Old Jun 21, 2012, 04:08 PM
GreenAce92_v2 is offline
Find More Posts by GreenAce92_v2
Euphoric flights
GreenAce92_v2's Avatar
United States, NY, Buffalo
Joined Aug 2011
Hollow channel spars, how to fabricate?
OK so here is how I envisioned that these hollow spars would be made:
Channels are cut with a mighty knife
Then carbon matting of some sort is bedded down on the channels which are then slathered in some sort of epoxy.
Then a "plug" is pressed in to get the nice shape.
The process finishes, dries and plug is released.
But... would this spar be strong enough to be depended upon? Also what type of matting / layers would be needed as well as resin? Can someone list specific sites?
Gratzi, Gratzi.
GreenAce92_v2 is offline Find More Posts by GreenAce92_v2
Old Jun 21, 2012, 08:31 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
In the book "Radio Control Foam Modelling" the author showed a spar which was a half circle cut out and glass or carbon was laid into the kerf and then the half circle was pressed back in. Seemed like a good idea...I haven't ever tried it though.
Do you need the channel to be hollow? or could you use the foam for the "plug?"
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Jun 22, 2012, 12:46 AM
Euphoric flights
Joined Aug 2011
Well the channel ideally is to be for dual use, not only for structural reinforcement but to house the wires going to servos on the wings...
Sort of like an "easy to get to" solution for long wires. Though it isn't necessary that they be hollow. However most likely the channels will be hollow since I "pick" out the the foam channel with a flat head screw driver.
Question How do I orient an Orange RX 6 channel with satellite inside my plane? trevorcgross Radios 2 Jun 11, 2012 05:34 PM
Discussion Dumb easy way to make spar channels in foam Piece Foamies (Scratchbuilt) 5 Jun 02, 2012 09:01 AM
Help! How to fabricate a bifurcated duct? spencer6891 Scratchbuilt EDFs 3 May 07, 2012 02:24 PM
Question Adding steel rod in EasyGilder's hollow spar rkhoo Slope 1 Sep 19, 2008 11:16 AM
Wing reinforcement using ALU. Hollow Spar guapoman2000 Parkflyers 4 Sep 08, 2003 11:45 PM
