Old Feb 23, 2013, 07:20 PM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
As Chris pointed out, steering bikes requires good management of throttle and brakes. You can watch one of the Chris's videos and see how bad he steer his bikes . Make us feel a little behind, LOL.
This is one of the aspects we love bikes over cars. Bikes don't steers like cars anytime.
David
davehour is offline Find More Posts by davehour
Old Feb 23, 2013, 07:23 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Originally Posted by chktm View Post
David I've found any play in the gyro bearings and the bearing to rotor or bearing the flywheel fit, ( I used locktite to eliminate and pick the best bearings ) rear wheel bearings, swingarm and or an out of round or wack rear tyre can cause the bike to wobble badly while pulling wheelies. I'd be balancing the flywheel also to improve the bike in that way. Ideally I'd like to see the flywheel be able to be supported by three bearings. This would help the flywheel stay completely slop free. Attention to detail in the rebuilding of the bike will help. Another trick is to keep the power applied gently when pulling wheelies it seems when the throttle is reduced or backed right off the bike can start to wobble in some wheelies. Hitting bumps while pulling a wheelie can cause the wobbles sometimes also.
Originally Posted by Jonathan Bradbury View Post
You can be ever so slightly ''out of balance'' per se when you throttle out of a corner.
A slight bobble in the surface will deflect you and the only(?) answer is swift thumbs to throttle back and recover, otherwise, you get collected by moments of inertia with the gyro.
All part of the fun of biking.
Thanks guys for the help.
Yes, the gyro bearings are needing replacement soon as they are chattering. And the flywheel needs to be balanced.
David
Old Feb 23, 2013, 08:54 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by iflybyu View Post
Good call. I will drive it first and go from there. I have a Hitec 7955 and a futaba S9156 both are 300+ in/lb torque and around 0.15 sec.
What type of fluid do you use? Associated, Losi, etc??
Generally I use Losi oil. For my 70wt I use a mix of 80wt AE and 60wt Losi for the rear shock. TJs big bore setup seems to look like it works well and is worth trying.
chktm is offline Find More Posts by chktm
Old Feb 23, 2013, 08:58 PM
chktm is offline
Joined Jul 2012
David
Your right there David bikes are nothing like cars to steer. It makes it hard as you are holding a wheel though and it can trick you into thinking it will turn like a car lol.
Old Feb 23, 2013, 08:59 PM
chktm is offline
Joined Jul 2012
David
Yea, replace the bearings and balance the flywheel and I'm sure you'll feel a big improvement in the bike.
Old Feb 23, 2013, 09:24 PM
chktm is offline
Joined Jul 2012
Got a few laps in before the supercross .
Atomik MM450 more green laps (3 min 39 sec)
Old Feb 24, 2013, 12:45 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Great vids TJ & chktm. Looks like a lot of rain has been falling because everything is so green now lol.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Feb 24, 2013, 03:28 PM
chktm is offline
Joined Jul 2012
Definitely had some rain, everything is looking green and alive again . Helps the track stay together also. Looks better a bit of green in the vids instead of dry dead grass lol.
Old Feb 24, 2013, 04:53 PM
iflybyu is offline
Find More Posts by iflybyu
Joined Jan 2013
TJ, What is the thread on the shock shaft? I an going to do up a shock end like yours and don't have any metric dies to test for correct tap use.
iflybyu is offline Find More Posts by iflybyu
Old Feb 24, 2013, 06:35 PM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Cool, It is an M4 mate.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Feb 24, 2013, 06:38 PM
Sydney, Australia
Joined Mar 2010
Yeah mate too much, i wish it would go away it is interfering with my rc time.
Old Feb 24, 2013, 06:54 PM
iflybyu is offline
Joined Jan 2013
Thanks a lot. I will post pics when done.
Old Feb 25, 2013, 12:31 AM
chktm is offline
Joined Jul 2012
Pulled out the big bike again for a quick squirt. Nothing flash.
KTM 250 short squirt (4 min 30 sec)
Old Feb 25, 2013, 06:58 AM
UFRC is offline
Find More Posts by UFRC
UFRC's Avatar
Australia, SA, Adelaide
Joined May 2011
UFRC is offline Find More Posts by UFRC
Old Feb 25, 2013, 07:16 AM
Sydney, Australia
Joined Mar 2010
http://youtu.be/wNGdAcEOM0g
Nice mate, that bike is awesome & i can't believe how stable that camera is.
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
