Old Dec 27, 2012, 01:04 AM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by Teamsherman View Post
Yep, especially going the other way on another battery!!! I could hear the dents in the balsa wood being made on every pass!! LOL
lol. Better check down the carby for some roost if they are petrol haha.
chktm is offline Find More Posts by chktm
Old Dec 27, 2012, 01:14 AM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Looking good Alan. Enjoy!
JohnnyMc is offline Find More Posts by JohnnyMc
Old Dec 27, 2012, 01:38 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
FunCub and MM450 Aerial view! (1 min 7 sec)
Teamsherman is offline Find More Posts by Teamsherman
Old Dec 27, 2012, 01:39 AM
Member #1
Joined Aug 2011
Nah we only fly electrics there which is good! The video ive just posted has a little bit of my funcub in it, with my mate chasing it in his FPV quadcopter.
Old Dec 27, 2012, 03:25 AM
chktm is offline
Joined Jul 2012
That was really cool Alan. Great fun.
Old Dec 27, 2012, 06:39 PM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Guys, thanks for the help and fast replies!
Loving the bike!!
davehour is offline Find More Posts by davehour
Old Dec 27, 2012, 06:56 PM
chktm is offline
Joined Jul 2012
Loving the bike!!
No worries, great bike all right .
Old Dec 27, 2012, 07:10 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Hi again,
I installed the front brake kit. The brake cable length is marginal to be pinched at the servo horn. The outer tube can't be shortened as its length is what's needed to not interfere with the steering. I'll have to get a new cable. I read you're using push bike brake cables.
Regarding the VR3T 2.4 setup for the front brakes, do you use B-MIX or MIX?
I also noticed there's a switch at the top of the radio for the AUX channel. Do you setup the brakes with the switch on or off? I ask because the Tx manual doesn't mention anything about it. The brake works at both positions. The difference is the servo seems to move its center with the switch on. But if the brakes are setup with the switch at the on position, and later the witch is turned of for any reason, the servo horn with peg at the brake cable bracket.
Thanks in advance.
David
Old Dec 27, 2012, 07:54 PM
chktm is offline
Joined Jul 2012
Hi again,
Thanks in advance.
David
No worries David, you are correct the servo works with the switch in both positions. The info here is how I set mine up.
http://www.rcgroups.com/forums/showt...1784958&page=2
Old Dec 28, 2012, 04:16 AM
Member #1
Joined Aug 2011
Hi guys,
On the box of the bike it says it has a "mechanical traction control system", is this just the slipper clutch? Cause the picture is of the drive cog and chain? Is there a part there I've got confused? Only reason I ask is cause I like to know the ins and outs of how my Rc vehicles work.
Old Dec 28, 2012, 04:41 AM
chktm is offline
Joined Jul 2012
Hi guys,
Hi Alan, its referring to the changeable blocks that support the swingarm shaft. By changing the position of the swingarm you can change the amount of squat or anti squat which can change the handling of the bike. I haven't tried it on bitumen but I've heard some people use the reversed B block and have been happy. I run on slippery dirt usually and still prefer the A block to the B. I don't seem to need any more grip and I find the squatting through the corner only upsets the bike for me. The slipper works like any other slipper. Hope that helps.
Old Dec 28, 2012, 04:43 AM
chktm is offline
Joined Jul 2012
Had some awesome fun destroying some berms today. Got some nice close ups. I think it looks ok.
Atomik MM450 awesome loam berm blasting (3 min 21 sec)
Old Dec 28, 2012, 06:13 AM
Member #1
Joined Aug 2011
Ahhhh yeah, i did read that in the manual about the blocks! Mate you're a bloody fountain of knowledge!!! Cheers!
http://youtu.be/jnGssz7RRSQ
That bike of yours is dialed in!!! You're running a different motor aren't you? I've just ordered a 12 and 13 tooth pinion to try and get a little more from my stock motor, I think if that's still a little tame, I'll look at getting the motor you're running.
Cheers!
Old Dec 28, 2012, 07:27 AM
chktm is offline
Joined Jul 2012
Cheers!
No worries Alan. The bike feels pretty good. This bike has a std motor geared with a 12 in this vid. I like 12 or 13. 12 gives good speed and great punch, 13 has a little more speed and pull up high but loses a little down low. The motor still seems to pull it fine.
Old Dec 28, 2012, 07:37 AM
TopDave is offline
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Get rid of that giant orange road cone at the one end, and you would swear that was one of your Ozzy pro's on his practice track slamming the berms and roosting out, lol. neat stuff!
TopDave is offline Find More Posts by TopDave
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
