Old Feb 01, 2013, 03:56 PM
Wrestling a pregnant albatross
wannabe's Avatar
Joined Oct 2003
Originally Posted by JohnnyMc View Post
For the top mount, maybe if you made 2 thin alum side plates that match mounting holes that would fit on each side. You would add 2 extra screws and nuts, front and back of the shock mount, plus the one thru the shock eye.
Yep, that's what I would do. Plus, I would put spacers in the slots with the extra screws so you dont over-clamp them. That would spread the load over the entire area and not just a single hole.
@ThrottleJunkie, I would not be too concerned about the stregnth of these things. I find the GRP or ABS or whatever the plastic is on these bikes to be stronger than I expected, and at least as strong as your typical Traxxas or Losi truck plastic. Replacements are cheap too.
I would love to see more aluminum frame parts made but that would just make the plastic parts break faster. Unless you could replace every single part of the bike with aluminum, that would be awesome.....
wannabe is offline Find More Posts by wannabe
Old Feb 01, 2013, 03:58 PM
wannabe's Avatar
Joined Oct 2003
Looking around locally and nobody had chktm's suggested BEL RAY Super Clean Chain Lube, so I will need to shop online. Browsing the internet I ran into another product that Im seeing nothing but good reviews from bikers for and a little cheaper: DuPont Teflon Chain-Saver Lubricant.
Anyone heard of it? What about using on bearings? I might have to try it out.
You can get Bel Ray at Cyclegear. There's one in Oxnard....
Old Feb 01, 2013, 04:21 PM
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Thanks, but Im 2hrs north of Oxnard. Local Yamaha and Auto stores didnt carry it so I tried at least but online is option I'm taking now.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Feb 01, 2013, 05:34 PM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I went for this lube seems good so far.
http://www.ebay.co.uk/itm/3008159553...84.m1439.l2649
Gaz-b is offline Find More Posts by Gaz-b
Old Feb 01, 2013, 05:45 PM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
This talk of chain lubes has made me wonder if the lube could be contributing to TJ's frame break. The wrong lubes will affect the plasticisers in the frame material. Mineral lubes and plastics really don't mix.
Old Feb 01, 2013, 06:00 PM
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by davehour View Post
Received the Atomik Nylon upgrade: It's really a downgrade. Ordering some 1/4" nylon bars...http://www.mcmaster.com/#standard-ny...6-rods/=ladm6s
Chris, I received the 1.2 pistons and filled the spare big bore shock with AE 70. Damping is somewhat similar (I'll be able to tell more after I remove the one from the bike) I'll swap shocks and see how there handling compare. The shock I have in the bike has 1.3 pistons with an unknown mixture of AE80 and Ofna 5,000. I also bought a bottle of AE 2,000 CST and AE 3,000 CST to compare them to the unknown mixture I'm using in the bike, and have an idea of its actual CST value.
David
David
Cool David, I have yet to test the 1.3 3000wt but will do that soon.
chktm is offline Find More Posts by chktm
Old Feb 01, 2013, 06:09 PM
Joined Jul 2012
That's the sort of lube I use also Gaz. It's a wax type film that is supposed to not attract dirt. I can't see TJs failure being related to chain lube sorry Gaz.
Old Feb 01, 2013, 06:11 PM
Joined Jul 2012
John there is plenty of other brands that make a dry wax spray on type lube. I'm sure you'll find one. David had some choices online I think. Maybe he can help?
Old Feb 01, 2013, 06:30 PM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I used to work in a hobby shop and remember a car being brought back with broken suspension the guy was arguing that the WD40 he had oiled and cleaned it with was not an issue the car was getting lower on the counter without being touched as it was cracking and breaking. I knew what he had used as I could smell it.
Old Feb 01, 2013, 07:08 PM
Joined Jul 2012
Must have been a cheap sh$@&@ car as Losi and AE recommend cleaning their plastic bits with WD 40 lol.
Old Feb 01, 2013, 08:02 PM
Post Falls, ID United States
Joined Feb 2004
Any petroleum or solvent based lubes can weaken plastic parts so use silicone lubes instead.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Feb 02, 2013, 02:44 AM
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Thanks Chris. Triflow is also a very useful line of Teflon lubes some that are dry great for exposed gears. .
Old Feb 02, 2013, 07:12 PM
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Fixed should be a lot stronger now i just have to mark & drill the rest of the adjusting holes but 2 will do for now & when i do get another chassis i can fit these to it as well.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Feb 02, 2013, 08:45 PM
Joined Jul 2012
Nice .
Old Feb 02, 2013, 10:25 PM
United Kingdom, England, Ware
Joined Aug 2012
If I am correct that cross brace appears to be fabricated alum
Despite from being a nice bit of work can you expand on why you changed from the original plastic moulding
Thanks Jim
Jimob23 is offline Find More Posts by Jimob23
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
