This thread is privately moderated by Syberian, who may elect to delete unwanted replies.
Old Jul 10, 2012, 02:30 AM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
GCS has been updated. Its window size has been shrinked to 600px vertical to fit into most netbooks.
Vibrations? Copter to small?
Was that normal on another controllers in acro mode? It's hard to judje not seeing a video.
Anyway, im working on the better AHRS algorithm.
1881 reversed synchro
It means adding another config option because my board is not using a 1881 so it can confuse users why there is no OSD. Consider soldering that 7404 or even a simple FET transistor to invert the signal.
Syberian is offline Find More Posts by Syberian
Old Jul 10, 2012, 04:34 AM
Lufträuber
Deutschland, Nordrhein-Westfalen, Ochtrup
Joined Jul 2011
Hello.
GCS looks good now.
But i can't test it right now, because i'm at work.
Simply: no
For me it's no problem.
And i'm sure for other DIY users is it also no Problem.
JaggerMD is offline Find More Posts by JaggerMD
Old Jul 10, 2012, 01:02 PM
Lufträuber
Joined Jul 2011
I think i have a vibration problem.
I will build a new quad.
Have some KDA20-26 and Plush 18 here that i will use.
I think ca 600.
http://player.vimeo.com/video/45521704
http://player.vimeo.com/video/45523488
Same frame last year (before some crashs). But now with Multiwii it flys like this.
Multiwii Sep 2011 (3 min 25 sec)
Old Jul 13, 2012, 11:06 AM
Lufträuber
Joined Jul 2011
Originally Posted by Syberian View Post
Also the board will try to re-configure MTK and UBLOX modules working at 9600 by default: try to switch them to 38400 NMEA @ 5 or 10Hz which available.
Hello.
Today i tried the automatic reconfiguration on my ublox neo6m (frsky module).
Sorry, it'not working.
Reconfigure in ucenter is no problem.
But this module does not hold the settings after power loss.
Atm it's no problem, because my other (bigger) module works.
OSD,GCS and communication works great!!
Thank you for your good job.
PS: New Quad with t-motors 900kvfor your Pirate is in progress.
Old Jul 13, 2012, 02:26 PM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
Hello Marcus,
Thanks for video! Though I'm not satisfied how your quad flies. I need to re-check it by myself.
So it is a time to move all that discovery "ratsnest" back from my plane to the tricopter.
Also I hope to borrow an Ublox from friend (mine blackvortex's one was fried this winter) and solve the ublox configuration issue.
Sorry I cannot reply often for some time. I have a daughter just born yesterday and all that stuff with hospital, diapers, relatives, beer etc... Heaven knows how happy I am!
Old Jul 14, 2012, 04:40 PM
Joined Sep 2010
Congratulations Oleg!
msev is offline Find More Posts by msev
Old Jul 15, 2012, 02:45 AM
Lufträuber
Joined Jul 2011
Congratulations!!!
I hope everything is fine with your wife and daughter.
New Quad is nearly finished.
Maybe i can post a video this evening.
Marcus
Old Jul 15, 2012, 03:59 AM
Joined Sep 2010
Oleg will you provide schematics or write down connections for the antenna tracker board?
Old Jul 15, 2012, 08:33 AM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
Thanks!
msev, there are no reasons for head scratching with the AAT. There will be standard 5V servo pan and tilt 3-pins, a standard barrel plug for Vin from 7 to 42v and a standard so called 'tulip' socket for video in.
Also Im writing a chapter in the manual about the AAT servos tuning.
Old Jul 15, 2012, 12:07 PM
Joined Sep 2010
I like to build things myself thats why I ask
Old Jul 15, 2012, 01:51 PM
Lufträuber
Joined Jul 2011
So, tested with new quad.
But it's nearly the same.
I think the old small quad flies slightly better.
Sorry, no video.
btw: wat's the name from your daughter?
Old Jul 15, 2012, 09:13 PM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
Marcus,
Your quad looks good and should not cause any problems. Let me check by myself. Maybe I had broke something quad-related when tuned the plane part of the code.
btw: her name is Veronika
Old Jul 16, 2012, 03:54 AM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
hey Marcus,
I've just build a tri and tried an acro mode. True, it flies like a piece of sh.... Since Im bad flier at all, I never tried an acro mode, only stab. Though I do have a point how should it fly with gyros. I need a small time to fix it.
Old Jul 16, 2012, 04:13 AM
Lufträuber
Joined Jul 2011
No Problem.
I will wait.
In the meantime i will test the board in my fpvraptor.
But for this i need help from my friend.
Because i'm not a good pilot with "big" planes like this.
Atm i dont want to rtfm.
How i must trim the Servos?
Simply trim that it flies good, and then press neutral?
Marcus
Old Jul 16, 2012, 04:36 AM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
Trim it in manual mode then press neutral.
Though I had 15 degrees in ailerons set in opposite sides totally untrimmed and flew OK in stable (yes, always) mode until accidentally flipped that damn switch in manual!! Duh, that was hard time for my skills. She wanted to make a barrel roll on a skywalker constantly.
New Product Pirates' Productions Proudly Presents: the MegaPirate UAV and more... kinderkram Multirotor Talk 3838 Today 01:57 AM
New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware Jessestr Multirotor Talk 40 Jun 25, 2012 08:18 PM
For Sale HoverFlyPro Control Board for Multirotor UAV's Bruce Mandel Aircraft - Electric - Miscellaneous (FS/W) 1 Jun 14, 2012 08:23 PM
Discussion X copter based on KK V5.5 board liftof problems riahut.com Multirotor Talk 1 Apr 07, 2012 10:41 PM
Discussion Inemo inertial module stm32 and mems demonstration board Z06 Tony Multirotor Talk 0 May 02, 2011 03:57 PM
