Old Jun 22, 2012, 03:50 AM
Genetics101 is offline
Find More Posts by Genetics101
We were all NOOBS once!
Genetics101's Avatar
United States, WA, Seattle
Joined Sep 2011
Question
NAZA's GPS add on. Need help! Please-
I swear I just picked up the last two GPS modules left in the entire U.S.. This add on to the NAZA is the best thing since bread & butter but aside from everything working great I've got one last thing that needs to be done & I don't feel comfortable showing off the "return to home" function until I do it... It's a procedure that I don't quite understand & has to do with flipping one of the switches on the radio multiple times & then holding the multi rotor vertically & then horizontally while turning in a counterclockwise motion until the GPS/compass calibrates itself. I don't understand this procedure & would be grateful for someone to help... P.s- the GPS units work well the way they are but in some cases the platform will make sweeping motions as it seems to be looking for it's bearings. I can only suspect that this is from not calibrating the module yet. Can anyone help? Thankyou
Genetics101 is offline Find More Posts by Genetics101
Old Jun 22, 2012, 09:54 AM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Recommend you look in the Multi Rotor Helis Forum.
jforkner is offline Find More Posts by jforkner
Old Jun 22, 2012, 10:28 AM
Wingnut13 is offline
Find More Posts by Wingnut13
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
It sounds like you understand the procedure pretty well. From what I understand you are just calibrating the sensors to the new environment, motors, esc's and such. Flip you switch 6 ~ 8 times to get the NAZA into the calibration mode, hold it so you can see the LED turn green and turn around with the multicopter in a horizontal plane. Once the LED changes color turn the multicopter to the vertical plane and turn around again. If it takes, the LED will go back to standard amber color and if there was a problem it will blink rapidly red. So try again.
The GPS thread can be helpful if you can find information in between all the how do I program my radio questions!
Wingnut13 is offline Find More Posts by Wingnut13
Old Jun 24, 2012, 09:02 AM
Joined Sep 2011
Sometimes we answer our own questions, thanks for the input
Old Jul 05, 2012, 04:18 PM
hazchem88 is offline
Find More Posts by hazchem88
Joined Dec 2009
this switch flicking is just to calibrate the compass,
also, you only need to calibrate compass once.
You only need to re-calibrate if you move your stuff around on your quad,
If your setup stays the same then just do once
I tried RTH today for the first time.
scary, but worked perfectly
hazchem88 is offline Find More Posts by hazchem88
Discussion Help With Turnigy Setting for Dji Naza GPS r2pardjo Multirotor Electronics 10 Oct 01, 2014 08:52 AM
Build Log Talon Hexa 625 with NAZA GPS and Arris CM2000 Brushless Gimbal chuenwe Multirotor Talk 227 Feb 13, 2014 10:41 AM
Help! Naza quad need help won't turn right Damuelson Multirotor Talk 2 Jun 24, 2012 09:25 AM
Help! Need help with T-Motor issue on Naza!! Arxangel Multirotor Talk 4 Apr 21, 2012 09:02 AM
Help! Pleas Help! Need info on USA car size quick! fooesboy Slope 9 Aug 04, 2008 01:23 PM
