Old Sep 26, 2012, 02:34 AM
fsimao222 is offline
Find More Posts by fsimao222
fsimao222's Avatar
Portugal, Faro, Loulé
Joined Jun 2012
Originally Posted by dennyrowland@mac View Post
We seem to have digressed from the fact that making the arms stiffer is not the answer to this problem. It does not cure the problem at the source. It may help slightly but the source of the vibration is coming from the props. which are a very bad design. Having now conducted quite a few tests it has emerged that the best all round prop. is the Graupner 14x8 for a number of reasons. I am sure that DJI will not be pleased to hear this but we cant all be wrong......
White flashes. never see em.
From where you bought the adaptors for this propellers. I`ll try this to see the vibrations
fsimao222 is offline Find More Posts by fsimao222
Old Sep 26, 2012, 03:06 AM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
@Denny
Do you think you might try out those 15x6 Xoars (CF) by any chance? My guess is that they'd give a lot more thrust than the 14x8's due to larger diameter and less pitch. They might not allow for as high a top speed, but would still be an improvement in that department compared with the original 15x5.5, if considering diameter and pitch as the only factors. It's not like top speed for this type of platform is what most people are looking for, though; although, more thrust seems good.
AEMontoya is offline Find More Posts by AEMontoya
Old Sep 26, 2012, 03:07 AM
jdm66 is offline
Find More Posts by jdm66
jdm66's Avatar
France, Pyrénées Orientales
Joined Feb 2009
Originally Posted by AEMontoya View Post
I just got in contact with Xoar, and they said that they do have a CF precision pair of props for multicopters that are 15x6. They also have a wooden pair of 15x5.5's that aren't specifically for multicopters. Any ideas?
Hi
an idea of price
jdm66
jdm66 is offline Find More Posts by jdm66
Old Sep 26, 2012, 03:21 AM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Originally Posted by jdm66 View Post
Hi
an idea of price
jdm66
Not sure; I'm still waiting for a return e-mail from them. I'll post when I find out. However, here is the response I got when I mentioned to them that I'd have to adapt the props to be like the s800 ones, with a hole in the middle and two smaller holes on either side.
"Should be no worries, by learning the sizes, locations of the center hole and two smaller holes, we can pre-drill them on the carbon 15X6 for you. Kindly be noted that please do not drill any holes on our carbons, because it may destroy the prop.
Let us know your preferred center hole diameter, we will custom at your request."
Sounds pretty good, if the price is right. Probably could just use the stock prop adaptor that comes with the s800 by using some longer screws and dealing with the two lips on the top plate.
Old Sep 26, 2012, 03:25 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
I completely agree, but the arms still need to be rigid.
Even perfect propellers will have blade warps during flight maneuvers. And the temporary vibrations from such warps should be stopped in the arms, never reaching the base plate. Soft arms will not do this, and instead make blade warps more pronounced by allowing the motor/propeller to move around.
jab is offline Find More Posts by jab
Old Sep 26, 2012, 04:47 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I am not seeing any arm vibrations now. I don't think you should worry about the standard arms
they are working fine for me. It is the way that the DJI carbon prop' distributes it's lift that is the problem. With the Graupner 14x8 you will have better motor cooling, better stabilisation and no vibration . It is a perfect combination for the S800. you just need these adapters and that is all.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Sep 26, 2012, 05:07 AM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
Polynésie française, Îles du Vent, Papeete
Joined Mar 2010
and no more white flashes ?
flytahiti is offline Find More Posts by flytahiti
Old Sep 26, 2012, 06:45 AM
Joined Aug 2005
I flew yesterday two flights of around 14.5 mins. and saw no white flashes anywhere. Very low motor temps. and rock solid stab. (unlike PH.....) It was very strong wind.
Saw a red light briefly when the battery level was warning at the end.
I am sure many people will want to try other props. but I recommend this one because I know how well it works and it is a sure solution to the problem.
With regard to arm flexing, a small amount is necessary. Boeing seem to been doing this for some time now, that is how they keep the engines from falling off......
Old Sep 26, 2012, 07:56 AM
semich is offline
Find More Posts by semich
Portugal, Lisbon, Cascais
Joined Mar 2010
Windows 8 and DJI USB driver
For those like me who already use Windows 8, you will find out quickly that the DJI USB driver won't work. While DJI is already aware and making changes, here is a workaround:
Bit locker must be suspended, otherwise, it will require a recovery key.
From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
Click ‘More PC Settings’.
Click ‘General’.
Scroll down, and click ‘Restart now’ under ‘Advanced startup’.
Wait a bit.
Click ‘Troubleshoot’.
Click ‘Advanced Options’
Click ‘Windows Startup Settings’
Click Restart.
Select 7 (disable signature driver verification)
Boot the PC and install the DJI USB driver.
Once those steps are done, we can use the software assistant again.
semich is offline Find More Posts by semich
Old Sep 26, 2012, 08:25 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Like Dennyrowland I do believe the issues are caused by the original props. I do have good results with APC 14*4,7 a while ago, but I do not have such nice propadapters.
Nevertheless I'd like to try with reinforced arms, and want to use carbon cloth for this. Each arm will have 7 grams carbon, and approximately 4 grams resin.
This is before, waiting for the spare arms to reinforce, keep this ones original. But to give an idea:
Aaalie is offline Find More Posts by Aaalie
Old Sep 26, 2012, 09:22 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
I am very curios to see your results. At least this way the arms look nice. Better than zip tied rods in my opinion.
Iceman575 is offline Find More Posts by Iceman575
Old Sep 26, 2012, 09:36 AM
Joined Aug 2005
Don't forget to check the weight as you go, epoxy resin is very heavy. I would prefer to see a top and bottom molding that is very thin and vac bagged. then the two halves could be wrapped and joined. It could also look nice and be very strong.
Old Sep 26, 2012, 09:44 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
"Zip-ties are what gives a MC-Pilot his power. It's an energy field created by all zip-ties. It surrounds us and penetrates us. It binds the multicopter together. "
"do not underestimate the powers of zip-ties"
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Sep 26, 2012, 10:33 AM
Aaalie is offline
Aaalie's Avatar
Netherlands
Joined May 2006
I'll preprag the cloth with 4 grams resin. Then put it over the (light sanded) arm, put a piece of heat shrink over it en shrink the total. During the hardening I'll rotate the arms so the resin (and carbon cloth) is forced to the heat shrink wrap by the centrifugal force. When the resin is hardened, I'll cut away the heat shrink, leaving a slightly glossy surface (7 grams cloth, 4 grams resin and the surface of the heat shrink).
Thats the idea, hoping it will work like that (otherwise I'll have another failure project ).
@ Ferdinand:
Carbon cloth, we use. I feel, great result... we have.
May the Zen be with you.
Old Sep 26, 2012, 10:39 AM
fsimao222's Avatar
Joined Jun 2012
I have already thought this solution, but for first test it is too expensive.
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
