Old Jun 22, 2012, 12:03 AM
Melange2008 is offline
Find More Posts by Melange2008
Joined Aug 2008
Nicad Charging
Hi.
I have a requirment to charge a 23 Cell Nicad Pack 2500mHA.
Using the Cellpro 10XP with 8mA fall backsetting (default) the charger goes to trickle charge after 200mA but the battery is no where near charged.
Version 1.19 firmware.
I have 3 different chargers all doing the same...does anyone have any reason why and how to fix it.
Richard.
Melange2008 is offline Find More Posts by Melange2008
Old Jun 22, 2012, 10:21 AM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
I'm no 10XP or NiCd expert, but the pack could be full or bad if you have 3 chargers doing this to you. What is the voltage of the pack and have you tried fully discharging it first? Posting pictures of charge voltage, current, and fallback volts may be helpful as well.
SteveM732 is offline Find More Posts by SteveM732
Old Jun 22, 2012, 09:56 PM
Joined Aug 2008
Hi Steve
I have tried 3 different battery packs.. all brand new.. all doing the same.
I charged one of the packs on a supernova charges and it worked fine. took about 2500mA to reach fully charged.. the same pack on the XP dropped to trickle after only 200mA.
Richard
Old Jun 22, 2012, 11:30 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I would try increasing the fallback voltage. Monitor the pack temp during the charge. If the pack starts to get warm or hot and the charge cycle does not end, the fall back voltage setting is too high.
Gregor99 is offline Find More Posts by Gregor99
Old Jun 24, 2012, 05:08 AM
Joined Aug 2008
hi.. not sure how to increase the fall back voltage.. the Pre-Set is only 8mV per cell (23 cell nicad)
is there an option to change it.. Had a look in the settings via the PC..
Richard
Old Jun 24, 2012, 02:07 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Richard
Hi:
On the Cellpro 10XP, the fallback voltages are fixed at 8mV for NiCd and 5mV for NiMH.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Jun 24, 2012, 09:55 PM
Joined Aug 2008
Hi Tim
Have you had any problems charging the Nicad packs..? We have bought 6 chargers because they could handle the 23 Cell count.
Do you have any recommendations.?
Richard
Old Jun 24, 2012, 10:04 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Sorry. Didn't realize the 10XP had a fixed value.
Old Jun 24, 2012, 10:49 PM
Tim Marks's Avatar
Joined Mar 2008
Original Post:
Hi Tim
Richard
Hi:
What charge rate setting are you using?
Tim Marks
Old Jun 25, 2012, 03:50 AM
Joined Aug 2008
2 Amps.. tried 2.5 Amp too..
Is there a way to graph the charge on the PC.. I know you can do it with LiPo but when you select Nicad the graphs don't show.
Richard
Old Jun 25, 2012, 10:54 AM
Tim Marks's Avatar
Joined Mar 2008
Richard
Hi:
It's likely this particular battery is false peaking on the 10XP. Please try raising the charge current to 3.5A and give that a go. Let me know how you make out. The graphing function does work for NiCd, but not all the graphs are applicable. Pack Voltage and current graphs should work. It may be that the charger is kicking out of charge mode before the graphs have a chance to come up?
Tim Marks
Old Jun 25, 2012, 07:25 PM
Joined Aug 2008
Hi Tim
A little better.. a new battery took 281mA... The Cells are 1/2 D 2500mHA
The Datasheet says to charge at only 900mA.. I did try but only got 80mA
http://www.master-instruments.com.au...3/ET2500D.html
Is there a way to change the Fall back Voltage or is that a firmware change..?
I still have no trouble using the SuperNova with 8mV per cell.. but on there you enter the cell count.. How does the XP know how many cell there are in the pack..?
Richard
Old Jun 25, 2012, 11:14 PM
Tim Marks's Avatar
Joined Mar 2008
Hi Tim
Richard
Hi:
Currently, fallback voltage is fixed on the CP10XP. Yes, it would require a firmware change to alter this. Let me work with the design engineer and see if there is any chance of supplying a firmware upgrade you might be able to try.
In the CP10XP, the no. of cells is autodetected. It re-adjusts the count as time goes by but eventually "locks in". Generally, even if it does not get the cell count 100% accurate, it is not enough to make much difference on total fallback for a pack.
Let me see what I can come up with. I'll get back to you.
It might be good if you send me an email at tim@fmadirect.com so I can better support you. Forums are not the greatest tool for this type of issue.
Tim Marks
Discussion Accucell-6 Charging Nicads WhiteNite1971 Batteries and Chargers 18 Jan 02, 2013 02:53 AM
Discussion Charging NiCad's? Colbyntx Batteries and Chargers 19 May 01, 2012 12:06 PM
Discussion Charge rate for Nicads anash929 Fuel Plane Talk 13 Apr 29, 2012 08:09 AM
Question NICaD Battery charging? harleythatcher Batteries and Chargers 5 Apr 27, 2012 05:14 PM
Question Stupid NiCad charging question. Wookster Batteries and Chargers 22 Apr 22, 2012 02:13 PM
