Australia, QLD, Burua
Joined Jul 2012
This is how i make my upper shock mounts, it is 7 x 7mm square alloy cut to size & round the corners so it fits up in there nice & mark the holes & drill them & screw it in with a screw washer & nut through the chassis & the other screw just screws into the chassis using counter sunk heads, you will loose 3 adjusting holes but with the big bore i don't think you will need them, i am still running my broken chassis i fixed with these & have had a couple of good endo's & nothing has broke yet i am going to hit some jumps soon to really put it to the test.
Puerto Rico, Guayama, Guayama
Joined Jun 2006
I've ordered a 1mm carbon board to reinforce the area. I'll two plates similar to the flat area the shock holes are, and will glue one plate on each side. I believe this should reinforce the area. What do you think? David |
Joined Jun 2006
running like that. I'm wondering why your bike pitches up. Mine pitches down on the small ramp even applying throttle much like you. Could it be the depth of the parabola or what it's behind the Tx ?David |
Joined Jul 2012
Could be the bike setup possibly? I've been jumping all my life and on flat landings try and land rear first. I only would just blip the throttle on that little jump I'm sure. Pretty boring though David. That was the only time I've used that small ramp. The big one is spot on.
Ok, finally pulling the trigger on a brand new MM450... I want to pick up everything I need for this right away... I have a deal on the upgrade 5000mah venom battery already... Two batteries should hold me for now... I want to pick up all the alleven and venom alloy parts in one swoop... Also the front disc brake kit... Ktm body, front axle upgrade,what else guys???
what weight oils do I need for both front and back??? I noticed there is an alloy gear support for the vmx, does it even fit on the mm450??? Am I missing anything else??? Thanks all!!!
| Thread Tools | |
| Discussion Nitro ARX with e-gyro conversion first test run | Throttlejunkie | Motorcycles | 55 | Aug 16, 2012 12:35 AM |
| Sold E-flite G210 mems Gyro | rodneybarrett | Aircraft - Electric - Helis (FS/W) | 3 | Jun 26, 2012 10:04 PM |
| Sold E-flite G110 gyros | rodneybarrett | Aircraft - Electric - Helis (FS/W) | 2 | Jun 24, 2012 05:29 PM |
| For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) | mictopwin | Aircraft - Electric - Batteries & Chargers (FS/W) | 8 | May 09, 2011 01:47 PM |
| Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped | AllBread | Aircraft - Electric - Helis (FS/W) | 6 | Apr 19, 2009 09:23 PM |
