Old Jan 15, 2013, 10:51 AM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Originally Posted by davehour View Post
LOL, yes they do. Actually, I use Gens Ace 25C 6S 3300mAh batteries in my 12S T-rex 600EFL Pro heli. And if you read reviews, pilots can't tell the difference between them and the Thunder's and the other high priced packs.
Now, lets talk about real life ratings. It's hard for me to think of those 65C. 5000mAh batteries delivering 325A continuous; yeah right. Use it that way. Won't last a dime.
From my experience with Lipos, using more C's than actually needed is no good. You have a battery with more weight, and this weight will fight back your gain in punch and duration, if any.
The real key in Lipo longevity is to not over discharge it, not over charge it, and store it at the proper potential and temperature. Remember, there is a self degrading chemical reaction in Lipos, even when they are sitting. Storing them at the wrong temp and potential just advances the inevitable deterioration.
David
The thing about the high C rated batteries is that they can give more current without the voltage dropping, like when you apply a burst of throttle. I personally cant tell the difference between a Thunderpower and a Skylipo of the same C rating, but I can definitely tell the difference between a 20C and a 65C battery (of any brand name) when giving a model (boat, plane, heli, car, motorcycle, quad rototr, etc.) the "throttle punch" test.
wannabe is offline Find More Posts by wannabe
Old Jan 15, 2013, 11:04 AM
davehour is offline
Find More Posts by davehour
davehour's Avatar
Puerto Rico, Guayama, Guayama
Joined Jun 2006
That's correct, but in the case one have what's needed, going higher won't help that much.
I've read many saying they can't feel the difference between a Gens Ace 25C vs other brand 65C, at least in 3D helis. Another thing to consider is True C rating. Many brands over rate their batteries while others underrate them; hence the non existent difference in some batteries with different C ratings.
For big difference in C ratings between some batteries, you can tell, but I don't think the difference will be that much between a good 40C and 65C battery. Or besides the punch, what else can you get? Speed:? Better handling? What about jumps, where weight is multiplied by the G's produced; then, you get almost 1kg more of dynamic weight at that moment. Again, going high C's also increase weight, and the little punch obtained is shadowed by the handling issues due to the weight increase.
What it's important is to use the practical C rating for an application. Going way more than what's needed is useless IMHO. But manufacturers know going high C's means more sales for people looking just the highest C's.
David
davehour is offline Find More Posts by davehour
Old Jan 15, 2013, 11:17 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Taking for example my MM450 and the stock 3200 20C battery, it has plenty of punch and I'm not missing any of it. I believe 5000 20C would be sufficient, but there's also practical experience and the fact a higher C will last longer if a lower C is marginal for the application.
Old Jan 15, 2013, 11:20 AM
davehour is offline
davehour's Avatar
Joined Jun 2006
Originally Posted by Gaz-b View Post
Wow do they really still make cells under 40c.
Gazb,
I really doubt I'll use a 40C battery in my stock MM450 . The stock 20C gets barely warm running the bike hard on bitumen.
The stock battery has 34 cycles on it, and the IR (internal resistance) of the cells measures the same as when they were new: 3 mohms.
David
Old Jan 15, 2013, 12:06 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I go with higher c after testing different types of aircraft with data logging more c + more volts under load more volts + more watts .that's more power mate.
Gaz-b is offline Find More Posts by Gaz-b
Old Jan 15, 2013, 02:44 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
I have solved the issue of not having another bike to race against and to have two one for somebody else to drive.
Old Jan 15, 2013, 02:47 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
You are a good man to hang around!
However you need to use proper punctuation in your text.....
Old Jan 15, 2013, 03:00 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Higher C rates do not add any extra weight to a pack. You can combine higher C rates with any capacity pack to dial in an ideal power set up. Higher C rate with lower capacity means a light weight set up equal to a low C rate high capacity pack. The amp capacity under load can be the same but the set up weight will be different.
The point is for racing and having to run only a few minutes use a high C rate low capacity pack because you dont need the extra runtime or weight necessarily. You do want the highest voltage under load for competition.
For bashing around you want high capacity for more runtime and low to mid C rates. As long as you do the math (or read the label) you want to have a pack that covers 100-120A no matter what capacity and C rate combo.
The VMX/MM450 runs great on a cheap pack and really has punch with anything extra.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jan 15, 2013, 03:06 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Good info thanks Chris. Say, can I ask you a random question only you might know for the rear shock spring...I know nothing about springs, but do you have any info on its rating or strength so if we want to look at other brand springs we are not shopping in the dark? Glad you keep in touch around here. Hope your staying warm out there!
JohnnyMc is offline Find More Posts by JohnnyMc
Old Jan 15, 2013, 04:36 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by Teamsherman View Post
Nice vids mate!!
Is that your backyard or property mate? id love to have that bush surrounding my place!!!!
Thanks Alan. Yes that's the backyard. Room for a bit of fun lol .
chktm is offline Find More Posts by chktm
Old Jan 15, 2013, 04:38 PM
chktm is offline
Joined Jul 2012
Originally Posted by Throttlejunkie View Post
Cool mate, you look like you are enjoying a bit of a change from the dust, your silver rims look good.
Loving it thanks mate, be great all year round no dust. I like the look of the rims way better than black.
chktm is offline
Joined Jul 2012
Hey Chris,
Do you use a head cam to record the videos?
David
Hi David yes I use a camera on my head.
Old Jan 15, 2013, 04:42 PM
chktm is offline
Joined Jul 2012
David
Hi David I use between 30c and 40c batteries and they give me all the power I want. The vids are using these batteries.
Old Jan 15, 2013, 04:44 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
All in all, that's what I've discovered. The bike runs well even with the stock 3200 20C pack.
Old Jan 15, 2013, 04:46 PM
davehour is offline
davehour's Avatar
Joined Jun 2006
Great Chris. I'll then get the 25C one.
BTW, do you run the batteries down to cutoff, or stop at the 20% mark which is about 3.75V per cell?
Are the batteries with connectors fine for offroad use? I mean the ones that have their wires connected to the case by means of connectors.
Thanks you very much,
David
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 01:35 AM
Sold E-flite G210 mems Gyro rodneybarrett Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2012 11:04 PM
Sold E-flite G110 gyros rodneybarrett Aircraft - Electric - Helis (FS/W) 2 Jun 24, 2012 06:29 PM
For Sale 3-channel Micro IR S107 Metal HoneyBee Helicopter No.ES0107 (with Gyro) mictopwin Aircraft - Electric - Batteries & Chargers (FS/W) 8 May 09, 2011 02:47 PM
Sold Gaui hurricane 550 with metal head, servos, gyro, esc, and batteries. - $350 shipped AllBread Aircraft - Electric - Helis (FS/W) 6 Apr 19, 2009 10:23 PM
