Old Sep 25, 2012, 12:15 AM
awilmunder is offline
Find More Posts by awilmunder
Good for what ALES you
awilmunder's Avatar
United States, CA, Novato
Joined Jan 2009
I hadn't even considered the over-the-fence vs. through-the-fence aspect of this decision. I think there are solid arguments on both sides. We measure to the tip of the nose of the plane for distance, but 'inside the fence' can easily be interpreted as the entire aircraft, not just the nose.
I would like to say it wasn't my plane, but.... I took the photo because I thought it was a great example of a challenging call.
I'm off to Cal Valley for three days of cross-country flying this weekend, ALES in Visalia the following Friday, and two days of TD flying on Saturday and Sunday. What a great time of year!
awilmunder is offline Find More Posts by awilmunder
Old Sep 25, 2012, 08:43 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Well, of course if the fence wasn't there the plane would be within the boundary. But, the fence is a known obstacle/marker, so, in my opinion, if the CD said you must be inside the fence line then the picture shows it didn't make it.
Likely the next time the CD will spell out that particular detail. To me though, the nose poking through doesn't cut it. The fence prevented the plane from making it.
I've got the cross-country thing on my bucket list of soaring. I need to check that out. There just always seems to be a contest to fly or a plane to build or repair!
Have a great weekend doing X-country, and I will see you at the Fall Fest.
target is offline Find More Posts by target
Old Sep 25, 2012, 10:52 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I bet the folks at San Quentin would they are still on the wrong side.
If it were a wall it wouldn't be a question, if the fence wasn't there you'd have made it in. In the end how much of a difference would it have made?
Just my .02 cents worth.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Sep 25, 2012, 11:25 AM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
Originally Posted by awilmunder View Post
OK... How would you call this?
The contest rules as announced, all planes must land within the fenced area. In this case, the closer side of the fence was within the field boundaries.
At the CAMS-Polecat-Soaring Circuits 2K12 ALES Open Soar that flight would have been in bounds and would have received full flight points.
IBWALT is offline Find More Posts by IBWALT
Old Sep 25, 2012, 12:16 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
In our competitions (F3K) that's a no brainier as some part of the aircraft is in bounds so its considered in bounds but it would be a good question for the pilot's meeting as different disciplines have different ways if doing things.
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Sep 26, 2012, 01:51 PM
GotLift9369 is offline
Find More Posts by GotLift9369
GotLift9369's Avatar
United States, CA, Hesperia
Joined Mar 2009
It is always a difficult decision to zero a flight. We have a 3-minute countdown before launch which should be plenty of time for a quick motor check and even a fix if caught early. I have seen many pilots briefly throttle up their motor to make sure that they are ready to launch. Holding a launch is certainly an option, but reflights should be avoided since the goal of Man-on-Man is for everyone to fly in the same air, and I have seen plenty of circumstances where the flying conditions have completely changed from one flight group to the next.
This was probably an honest but unfortunate error on the part of the contestant. To rule other than the way you did however,would be a mistake on your part as some, not many, competetors would see your ruling as a way to get around one of the two main reasons for Man-On-Man...namely to force competitors to fly in specific groups. You cannot allow the competitors to choose who they will or will not fly against.
Rick
GotLift9369 is offline Find More Posts by GotLift9369
Old Sep 26, 2012, 01:55 PM
Joined Mar 2009
Originally Posted by GliderDriver45 View Post
I'm new to the CD role and had the following situation:
call to launch verify every one is ready.
Start the 10 sec launch window and one of the contestants motor will not start. All the other pilots are in the air, the 10 sec launch window expires then he discovers that his cam unit had become disconnected.
I gave him a zero for the round and did not permit a refilght.
Is this the correct desicion? or should he have been allowed to have a refilght?
If you give him a reflight do you call everyone else in to land and refly with the same flight group? Place him in the next flight group? or let him fly solo and compare his time to those in his orginal flight group?
This was probably an honest but unfortunate error on the part of the contestant. To rule other than the way you did however,would be a mistake on your part as some, not many, competetors would see your ruling as a way to get around one of the two main reasons for Man-On-Man...same air and namely to force competitors to fly in specific groups. You cannot allow the competitors to choose who they will or will not fly against.
Rick
Old Sep 26, 2012, 02:12 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Would the fact that no part of the plane is on the ground on the in-bounds side of the fence come into play? No part of that plane is on the ground in-bounds.
aeajr is offline Find More Posts by aeajr
Old Sep 26, 2012, 02:20 PM
knormang is offline
Find More Posts by knormang
Okanagan Falls. British columbia. Canada
Joined Nov 2006
Out of bounds
Quit playing at being lawyers!!! That model is out of bounds. Ken.
knormang is offline Find More Posts by knormang
Old Sep 26, 2012, 02:28 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thats what I would say too....
It wasn't like the fence was added as an obstacle after launch; it was there, the plane didn't make it inside the boundary because of the fence.
Thats the way it goes....Someone that cleared the fence should score higher than that plane did not clear the fence.
R,
Target
Old Sep 26, 2012, 02:35 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Hey, my plane is in a tree. If that tree had not been there I would have glided onto the field and been in-bounds.
Old Sep 26, 2012, 02:47 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
WOW! Sucks to be you.
jaizon is offline Find More Posts by jaizon
Old Sep 26, 2012, 03:26 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Exactly....
If the tree is out of bounds, so is your glider.
R,
Target
Old Sep 26, 2012, 03:55 PM
IBWALT is offline
W0X0F
IBWALT's Avatar
Joined Nov 2005
NO. The field boundary on the South side of the Carlisle AeroModlers field, where the Polecat is held, is a good example. The grass that marks the out of bounds line is cut higher than the grass on the field. I have seen this difference range from a few inches to a foot or more. Your plane could be resting on the taller grass that is out of bounds with the nose sticking out over the shorter grass that is in bounds and this would be counted as an in bounds landing. Any part of the plane in bounds scores flight points.
Old Sep 26, 2012, 04:04 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Aric-
What call did the CD make in this instance??
Just curious.
Clearly there are arguments for a call to be made either way....
Regardless, I'll bet the CD in the future calls that out BEFORE the contest next time.
R,
Target
Discussion If you had some extra Graupner 260s, what would you build? NeveSSL Foamies (Scratchbuilt) 2 May 06, 2012 09:00 PM
Discussion If you had an extra Fox .45, servos, receiver, etc., what would you put them in? NeveSSL Fuel Plane Talk 8 Apr 18, 2012 09:18 PM
Discussion What would you feel or do if you were in this situation? mediclavina Micro Helis 35 Oct 26, 2009 09:12 AM
Discussion What Would You Do If You Were In Charge Of Israel WhiteCloud Life, The Universe, and Politics 4 Jul 27, 2006 09:29 PM
Question If you are/were building smaller Irate 3s packs what do you suggest ScienceGuy Batteries and Chargers 11 Jan 17, 2004 11:00 AM
