Old Jan 24, 2013, 03:40 PM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Originally Posted by Gaz-b View Post
The metal on ceramics tends to be stainless and I have only used them on the flywheel not the road wheels. On the road wheels I have used SS 2rs bearings and fitted them with flowable silicone sealant including the cable entry. I keep upgrading bits I fitted a high torque HV brake servo today and now had to find an alterative to the cable outer as it was collapsing and concertinaring .
Understood and hopefully any impact will be taken by the two outer bearings .
i presume the outer bearings were standard steel ball with either metal shields or rubber seals .
I looked at ceramic but lost interest after the impact possibility and also was unable to find a pricing for the 21 x 12 x 5 mm .Plenty for skate boards and cycle gears so would be interested to know where you sourced and pricing .
Also interested regarding the make and torque of your replacement brake servo .
Ive got a brake kit with no servo to fit to another Venom I'm rebuilding from a real mess
All the ones I have seen so far to fit into the space available have been less than 3kg torque
Regarding the outer I found that normal antenna tubing did the trick and use PTFE coated stainless fishing trace as the inner .
Slip one of the small brass crimp ferrules over the trace where it is fixed by the grub screw to avoid it cutting into the trace and also round off the sharp points from the end of the screw
I see location is Norfolk where I have friends in the Walcott area just down from the Bacton gas terminal
Nice open beaches there with virtually no dog walkers etc so when visiting nice for playing with the bike undistubed
Cheers Jim
Jimob23 is offline Find More Posts by Jimob23
Old Jan 24, 2013, 03:58 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by Jimob23 View Post
Understood and hopefully any impact will be taken by the two outer bearings .........
Cheers Jim
The vertical load on the gyro bearing is isolated from the outer axle bearings so the outer bearings can not take any of the vertical load on the gyro.
I have ceramics on the gyro only. We will see if they hold out. I balanced the flywheel but it is still noisier than I think it should be, even with the top-shelf bearings. I believe it is the slop in the races.
wannabe is offline Find More Posts by wannabe
Old Jan 24, 2013, 04:25 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
http://www.ebay.co.uk/itm/3208578544...84.m1439.l2649
http://www.hobbyking.com/hobbyking/s...dProduct=29348
I have taken the red wire directly to the battery positive on the esc.
the bearing on the road wheels are stainless steel rubber sealed.
Gaz-b is offline Find More Posts by Gaz-b
Old Jan 24, 2013, 04:27 PM
JohnnyMc is online now
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Hope Chris Nicastro doesnt mind me quoting him from the rc dirt bike action facebook page, but it was regarding balancing the flywheel and a comment I made about the noisey bearings:
Stay away from ceramic bearings in this application. A higher tolerance or tighter bearing will help but if the flywheel pockets are made poorly it wont help. You will ruin the bearings eventually.
JohnnyMc is online now Find More Posts by JohnnyMc
Old Jan 24, 2013, 05:00 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
I use std bearings cleaned and lubed with a good quality tacky bearing lube. I've replaced my originals and am on my second set in my two well used bikes and in my good one have originals. Those two bikes have had countless hours put on them in the last 5 months or so. At $14 for 4 bearings I know which way I'm going. They run much more quietly when cleaned and lubed and last fine. I've never seized one I just replace them when they get too sloppy.
chktm is offline Find More Posts by chktm
Old Jan 24, 2013, 05:26 PM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Hi,
I know some are using car antenna tube for the brake cable outer tube but the ones I find are too stiff for the job, and will interfere with the steering. Is there a softer one to use?
David
davehour is offline Find More Posts by davehour
Old Jan 24, 2013, 05:37 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
Originally Posted by davehour View Post
Hi,
David
Du-Bro micro pushrod tubes might be good..... In fact, you might be able to use the actual micro pushrod wire for the brake instead of the cable.
Old Jan 24, 2013, 06:09 PM
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Newbee question on bearings, I was looking around and some say they are "6801-2rs" and some are "6801-2TS" Bearings. Whats the difference?
Old Jan 24, 2013, 06:21 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Hmm, looks very interesting. Thanks for the advice.
David
Old Jan 24, 2013, 06:34 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
RS Rubber seals. TS Teflon seals. Teflon I would assume can cope with higher temps and is probably food safe.
Old Jan 24, 2013, 06:54 PM
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Well I've been talking to some nice guys over at RCLargeScale.com and then Ed from FastEddyBearings was like, hey I'll make a bearing kit for the bike. So as Im asking about bearings here, today of all days, I see this pop up...
http://www.fasteddybearings.com/atom...e-bearing-kit/
Old Jan 24, 2013, 07:11 PM
Jimob23 is offline
Joined Aug 2012
Who knows a sample pack may be winging its way to you right now
Old Jan 24, 2013, 07:19 PM
Jimob23 is offline
Joined Aug 2012
Agree. 100%
Even if they do seize the clearances are not that close to lock anything up so will just make a ghastly noise
Not like you are doing the 1/4 mile on full boost and max nitro
Old Jan 24, 2013, 07:56 PM
chktm is offline
Joined Jul 2012
That is great value John. Good find.
Old Jan 24, 2013, 09:56 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
I dont mind,
The bearings are either going to work or fail. They dont last very long inbetween. At around 11K RPM and 9lbs of force or more in an instant ceramic bearings will not last long. I have had low grade steel bearings shatter so spend some money on good bearings but dont go nuts. Again bearings are not noisy its the pockets in the flywheel and balance of the wheel. When bearings are noisy its because they are very worn out and nearly broken. If you try a CA bushing trick or teflon tape you can tighten up the pocket tolerance temporarily.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
