Old Jun 22, 2012, 09:37 AM
RCRod is offline
Find More Posts by RCRod
Acacia II Lunar Lander
RCRod's Avatar
United States, CA, LADERA RANCH
Joined Feb 2011
Question
Wire Gauge for Digital Servos
I'm starting a re-wiring project on my current F3F racer (Acacia II), and am preparing for a new build (Willow). I've come across a question I'd like some help with: wire gauge for running plumbing to the digital wing servos.
What gauge do you use?
I know the bigger seems better, but I'm finding that running 22 AWG through a single connector on my Acacia II's center panel is feeling very crowded. I have an 8-pin multiplex connector (like the green 6-pin ones we all know and use, but with an extra two pins) through which I'm trying to connect all four servos. With the fat 22 AWG stuff, it's pretty tough to get 12 leads crammed together around the little pins. I'm trying an experiment wherein I'm only running power (plus/minus) from two channels, and just signal wires from the other two into the fuse side of the connector. I'll branch the power on the wing side a little bit downstream from the connector, so I have room.
Is that silly? Am I over-killing it with the fat 22 AWG? Should I scrap the single 8-pin connector and go to two 6-pin connectors, so they're not as crowded?
Any experience-driven opinions would be appreciated!
Cheers,
Rod
RCRod is offline Find More Posts by RCRod
Old Jun 22, 2012, 01:38 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I run 22awg for power and 28awg for the signal wire to save a bit of weight. I tax my wing servos pretty heavily during launches.
Experience:
I manage a large number of various types of radios that average 60 watts output, (railroad). Recently we changed the input wiring in a series of facilities from #12 to #8. These 100 watt radios were drawing enough current that the voltage was dropping below the minimum threshold. The change in input wiring guage solved the problem entirely.
schrederman is offline Find More Posts by schrederman
Old Jun 22, 2012, 01:54 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
I wouldn't worry about the gauge too much. The stall current on the servos will be a lot less than the rating of even pretty thin wire.
I've haven't heard of or experienced having problems (f3b etc) running 6 digis off 1 servo plug in to the receiver, which powers the 6 servos. Unless you bypass the receiver an power your servos direct from the battery you are only running all your servos through a pair (or maybe two pairs) of servo pins going in to the rx. (Usually I put two leads in to the RX to be on the safe side. )
satinet is online now Find More Posts by satinet
Old Jun 22, 2012, 02:28 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
I use 24 guage teflon coated for power and 26 for signal. Expensive wire but using stock 22 guage servo wire adds an extra ounce or more to a model.
mlachow is offline Find More Posts by mlachow
Old Jun 22, 2012, 03:26 PM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
All good info, guys. Thanks a bunch!
I think I'll step down to a smaller gauge. Stuffing the crimped ends of the 22 AWG wires into the connector housings is a pain in the butt.
Satinet, you touched on a point I was considering, as well. It hardly seemed necessary to run so many power leads to the wing, when the entire system is pulling juice through only the wires from my BEC.
Old Jun 22, 2012, 03:43 PM
F3B
satinet's Avatar
Joined Sep 2006
well my point is merely that if you are running all your servos through one power lead that is the same rating as each individual servo wire, your problem is not your servo wires. not that there is a problem.
It's really solving a problem that doesn't exist. yes you can pull a fair bit of current on a winch launch because you have a lot of deflection on the surfaces and a lot of speed, but the wire can take high loads for a short period quite easily.
Old Jun 22, 2012, 03:48 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Good topic and something I have always wondered about...
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Jun 22, 2012, 04:10 PM
F3B
satinet's Avatar
Joined Sep 2006
some info about servo wire ratings here:
http://www.smservices.net/acatalog/Cable_and_Wire.html
in metric but you can convert it. I assume 0.34mm is the same as 22awg (looks like when I bought some). That takes 6amp continuous and 12+amp for 5m minutes. So even if you go down a grade i very much doubt you will have a problem.
IIRC the typical stall current of a digi wing servo is something like 1-1.5amps.
Old Jun 22, 2012, 07:26 PM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Really helpful posts, Satinet! Thanks very much!
Old Jun 23, 2012, 01:26 AM
roydor is offline
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
In the following link you will find a chart with max current and a calculator for the voltage drop.
http://www.powerstream.com/Wire_Size.htm
In general it is wise to de-rate the wires by a factor of 2, this means that for a servo with a current draw of 1 amp you wouldn't use a wire with less than a 2 amps for its max rating.
roydor is offline Find More Posts by roydor
Old Jun 23, 2012, 03:04 AM
F3B
satinet's Avatar
Joined Sep 2006
With this information plus the stall current of your servo you should have no problem working out what you need.
Old Jun 23, 2012, 07:54 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Nice resource! Roydor, do you know if that data is for single- or multi-conductor wire? Servo wire is all multi-conductor.
Old Jun 23, 2012, 08:19 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Here's another good resource...
Hansen sells wire and connectors. This PDF is his a how-to for creating servo leads and extensions.
http://www.hansenhobbies.com/product...Connectors.pdf
He includes a table of gauges and resistance. The only data missing is max amperage. Is there a formula we can use to determine that?
Old Jun 23, 2012, 11:04 AM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
There is a formula it is current=voltage/resistance of wire per unit length. So if you are using a 3 foot piece of wire and it measures 5ohms
Current=6.0volts/5 ohms
Current = 1.2 amps
J. Wydronek is offline Find More Posts by J. Wydronek
Old Jun 26, 2012, 07:32 AM
Joined Nov 2002
I used the heavier wire not for current carrying capacity, but for the drop in voltage over the long leads.
Sold Rc logger digital pitch gauge gso125 Aircraft - Electric - Helis (FS/W) 2 Jun 20, 2012 10:43 AM
Off Site Rc logger digital pitch gauge gso125 Aircraft - Electric - Helis (FS/W) 1 Jun 15, 2012 02:09 PM
For Sale Align Digital Pitch Gauge AP800 $35 Pathseeker56 Aircraft - General - Miscellaneous (FS/W) 0 Jun 13, 2012 11:57 PM
Question What Gauge Wire to use for hook ups. roach101761 Scale Boats 9 Apr 06, 2012 08:05 AM
Question re: use of solid 22 gauge wire for servo leads YVR Radios 1 Feb 15, 2003 03:38 PM
