This thread is privately moderated by xplaneguy, who may elect to delete unwanted replies.
Old Jun 21, 2012, 05:46 PM
xplaneguy is online now
Find More Posts by xplaneguy
EB-66C Team Member
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
New Product
Hobby King 64mm RQ-4B NASA Global Hawk
Back in 2003, I had an opportunity to be a Crew Chief on an Air Force Block 10 Global Hawk (Ship 6). Several years ago, Ship 6 went to the NASA Dryden Flight Research Center here at Edwards AFB, CA , so... I couldn't resist the new 64mm NASA Global Hawk from Hobby King.
Assembly was easy with the two issues being: no manual included and the main gear installation. The main gear plastic mount plate holes need to be slightly enlarged to prevent cracking when installing the mount screws. An option is to replace the plastic mount plates with light ply, coated with epoxy. I painted all the hardware white and added pitot tubes to the verticals. Planning to fly the maiden this weekend. I'm using the 1/3 rule back from the leading edge for the initial CG. Once I get it fine tuned, I'll post my CG with a 14.8v 2200mAh battery.
Here's the specs and some photos:
Specs:
Wingspan: 2360mm (92.9 inches)
Length: 850mm
Wing Area: 23.6dm2
Wing Loading: 42.4g/dm2
Flying Weight: 1000g
EDF: 64mm with Brushless Outrunner Motor
ESC: 50A w/BEC
Servo: 9g x 5
Requires:
Your own 4~6 Channel TX/RX
1800mAh 4s Lipoly Battery
Best,
Tony
xplaneguy is online now Find More Posts by xplaneguy
Old Jun 22, 2012, 06:13 AM
KiwiKid is offline
Find More Posts by KiwiKid
RCGroups - my happy place
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Great stuff Tony - loved the pics.
I have one of these too, unfortunately it was packageed with two starboard stabilisers only. Went through the mill with HK and then found a chap in Aussie who had received one with two port stabs, so we are doing swapsies at the moment.
Would be relly keen to hear your thoughts and tips on this model - thanks.
ps Evelyn is growing up to be quite the young lady - has she found "boys" yet??
KiwiKid is offline Find More Posts by KiwiKid
Old Jun 22, 2012, 11:29 PM
EB-66C Team Member
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Kiwikid-Thanks for the feedback. Sorry to hear about the vertical stabilizer problem.
The only boy Evelyn likes is Harry Potter.....thank God! She's read all the books and owns the movies.
Best regards,
Tony
Old Jul 06, 2012, 01:02 PM
ara25demayo is offline
Find More Posts by ara25demayo
México, MOR, Jiutepec
Joined Oct 2011
hi im thinking of buying this EDF is the PNF version right? does the edf work well or you think i might change ir for this one http://www.hobbyking.com/hobbyking/s..._750w_4s_.html
ara25demayo is offline Find More Posts by ara25demayo
Old Jul 08, 2012, 01:07 AM
EB-66C Team Member
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
The stock fan works well with more than enough thrust but it could use some balancing. I have one flight on mine and will be moving the battery aft to the back edge of the battery mount plate
Best,
Tony
Old Jan 29, 2015, 02:42 AM
hobidude is offline
Find More Posts by hobidude
can't wait to retire..
hobidude's Avatar
Australia, ACT, Symonston
Joined Feb 2006
I noticed th thread is a couple of years old however thought I would post here in case anyone was interested.
I bought one of these also and now that I went to build I found the same issue as many have had, 2 x right stabs!
So if anyone has a left (port side) stab spare I would like to buy.
or if anyone is still into these and wants a new in box kit with no left fin then I would be happy with $30 plus freight. It is the complete kit with fan and servos installed,
hobidude is offline Find More Posts by hobidude
Old Jan 29, 2015, 02:53 PM
KiwiKid is offline
KiwiKid's Avatar
Joined Jun 2005
Hi hobiduude, can't help with the fin - could you make one?
Here's a link to the GH thread which has been active recently - you could also post there:
http://www.rcgroups.com/forums/showt...5#post30242498
Help! 1:12 RQ-4B Global Hawk EDF GourmetSaint Scratchbuilt EDFs 15 Jun 11, 2012 08:03 PM
Discussion hobby king rq4b global hawk splitpilot Foamy EDFs 13 Jun 06, 2012 06:59 AM
Video Hobby King "Global Hawk" aerial video Alrus1 Electric Plane Talk 0 Feb 19, 2011 01:50 AM
Video Hobby King "Global Hawk" aerial video Alrus1 Electric Heli Talk 0 Feb 19, 2011 01:48 AM
