Old Dec 01, 2012, 08:53 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Have been away for the weekend and found this neat little spot to unleash the bike and have a bit of fun.
Atomik Brian Deegan MM450 Dirtbike (1 min 45 sec)
Atomik Brian Deegan MM450 Dirtbike (1 min 2 sec)
chktm is offline Find More Posts by chktm
Old Dec 02, 2012, 04:53 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Originally Posted by chktm View Post
Try RedStar hobbies maybe, I think they had stock in Australia of them still.
They come as a pack, inserts and tyres.
Yep, got some!!
Teamsherman is offline Find More Posts by Teamsherman
Old Dec 02, 2012, 05:11 AM
chktm is offline
Joined Jul 2012
Originally Posted by Teamsherman View Post
Yep, got some!!
thought they might have some
Old Dec 02, 2012, 05:44 AM
Member #1
Joined Aug 2011
They have a few parts that look like they might be interchangeable which is always good!
Old Dec 02, 2012, 06:41 AM
chktm is offline
Joined Jul 2012
Most of the parts for the VMX will fit the MM. Basically the same bike but with a e gyro and a few small changes. Save some freight for sure. Just watch if you order SM inserts separately the front and rear part numbers were mixed up. You might see that when you receive yours if you check. Way better value to get a set I think though.
Old Dec 02, 2012, 06:46 AM
chktm is offline
Joined Jul 2012
TJ, what batteries have you got to use?
Old Dec 02, 2012, 06:50 AM
chktm is offline
Joined Jul 2012
Also going to Ultra Hobbies tomorrow. Do you want me to see if they have a pinion to suit for you. I could send it down, although by the time it gets their yours might have turned up.
Old Dec 02, 2012, 06:52 AM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
I have a zippy 5200mah 30C that i had from one of my other models i am going to use for now but am going to get a few more maybe 6000mah & biggest C i can get.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Dec 02, 2012, 06:53 AM
Sydney, Australia
Joined Mar 2010
That's ok mate thanks anyway they can't be far away now.
Old Dec 02, 2012, 07:01 AM
chktm is offline
Joined Jul 2012
No worries. The only thing with the bigger batteries is the bike doesn't handle as sharply. Also jump landings are harsher. You have to be smoother on the throttle while cornering. I try not to use the 6000 batteries anywhere apart from quite small jumps. They are good for flat track. For the big track jumps and track work I use 5000s. I think your 5200 will be pretty good. Maybe try your mates 3200 in comparison, this will give you some idea what the different battery weights do.
Old Dec 02, 2012, 07:04 AM
chktm is offline
Joined Jul 2012
The other thing is the inserts cop more of a hiding with the extra weight and the bike can tip quicker due to a height C of G.
Old Dec 02, 2012, 07:08 AM
chktm is offline
Joined Jul 2012
One more thing I've found is for the best stability, the batteries need to be in good condition. This makes the gyro spin at optimal speed.
Old Dec 02, 2012, 07:17 AM
Sydney, Australia
Joined Mar 2010
Ok cheers mate i will keep that in mind when i am on the hunt for more.
Old Dec 02, 2012, 12:05 PM
TopDave is offline
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
VMX E GYRO LOW CG RUNNING gear
This bike is running a lightened "gutted out" Vinnie rider, a low CG custom MAX AMPS 4000mah battery that DOES FIT the stock battery box, the new roller crash bars with much more lean angle than before,AND THE AMAZING hinged rear fender! The bike really is noticably quicker stopping, cornering and stands back up on it's wheels much faster than with standard battery pack and heavy Degan rider. I did a back to back comparison between the Deegan rider and the Vinnie gutted out rider and the Vinnie is much better even without the lighter battery. The riding in the video is pretty rough in the first minute of the vid, but I smooth out pretty good for the next minute or two. check out the hinged fender at the end! More about the battery and fender in the second vid. The third vid is "racer vinnie" compared to "goonie" Degan. Seriously, who would you put your money on to win?
00160 VMX/MM450 LOW CG SET UP (5 min 19 sec)
00161 VMX LOW CG BATTS + FLIP FENDER SAVER (1 min 31 sec)
00154 (0 min 31 sec)
TopDave is offline Find More Posts by TopDave
Old Dec 02, 2012, 02:00 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Hehe, amazing hinged fender. The alternative way to do it, not sure if it was ChrisH, where the fender is cut like yours but attached to the bar instead of the body. Hey why havnt you considered a wheelie bar yet? I whipped one up in an hour based on a youtube video. I have it in my tips playlist. Maybe next spring/summer when you get out into the dirt, I am curious if you do some track testing to see how each setup runs, low cog vs stock. When you modified the battery tray on the low cog bike, does it still accept the standard stick batteries anymore or is that it, your locked into the fat short battery for that bike?
JohnnyMc is offline Find More Posts by JohnnyMc
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 01:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 11:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 06:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 02:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 10:23 PM
