Joined Sep 2003
MooseFlyR,
I think the 350 motor is using C gearing(5.33:1). VWtechie, After taking the motor out from the water, how should I dry it? using hairdryer? should I run it again for few seconds? What kind of oil should be used on the motor after it is dried? Should I drop the oil into the inner part of the motor through those holes on the motor casing? Thanks |
After 5 minutes I could barely detect any carbon/metal in the water at all, and looking at the brushes through the side hole showed no signs of wear, it was still only the rised outer edges of the brushes that touched the communicator. It took 30 minutes of break in before the ridges on the brushes had worn down enough for me to consider it ready. |
Idaho
Joined Sep 2003
HTY...
You should always break in your brushed electric motors. Break-in allows the brushes to seat against the commutator properly, insuring optimal electical contact and increased motor efficiency. If you just run a fresh motor at full power you will get arcing that will pit the brushes and the motor will never be as good as it would be if you had broken it in properly. VWtechie is right, the fastest way to break in a motor is the one that he describes. Just make sure to use only about 1/2 as many cells as you would use to fly with. Should only take 5-15 minutes this way. Make sure to dry it completely! You can use a hair dryer or heat gun to dry it. Then shoot it with a good light oil. WD-40 works, but I prefer spray silicone oil as it is VERY tenacious and doesn't seem to gum up the way that WD-40 can. Just make sure that it is completely dry, as the silicone does not displace water the way that WD-40 does. Alternatively you can just set the motor to running while you are working on another part of the kit. Let it run until your pack (again...about 1/2 flying voltage) is depleted. Check the motor once in a while to make sure that it is not getting hot. Warm is OK. If it is getting hot, reduce the number of cells in your pack. This method usually takes 2-4 hours, but you don't have to worry about getting everything dry, and is probably better for motor/gearbox combos where you can't actually get into the gearbox to make sure that everything is dry. --JB |
The best liquid for breaking in motors is alcohol, the kind you find in a paint store. I will evaporate quickly if you keep the motor running for a few minutes after removing it from being submerged. Re-oil the bearings using only a very small amount of oil. Use a needle type oiler or a tooth pick.
Ken |
I know lots of "E" modelers who have been doing this for years, as well as myself. The sparks from the comutator do not ignite the alcohol. I would not post something that I thought would be a dangerous practice. This has been a common method used for years and no one I know has ever had a problem.
I realize your concerns in regards to safety and in all modeling activities that should be formost. So, if you feel uncomfortable with this method, don't use it. |
Columbia Regional, Missouri, United States
Joined Dec 2002
PLEASE FELLAS----
W D 40 is NOT a lubricant. It stands for Water Displament. 40 was the 40th try. It is the what the ARMED FORCES call cosmoline. All FIREARMES are coated with W D 40 and packed away. When opened, or assigned to, they HAVE to be thourly cleaned to take OFF the cosmoline (W D 40) . When W D 40 gets heated, it forms a very hard coating. Back in my dirt track days, we used to coat new headers with W D 40 and run them emmediatly to seal them against water and mud from the track! I think that the brushes and contant area will get hot enough to create this coating on the comm and then you will have trouble with it and the only way eleviate this problem is to CLEAN between the segments and turn the comm. PHIL I. |
Columbia, MO USA
Joined Feb 2001
I forgot about that
! I usually dry mine out with a heat gun and then just re-oil the bushing/bearings as soon as they're dry. I'm not sure what temp it takes to cook cosmoline but I have measured endbells after a long flight at over 200 degrees F. If the endbell is that hot then the brushes and comm must be really cookin'. Thanks for pointing that one out Phil.--Brad BTW Phil, your new radio should be on its way to HTUSA.
| Thread Tools | |
| How should I break-in my new RadicalRC 8 cell 2500mah tx pack? | EddieNewYork | Batteries and Chargers | 4 | Jun 07, 2005 03:48 PM |
| Any problems in using Accucycle to cycle 7--8 cell power packs? | 1g1yy | Batteries and Chargers | 0 | Jul 14, 2003 02:52 PM |
| FS: 7 and 8 cell AAA packs for GWS and similar | webnetxpress | Aircraft - Electric - Airplanes (FS/W) | 0 | May 21, 2003 10:40 AM |
| How to break in a brushed motor with ESC built in. | saint | Power Systems | 1 | May 12, 2003 02:22 PM |
| How to break in a motor | NoVaNewB | Power Systems | 2 | Feb 26, 2003 01:16 AM |
