Old Feb 02, 2013, 11:15 PM
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Originally Posted by Jimob23 View Post
If I am correct that cross brace appears to be fabricated alum
Despite from being a nice bit of work can you expand on why you changed from the original plastic moulding
Thanks Jim
Cheers mate, i only replaced it because one of the threads for the crash bar mount was stripped & i like making bits for it where i can, it would be great to have a CNC machine instead of having to make them by hand.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Feb 03, 2013, 12:59 AM
United Kingdom, England, Ware
Joined Aug 2012
[FONT="Comic Sans MS"]All clarified now thanks[/
Had the same happen but just tapped out the next size up and then made up a tapped bush to bring it back to size
Lazy perhaps describes it FONT]
Good excuse to get a small one and start making alloy swing arms but then think how bored you would get after putting in the disk and it is all done for you
Will be following your experience with the beefed up shock mount
Chers Jim
Jimob23 is offline Find More Posts by Jimob23
Old Feb 03, 2013, 06:09 AM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I know how fulfilling making alloy parts is but on the more detailed and complex parts the plastic used on these bikes is very good and takes a helicoil well.
Gaz-b is offline Find More Posts by Gaz-b
Old Feb 03, 2013, 09:49 AM
razor_01's Avatar
United States, IN, Columbus
Joined Nov 2012
Here is a link for Fast Eddie Bearings to get a 15% off on your order. I recieved my order fast and the site is very user friendly.
http://fasteddybearings.refr.cc/PMG4899
razor_01 is offline Find More Posts by razor_01
Old Feb 03, 2013, 10:25 AM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
It would seem that the carbon sheet is not suitable so I am now using 3MM Lexan sheet. I will get some pc paint Tomoz.
Old Feb 03, 2013, 11:16 AM
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Gaz,
I think you now hit the nail in the head. Lexan is the perfect choice for that!
David
davehour is offline Find More Posts by davehour
Old Feb 03, 2013, 02:40 PM
Wrestling a pregnant albatross
wannabe's Avatar
Joined Oct 2003
Fixed should be a lot stronger now i just have to mark & drill the rest of the adjusting holes but 2 will do for now & when i do get another chassis i can fit these to it as well.
Well done!
wannabe is offline Find More Posts by wannabe
Old Feb 03, 2013, 03:37 PM
Sydney, Australia
Joined Mar 2010
Originally Posted by wannabe View Post
Well done!
Cheers mate.
Old Feb 03, 2013, 05:45 PM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Originally Posted by Runner11 View Post
Anybody using a metal front sprocket? BTW this is my first post here.
For anybody interested the Anderson m5 hardened steel sprocket is a perfect match for the original VMX brass one ANM59318
Old Feb 04, 2013, 09:09 AM
Joined Jun 2006
To make it all clear for you folks, the sprocket being recommended won't fit the later VMX's and the new MM450 because they use a newer sprocket which is pinned.
David
Old Feb 04, 2013, 09:36 AM
Joined Jun 2006
Hi guys,
I'm debating whether to buy or not the metal triple clamps for the bike. My thoughts are the stock plastic ones have some give that protect the front parts and bearings from getting bent or damaged, while the metal won't protect as much. The metal triple clamps can even get bent too.
What do you think?
David
Old Feb 04, 2013, 10:21 AM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
David
Unless you have a file and are prepared to use it.
Old Feb 04, 2013, 10:24 AM
Joined Jun 2006
Maybe I should take a course
I wonder why they changed the original design, Did it has issues?. Do you know why?
David
Old Feb 04, 2013, 10:52 AM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
David
the M4 screw into brass was a pain to lock up tight enough
Old Feb 04, 2013, 11:01 AM
Joined Jun 2006
So with the hardened steel one that shouldn't be a problem, right?
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
