Old Jan 16, 2013, 02:57 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Originally Posted by Throttlejunkie View Post
Hi mate, we are riding in a place called Whalan Reserve it is in the western suburbs of Sydney, you would be more than welcome to come ride with us more the merrier, but it might be a bit of trip for you to get here though, i think you are pretty far south of here.
If that's the Whalan near Mt Druitt, then that's nothing for me, I drive further away to fly Rc planes so we'll have to organise a bash! I'll bring my quadcopter and gimbal and get some crazy aerial close up chase vids going!!!
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 16, 2013, 05:00 AM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Cool mate that would be awesome, other guy's used to fly planes down there they use the road as a runway because it is nice & smooth, i have to get some more lipo's so we can have a good run we only have one each at the moment i should be getting them next week though.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Jan 16, 2013, 05:52 AM
chktm is online now
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Sounds great guys, look forward to seeing the fun .
chktm is online now Find More Posts by chktm
Old Jan 16, 2013, 07:50 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Originally Posted by Rellik View Post
Is that price shipped? I can get anyone here RTR bikes for $380 shipped and ARR for $350 shipped. If anyone is interested PM me
Don't dismiss this offer.O did I say I have a 2nd bike on the way for me mates to race me with . Thanks again Rellik,
Gaz-b is offline Find More Posts by Gaz-b
Old Jan 16, 2013, 08:11 AM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Originally Posted by chktm View Post
Hi David I use between 30c and 40c batteries and they give me all the power I want. The vids are using these batteries.
Not wanting to stir up a hornets nest here but when running the 30/40c batteries have you had to change the conductor sizes as one would presume the original conductior size was selected to cater for the lower power available from say 20c
Also are the EC3 connectors rated high enough to carry the additional amperage ?
Thanks Jim
Jimob23 is offline Find More Posts by Jimob23
Old Jan 16, 2013, 11:21 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Thanks Jim
the conductors are fine for the current we draw. The higher c gives better voltage ie less sag at the current we draw. In fact for the same watts at higher volts we draw less amps.
Old Jan 16, 2013, 12:17 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
That is a good price..
I'm a little reluctant buying from someone without a store front and not to many posts. How about the Atomik guarantee?
GiantScale is offline Find More Posts by GiantScale
Old Jan 16, 2013, 12:23 PM
Jimob23 is offline
Joined Aug 2012
Understand the voltage drop situation and the need to keep the conductors as short a possible but a while back there was a discussion surrounding replacing the original 80a ESC with one rated at 120A hence the question surrounding the conductor size remaining the same
Cheers Jim
Old Jan 16, 2013, 01:46 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
I replied to you back on page 105 when you first asked. Try Venom's ebay store for the $350 ARR price http://stores.ebay.com/Factory-Direc...sub=5412299015
JohnnyMc is offline Find More Posts by JohnnyMc
Old Jan 16, 2013, 07:03 PM
chktm is online now
Joined Jul 2012
Thanks Jim
The std EC3 connectors work fine Jim. I prefer them over Deans but each to their own.
Old Jan 16, 2013, 07:06 PM
chktm is online now
Joined Jul 2012
Cheers Jim
I use a 120 amp ESC with a Tenshock 5200kv motor in one bike. In others I use the 80amp Venom one using either the 4800kv or 4200kv Atomik motors.
Old Jan 16, 2013, 09:50 PM
chktm is online now
Joined Jul 2012
I've been asked in a PM to do a video of the action and rebound of my rear shock set up so here it is David. If it helps anyone else good . There is no battery on board. I can do one with a battery but there's not much difference. It sits a fraction lower. Also take note of how the tyre doesn't bounce at all when it hits the ground. Do the same thing with a std insert and watch the slight bounce off the tyre insert.
Atomik MM450 Big Bore rear shock action (0 min 23 sec)
Old Jan 17, 2013, 01:28 AM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Lol, thanks Chris. Yea definitely give Vinnie the boot haha .
If you guys only knew how much time I spent developing the suspension just get it to RTR ready... You'd go nuts.
Finally I see people actually using all the geometry I built into the chassis. The more vertical the shock is the more stiff and direct the shock is in response to the swing arm. Laying it down reduces the spring rate a percentage per hole. This gives you a sort of in between rate and once you reach either end and need more, softer or harder spring, you know to change the spring and set the shock back to the center most position.
Try some different hard Revo springs if you want to test but I highly recommend the alloy shock for this work or some alloy shock that fits. The hard part will be finding hard enough springs because the bike operates at the highest end of whats available for truggies and buggies.
Take the test spring and compress it against the bike spring to see if its harder or softer than the stock spring. If the test spring has a spring rate spec then save this info to compare notes later. The test spring has to be as long or slightly longer than the stock spring so you have the range of preload you need.
Take the stock spring and the test spring and compress them on a scale to see how many pounds per inch it takes to compress them. Thats your rate. Each production batch may be slightly different. Save your notes and play around with springs and oils plus pistons. Keep in mind the internal pressures will rise with thicker oils so use alloy shocks not plastic. Also go to one hole on the piston with thick oil like 100wt. If you have to try thicker diff oils use 2 holes or open up the single hole. Hundreds of combos but precise observation for your situation will give you clues to make adjustments.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jan 17, 2013, 04:29 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
http://youtu.be/gzhithgJXTI
Chris,
Thanks so much for your video.
My mixture of Ofna 5000wt & 80AE went a little thick for the 1.3 pistons, though isn't that far from yours, specially in the drop test. In the compression and rebound by hand, your rises a little faster. Thanks again Chris. You're da man!
I know Ofna doesn't follow CST standard. I've ordered 1.2 pistons in order to use Chris's setup, but can also get a bottle of 3,000 differential oil and use it with the 1.3 pistons as TJ did.
The big bore shock looks amazing in the bike, and you can see the difference when the bike take bumps.
David
David
davehour is offline Find More Posts by davehour
Old Jan 17, 2013, 04:34 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Chris,
The bike rocks they way it's from the box! And the design is amazing. I'm having A LOT of fun with the bike; running it and working in it on the bench. Thank you very much for your hard work. You can feel more than proud as you have made a bunch of grown out kids very very happy .
At this moment, my only wish is if Venom releases other trims of the RTR bike, as it was done with the VMX.
David
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 10:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 05:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 01:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 09:23 PM
