Old Feb 04, 2013, 11:56 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Originally Posted by davehour View Post
So with the hardened steel one that shouldn't be a problem, right?
With the design of the MM the layshaft can be removed with the sprocket still attached so if needed it can be stud locked onto the shaft itself as heat can be used to remove it later. Looking at the M5 sprocket I have here it will be much much later.
Gaz-b is offline Find More Posts by Gaz-b
Old Feb 04, 2013, 12:15 PM
JohnnyMc is online now
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Speaking of the front sprocket of the DX450/M5, I have that bike but didnt look at it last night. I was under impression the chain is smaller than whats used on the MM450. If so, how is it that a sprocket for a smaller chain can be correct size for the bigger mm450 chain?
Hi guys,
I'm debating whether to buy or not the metal triple clamps for the bike. My thoughts are the stock plastic ones have some give that protect the front parts and bearings from getting bent or damaged, while the metal won't protect as much. The metal triple clamps can even get bent too.
What do you think?
David
I just upgraded to the metal triples and that is a concern too. I hope its not an issue. However, Ive had the stearing stem bend and the plastic part that the stem fits into that mounts to frame break, so those seem to give out enough so forks dont damage so I am hoping that continues to be how things go in a crash, not the forks or triples. Time will tell. I wish I was good enough to tell difference in ride between plastic or metal triples. Maybe CHKTM can though.
JohnnyMc is online now Find More Posts by JohnnyMc
Old Feb 04, 2013, 02:59 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
[QUOTE=JohnnyMc;24031302]Speaking of the front sprocket of the DX450/M5, I have that bike but didnt look at it last night. I was under impression the chain is smaller than whats used on the MM450. If so, how is it that a sprocket for a smaller chain can be correct size for the bigger mm450 chain?
QUOTE]
The M5 chain is smaller well shorter anyway less links same pitch.
Old Feb 04, 2013, 03:57 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Hi guys,
What do you think?
David
David I find the alloy triple tighten the front up a bit and help the forks to work better. I have crashed the bike badly and broken bits around the forks such as the steering stem block and even the main chassis and the front rim and haven't even bent the steering screw. I think it holds the forks much better. You'd never bend the triples themselves I'm sure Dave.
chktm is offline Find More Posts by chktm
Old Feb 04, 2013, 03:58 PM
chktm is offline
Joined Jul 2012
Originally Posted by Gaz-b View Post
For anybody interested the Anderson m5 hardened steel sprocket is a perfect match for the original VMX brass one ANM59318
Thanks Gaz, looks the goods .
Old Feb 04, 2013, 04:15 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
The M5 chain is lighter duty I have checked the roller diameter and pitch on a digital vernier and it's an exact match to the venom/Atomic chain.
Old Feb 04, 2013, 04:36 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Do I posted a pic of a TT Ducati sprocket by mistake this is the M5 one
Old Feb 04, 2013, 10:19 PM
cwazyduck is offline
Find More Posts by cwazyduck
Lloydminster AB
Joined Dec 2010
Searching for connecting links a while back, I found out that the VMX/MM450 chain is an ANSI #25H as opposed to the standard ANSI #25 which is the same pitch but looks thinner, used on some other bikes. Most pocket bikes use a #25H, so as far as the MM goes, the chain is really overkill, now to start looking for a new sprocket that could be sourced from another application.
cwazyduck is offline Find More Posts by cwazyduck
Old Feb 05, 2013, 02:19 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
The chain on the TT Ducati is deffo the same as I have used the connecting link from one on my VMX.
Old Feb 05, 2013, 05:08 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Thanks John and Chris for your opinions. I'll buy them.
David
davehour is offline Find More Posts by davehour
Old Feb 05, 2013, 12:22 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
My two new sprockets arrived today and they have changed the pattern slightly but still drop right in. The one with the red spacer has had four packs and the other brass one has had two packs. The spacer is no longer needed as the built in one is the correct length. I dremeled a flat onto the shaft at 15mm from the end so there is a radius rather than a filed flat as the square edges would create a stress point. I fitted it with a little stud lock on the shaft and used nut lock on the screw with a bearing and clip on for spacing then remove the bearing asap or the stud lock will want to keep it. I tested the new sprocket with a file and it didn't touch it.
Old Feb 05, 2013, 03:21 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Gaz,
From the pictures it seems the radius of the steel sprocket is smaller hence the chain bushings won't rest on it, possibly?
Old Feb 05, 2013, 03:32 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
it is the correct pitch for the vmx chain the brass sprockets are sh@ged.
Old Feb 06, 2013, 02:12 PM
razor_01 is offline
Find More Posts by razor_01
razor_01's Avatar
United States, IN, Columbus
Joined Nov 2012
Originally Posted by Throttlejunkie View Post
Redstar sell the tenshock 5200 cheaper on ebay mate http://www.ebay.com.au/itm/Tenshock-...item2578767dd8
They recommend to run a 120amp esc with it, i am using a hobbyking 100amp sensored or sensorless esc as i had it already & it works great barely gets warm & it is smaller than the venom esc.
Do you use the punch control setting on this ESC? If so does it help any?
Sorry I see that it is a hobby king and not a turnigy esc.
razor_01 is offline Find More Posts by razor_01
Old Feb 06, 2013, 04:21 PM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Yes mate it is a hobbyking but is fully programmable with card, the initial acceleration is the punch setting i only have it set on MED which is plenty for this motor with so much torque & it is hard enough keeping the front down with the MED setting.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
