Jul 17, 2001, 07:52 AM
N. Andover MA
Joined Sep 2000
Center of Gravity
I have an Ace Simple Series Me-109 with a speed 400 motor, 1.85:1GB, micro servos, standard Rx, and 8cell 600AEs (flat).
After the first couple of attempts to get it airborne, I noticed a tendency to tip stall to the left once I tried adding any control inputs.
The plans call for the CoG to be about 1" or so back from the leading edge at the root. I have only managed to have the actual CoG to be about 1.5" or so from the leading edge.
Would incorrect CoG (too far aft)make that big of a difference? I assume so. If that is the case, should I add weight to the nose, try changing the AoA of the wing (rubber band mounted), drop the thrust line of the motor down, what?
Should I try to move the CoG forward of the recommended spot?
Any advice would be greatly appreciated. By the way, thanks for reading this long winded post.
C.
