Old Feb 26, 2013, 12:21 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Yep, great pic of some epic air time.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Feb 26, 2013, 03:01 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by TopDave View Post
scale that jump up to 1:1 ...My, that Deegan is a brave man!
Thanks guys I was thinking the same Dave, that's big in real life lol.
chktm is offline Find More Posts by chktm
Old Feb 26, 2013, 03:47 PM
chktm is offline
Joined Jul 2012
Found another big air shot.
http://www.rcgroups.com/forums/newat...anageattach&p=
Old Feb 27, 2013, 05:36 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Hi guys,
Well, I'm happy to tell you I got a new bike!
No, it's not that I bought a new one, but after correcting some of the wobble, changing the bearings and balancing the flywheel of the gyro, the bike is behaving so much better and different that it seem it's a completely different bike. It's that much that I need to re-learn to drive the bike, specially making turns. The bike leans so smooth and predictable. And I'm getting used to new sounds I hear from the bike now that the gyro isn't making as much noise and vibrations. The bike is really quite. It's sad to get a bike with this kind of imperfection from factory that f it not were because of you guys, I would still be having it the way it came from factory because there was no way to tell. And the bike is doing wheelies better now too!
David
davehour is offline Find More Posts by davehour
Old Feb 27, 2013, 06:24 AM
chktm is offline
Joined Jul 2012
Originally Posted by davehour View Post
Hi guys,
David
David that is great to hear. I'm hearing you when you say it shouldn't come from the factory with those sorts of issues for you to sort. I'm glad you have and can see how much better the bike is and I'm sure it'll make using it that much better again, cool.
Old Feb 27, 2013, 06:42 AM
chktm is offline
Joined Jul 2012
I bought a prop balancer to balance my bad flywheels. It's amazing how out of balance the bad ones are. It works really well.
Old Feb 27, 2013, 06:53 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Chris,
I have that same balancer. I measured by eye and thiought the centers were too small for the flywheel hub and didn't try, but I now see it works with the bearings, LOL.
I believe the worst of all was the big amount of wobble the flywheel came with. Adding that to the unbalance, made the worst combination...
David
Old Feb 27, 2013, 06:57 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Next time, I'll work harder to get rid of all the wobble now that I see how much difference that fix does to the bike.
David
Old Feb 27, 2013, 10:38 AM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
@Dave,
Hehe, new bike...you had me there for a second I thought you bought another one. Its amazing when the first time you really can hear how quiet the egyro can hum when its setup proper. I could deal with the bearing noise but when that noise is gone it just sounds well, perfect. The help here is amazing, I wouldnt have a CLUE without all you guys sharing.
Nice. What brand is it? Looks way more professional than me using my dx450 bike stand and stator reversed. Team CHKTM orange semi truck rolling in style dang haha. I would like to update my balancing tip on website to include this pic, would that be ok Chris?
Old Feb 27, 2013, 03:03 PM
chktm is offline
Joined Jul 2012
Originally Posted by JohnnyMc View Post
@Dave,
Its a Dubro one John. I'm amazed it settles in the same spot to the mm every time. It's very accurate. I'd recommend using this sort of setup to balance as I tried the cleaned out bearings on a drill bit method and couldn't accurately determine the heavy spot on this flywheel. As soon as I put it on the balancer it showed a heavy side. You can use the pic of my messy work area no worries John lol.
Old Feb 27, 2013, 03:32 PM
chktm is offline
Joined Jul 2012
David
David, how did you get rid of wobble. None of mine have wobble really but some are definitely out of balance. I'd be hitting Atomik up to send you out a replacement flywheel.
Old Feb 27, 2013, 04:37 PM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Mine produced wobble after bearing failure. Replaced bearings and it went away.
Old Feb 27, 2013, 04:50 PM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Im just going to throw this out there. I did a quick test with a full charged battery of my bike in backyard just to make sure its working. I noticed the bike turns/steers to the left faster than it does going right. Picked it up and I could see what appears to be the servo pulling the servo horn faster than it does pushing the horn. Checked and steering speed on radio is 100% both ways. I think this is a tower hobbies servo I pulled from my dx450 because previous vmx servo failed. My truck servo just started to fail, my vmx brake failed last week. Ugh.
Old Feb 27, 2013, 07:03 PM
chktm is offline
Joined Jul 2012
John what you want to look at is the EPA adjustment. The way I set my bikes up is as follows. Reduce the amount of travel both left and right to about half travel to the stops, the left adjustment may be different to the right which is pretty normal. Next go out and try the bike and adjust according to the fastest corner taken on the throttle to just get enough steering one way and then turn a corner the other way and adjust as needed. If it needs a bit more dial a bit more in, if it needs less dial some out until the bike turns evenly both ways and the steering isn't too sensitive.
Old Feb 27, 2013, 07:15 PM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Yeah I check it out. I know my epa is different for each just due to servo position I guess. What Im noticing doesnt seem related to epa though, but the speed which servo pushes or pulls on steering so I can enter turn or straighten up out of a turn faster when servo pulls back vs when servo pushes damper foward. I'll check binding tonight. Fun stuff but Id rather be roosting lol.
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
