Old Jan 23, 2013, 01:21 AM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Sweet, ive also got 6 lipos for mine that i havent even broken in yet!!! Are you free any weekdays or will just weekends be the go?[/QUOTE]
Weekday's or weekends anytime is good mate, i work from home & am only 5mins from the park.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Jan 23, 2013, 01:56 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Awesome!
I've got shedloads of time considering I'm on permanent sick leave as I'm being medically discharged from the Army after 17 years.
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 23, 2013, 05:44 AM
Sydney, Australia
Joined Mar 2010
Originally Posted by Teamsherman View Post
Awesome!
Ok cool, check with your mate to see when he is free & we will work out a day, will be good fun having 3 bikes running my bro inlaw is getting one soon as well.
Old Jan 23, 2013, 07:03 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
Hi all,
Ordered two of these Razor ramps. I'll join them side to side to make a wider one. These will probably let me practice backflips without going crazy high. I'll be able to control jump altitude with the speed of the bike. I think I can work them out so I can attach the bike and Tx on the underside and make a slot as a handle so they serve as a carrying case. Total width using both is about 24" (610mm).
Here is the link:
http://www.zappos.com/razor-punk-ramp-one-color#prdInfo
What do you think guys?
David
davehour is offline Find More Posts by davehour
Old Jan 23, 2013, 08:28 AM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by davehour View Post
Hi all,
Here is the link:
David
Yep! Pat brings six of those ramps out for us to play on. They seem to have the perfect parabola shape for these little bikes.
wannabe is offline Find More Posts by wannabe
Old Jan 23, 2013, 08:48 AM
TopDave is offline
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Hi all,
Here is the link:
David
Jump as high as you need to, but have a correspondingly high landing ramp or platform to ease the landing impact:
00119 Edit Atomic RC MM450 MY BASEMENT MOTOCROSS (2 min 49 sec)
TopDave is offline Find More Posts by TopDave
Old Jan 23, 2013, 09:11 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Great, thanks!
Are you able to do backflips with it?
How high you can go with them?
David
Old Jan 23, 2013, 09:13 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
http://www.youtube.com/watch?v=v6uyLgSyZ4Y
Yes, that would be the correct way. The only problem I see is to have a ramp big enough to spottily land when doing big airs.
David
Old Jan 23, 2013, 02:25 PM
Runner11 is offline
Find More Posts by Runner11
Runner11's Avatar
Joined Jan 2013
Anybody using a metal front sprocket? BTW this is my first post here.
Runner11 is offline Find More Posts by Runner11
Old Jan 23, 2013, 02:33 PM
TopDave is offline
TopDave's Avatar
Waterford, Michigan
Joined May 2006
David
Drive safely then lollol.
Old Jan 23, 2013, 02:37 PM
Gaz-b is online now
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
What is yours made from. ????
Gaz-b is online now Find More Posts by Gaz-b
Old Jan 23, 2013, 02:51 PM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Originally Posted by chktm View Post
David that sounds fairly std to me, not too bad. I think its more bearing noise than vibration. The bearings can be noisy, I spray mine clean of the grease with solvent and lube with a adhesive chain and bearing spray called Tac 2. It's really tacky great lube and makes them quieter and last tonnes longer.
Chris
I think you are 100% correct regarding the gyro noise
Have been doing a bit of work balancing the flywheel assisted by an aero mechanic who was able to dynanic balance but only to 10,000 RPM
To give Atomic some credit I think the basic steel section is pretty accurate .
The problem comes when attaching the magnet sections hence the some appear ok and others need attention
Fitted a set of SKF bearings and reduction in the rumbling sound was very noticable
Just need to be aware that with rubber seals the rated RPM is reduced to 20,000 compared to 30,000 for metal shields .Am told the friction heats up the rubber contact area ,hardens it and reduces the seal effect
Price is a big factor so perhaps replacing the Chinese sourced bearing on a regular basis is the way to go
Static balancing is essential to reduce as much vibration as possible since that is an arch enemy of any bearing regardless of place of manufacture
Disregarding of the price factor part ceramc bearings are fine for high RPM static applications but not the best for impact load situations experianced in jumping etc as the balls can shatter .
Fully ceramic are a non starter mainly due to pricing but also the outer ring is not designed to fit into an interferiance fit situation so can crack and again the impact load issue
cheers Jim
Jimob23 is offline Find More Posts by Jimob23
Old Jan 23, 2013, 03:19 PM
Member #1
Joined Aug 2011
Hi all,
Here is the link:
David
Hey David,
If it were me, I'd buy 3 of them using 2 for a down landing and one to launch off. First I'd measure roughly where the bike will land off the jump ramp and place the two down landing ramps close to that position so you can get some really cool scale type of jumps going!
Cheers!!!
Old Jan 23, 2013, 03:21 PM
Member #1
Joined Aug 2011
Hey dude, are you running knobbies in that video or motard tyres???
Old Jan 23, 2013, 03:38 PM
TopDave is offline
TopDave's Avatar
Waterford, Michigan
Joined May 2006
motards, I was shreading the knobby too fast!
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
