Old Jan 28, 2013, 05:51 AM
chktm is online now
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by Teamsherman View Post
Hey TJ, are they stock motors with what size pinions??
Also, there won't be any aerial filming any time soon as my quadcopter took on a mind of its own and went flat stick into a shed from about 50m away. It will be on the bench for a while now as I can't afford to fix it just yet. ����
Dam that sucks Alan .
chktm is online now Find More Posts by chktm
Old Jan 28, 2013, 05:57 AM
chktm is online now
Joined Jul 2012
Originally Posted by Gaz-b View Post
WARNING those of you from hot dusty climates should probably look away. http://www.youtube.com/watch?v=W5Ms5...ature=youtu.be
I can see why you need to make your bike submersible Gaz. The bike just stopped dead at the end lol .
Old Jan 28, 2013, 06:12 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Originally Posted by Throttlejunkie View Post
Some footage from the other day of me & my mate testing our new 5800mah 40-80C lipo's they gave the bikes more punch & good run time.
Vinnie's day did not go well after 5mins running he pulled the screw out of his butt & started playing havoc in the handling department, then he got knocked out & near ripped his hand off in an endo so while he was off to the hospital i did some close up footage of my mates bike.
http://www.youtube.com/watch?v=cQAJcEGubiE
As Chris said, the bikes is handling great. Are you still using that 3,000/1.3 pistons setup?
What oil are you using in the forks and in the steering shock?
Thanks.
David
davehour is offline Find More Posts by davehour
Old Jan 28, 2013, 07:21 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Well if you watch this vid of a 1/5 race here in the uk you can see why I was surprised at the lack of wet weather capability on a dirt bike.
BRCA 1/5 RC bike race 1/7/07 Mendip. (3 min 32 sec)
Gaz-b is offline Find More Posts by Gaz-b
Old Jan 28, 2013, 12:24 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Vinnie is getting pretty beat up lately. lol. Anyways, TJ awesome job on the camera work. Just watching the bike come in close on the little bumps and suspension working and roost flying up is so cool! Great job. Oh yeah, looks like the mm450 went with nylon what diameter did he go with? You need to do that camera work more often now because it looks so good to not have it in haha.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Jan 28, 2013, 12:52 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Yeah, suspension is working great. I stopped the videos at some frames and it was nice to see the suspension compressed.
Old Jan 28, 2013, 01:17 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Hi guys,
I did some maintenance and found the Rx box dusty. I used 1mm mounting tape to add some barrier to minimize dust entrance. I also added mounting tape on the interior of the Rx box to damp vibrations from the Rx. Vibrations are hard in the bike and they can make the Rx fail over time. I had to do the cap that way because I ran out of tape .
In the inspection, I also discovered the right rear wheel bearing inner and outer races rotating on the gyro stator shaft and wheel housing respectively, when the gyro is running, even with the bike tire on the floor. I'll apply CA between the bearing and wheel housing to stop at least that rotation. I applied force to the wheel and the inner race of the bearing still rotates. This is no good as this will damage the stator shaft so I'll have to apply a bit of loctite to stop that rotation.
David
Old Jan 28, 2013, 03:26 PM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Awesome stuff Chris. That bike looks to be working very nicely and your mates driving is coming around . Poor Vinnie lol.
Cheers mate the bikes are handling great i think the extra weight of the battery has helped my mates bikes suspension work better, he is getting better i think he needs to do more laps by himself so he can concentrate on the track & not racing me.
You have to give it to Vinnie though, even in an endo he is throwing heel clickers lol & i am not sure whether Deegan was trying to push the bike off him or trying to squash him some more.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Jan 28, 2013, 03:27 PM
chktm is online now
Joined Jul 2012
http://www.youtube.com/watch?v=-OyRPO79F_s
There came a point where I thought I might need a boat for my track lol.
http://www.rcgroups.com/forums/newat...anageattach&p=
Old Jan 28, 2013, 03:30 PM
Sydney, Australia
Joined Mar 2010
That sucks about your copter i take it they don't crash well, you will have to get your mate & his one, i hope you did not have your camera on it when it crashed.
My mates MM is stock 4200 with a 12t pinion mine is a tenshock 5200 12t pinion.
Old Jan 28, 2013, 03:32 PM
Sydney, Australia
Joined Mar 2010
Thanks.
David
Hi David, yes i am still using the 3,000/1.3 set up & hpi 30weight in both forks & steering damper.
Old Jan 28, 2013, 03:58 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Ok, thanks TJ.
Regarding the problem I reported previously about the right rear wheel bearing, I took off the rear wheel and found the bearing had loctite already applied from factory. There's a big gap between the stator shaft and the bearing so that's why they used it. I applied medium strength loctite externally to at least stop the race from rotating on the shaft. After I applied the loctite, I rotated-slipped the bearing inner race to distribute the it on the shaft until I have time to disassemble the gyro to see if I can use bearing retaining compound which is the correct stuff to use but hard to remove. I have to make sure I'll be able to remove the bearing if I use bearing retaining compound.
David
Old Jan 28, 2013, 04:04 PM
Sydney, Australia
Joined Mar 2010
Yes mate Vinnie is starting to feel his age he had to have 2 hand transplants after the crash , Vinnie does not know yet that i have a new young Deegan coming.
I wish i hand 4 hands so i could do more camera work as i do enjoy using it & i love the slow mo close up stuff, an auto zooming camera is what we need
The nylon is 6mm mate same as me, everything i do to mine i have to do the same to his.
Old Jan 28, 2013, 05:43 PM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Hi guys,
David
Look up the spec on Loctite 660
Is a repair product and have used it to retain full size bearings that have locked and turned in the housings
Have used it on the small front wheel bearings with no problem and took up the gap
Has got a filler to bulk it up so better than retainer green
Has a longer cure time so easier to get every thing back and all lined up correctly
Removal is the normal applied heat where I have found a big soldering iron direct to the bearing is better than a hot air blower or flame as for full size bearings
Any Loctite product on non metal housings like the cover one they suggest a quick spray of 7649 activator first
Cheers Jim
Jimob23 is offline Find More Posts by Jimob23
Old Jan 28, 2013, 05:44 PM
chktm is online now
Joined Jul 2012
Just slightly wet lol.
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
