working on a better solution for the reinforcement of the arms. We have a product called carbon Nano tube. it is a fine powder type of substance and is about the toughest substrait known to man. I will mix this with some micro balloons and some thinned epoxy resin to form a very light yet strong filler paste to go inside the webbing of the arms.
I do believe this will make a much lighter solution. If it works well who knows I may sell some material kits.
After taping up the arm the filler can be poured in to form a smooth surface. Top and bottom.....
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
