Old Jul 11, 2012, 03:08 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
He's bent the starboard one forward to match it........
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 11, 2012, 05:32 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
The first landing will change that!
kkphantom is offline Find More Posts by kkphantom
Old Jul 11, 2012, 07:48 AM
cd_webb is offline
Find More Posts by cd_webb
Joined May 2009
Wow! Tough crowd! Actually, no, I didn't bend the starboard one forward, but that was Sparks' fault. He didn't mention the "starboard" one, so I didn't mess with the "starboard" one. kk's right though, it'll all get sorted out pretty quickly - no matter which one's a little bit out!
Have a good day (or night, as the case may be), boys!
David
cd_webb is offline Find More Posts by cd_webb
Old Jul 11, 2012, 08:15 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Hey David,
The crowd are definately tough, you certainly couldn't eat a full one of 'em
The starboard leg looked fine to me, only the port seemed to be toe'd in a bit, you may of course like a bit of toe-in to keep things straight on the runway, but I can't get away with that on the sand
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 11, 2012, 08:16 AM
Joined Nov 2008
...and I can't tell port from starboard, nor talk from mutter........
Just ignore me - I find that usually works!
Old Jul 11, 2012, 11:59 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
C'mon guys, give the man a break. Let him amongst us who has never had a cockeyed wire undercarriage cast the first stone - that lets me out! And I am sure that the Deacon will fly so well and land so gently that once it's straight the undercarriage will stay that way
Sundancer is online now Find More Posts by Sundancer
Old Jul 11, 2012, 12:43 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Yes, I'm out too.
So please don't take any of our teases seriously David, we are looking forward to the next progress update.
sparks
Old Jul 11, 2012, 01:00 PM
cd_webb is offline
Joined May 2009
No offense taken guys. It just amuses me the way some of your thought processes go. Seriously, I don't see half of the witty responses in this forum coming. Sometimes it takes a while for me to get it. A little slow, I guess. Must be my southern drawl being manifest in areas other than speech.
Old Jul 12, 2012, 03:20 AM
Joined Nov 2008
Indeed, it was pure banter - no aspersions were intentionally cast in the making of these posts. And as one who only ever managed to 'square the circle' a good 3/8" away from the noseblock, I fully expect to be ripped into when the Ajax undercarry-arge gets the Blink pliers treatment.
And that time is rapidly approaching!!!!!
Old Jul 12, 2012, 06:15 AM
kkphantom's Avatar
Joined Nov 2010
And we will all be watching...Mwahahaaaaa!
Old Jul 12, 2012, 08:54 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Being serious for a moment folks (hard to do when Colonel Blink is involved); this business of trying to get wire undercarts right is why, in my latest spell of building vintage type models with wire undercarriages, I have adopted a standardised procedure which goes like this: build two tubes into the fuselage, rear one at the normal u/c location is for the main leg, front one for the supporting leg. Then bend up two identical rear and two identical front leg halves, much easier to do than trying to bend a full undercarriage in one piece. Also easier as, using this method, thinner wire can be used for the front and rear legs than would be the case with a single leg version (eg 18swg rear, 20 swg front on the Witch and Sportster, 16 and 18 swg on the Zephyr). Insert one front and one rear leg into their tubes, adjust to optimum position, bind together with a thin strip of masking tape to hold position, then bind with fuse wire, solder. Repeat for the other side. Remove legs and only re-insert secured with a spot of CA AFTER covering - it is MUCH easier to cover the fuselage with no wires sticking out. If your binding/soldering is a bit messy, slip a length of heat shrink tube over the joint and shrink it up.
Providing you anchor the tubes in well with ply gussets etc, this is very strong.
Plugging into pre-installed tubes is also useful on scale models for other wire work such as rigging supports etc as on the Eastbourne - would have been a nightmare to cover around all the wire.
Old Jul 12, 2012, 12:38 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Nice examples George, I think i'll try the method myself.
Old Jul 29, 2012, 08:53 PM
cd_webb is offline
Joined May 2009
Except for situating wires and nailing down the battery location, the fuse is done. I think the .015 thickness acetate was just a bit too thick for the bend around the top of the cabin. Most of yesterday and pretty much all of today is what it took to get it done. I'm just not good at the canopy/windshield thing. The .015 was all I had and I finally made it work with a few stress marks being the result. Even with a little heat it was just plain tough! I'll order some thinner stuff next time.
Wing is built and should be able to start it tomorrow. Don't foresee any problems there - except that I'm running on empty for black covering. Should have [I]just[I] enough. Which brings me to another matter.
I do envy you guys who make nice covering jobs out of Mylar and tissue. I tried it again and STILL made a mess of it. I don't know. I thought I could read and follow instructions, but apparently that's not the case.
Old Jul 30, 2012, 03:54 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
That looks great David, a really nice and crisp colour scheme. I am the opposite to you - absolutely no problems with mylar/tissue, but I can't cover with film to save my life. Flying soon!!!???
Old Jul 30, 2012, 04:37 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I would not worry too much about the covering, the fus and tailsurfaces look great in the shiney black and cream, set off really well with the red trim too. Nicely done David.
sparks
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 11:45 AM
Build Log KK Ajax - BritKit Build Off 2012 Colonel Blink Vintage & Old-Timer Designs 400 Jun 18, 2013 11:04 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 04:47 PM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 06:28 AM
Poll Poll for the FROG Build Off October 2011 to April 2012 Sundancer Test Forum 0 Apr 19, 2012 09:07 AM
