Old Jun 20, 2012, 07:47 AM
rcfocus is offline
Find More Posts by rcfocus
Joined Jun 2012
Question
Outrunner wont fit. Please help...
Hello everybody. I purchased an ST Model Piper J3 Cub and after getting it ready to fly it nosed over on takeoff and damaged the motor.
I read good reviews about the Emax CF2822 and so purchased one of those.
However i now notice that it wont be as easy to replace as i had hoped.
The original motor had three holes to attach in a triangle formation and the new CF2822 has four - which i think is the norm.
Please see the following pictures for a clearer explanation of my predicament...
Below we have the two motors, the new one on the left and original one on the right...
Here we have the nose of the J3, the white plastic screws onto the metal with the motor attached, however it wont fit my new motor
Pulling my hair out a little, as have spent much time looking for adaptors online but to no avail. Can anybody rescue me?
Thanks!
rcfocus is offline Find More Posts by rcfocus
Old Jun 20, 2012, 07:59 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Unscrew the set-screws on the new motor mount and remove it. Tape it to your plastic mount making sure it's centered, mark new holes and drill them using the plastic mount as a template.
The new mount is aluminum and should drill easily.
I would say remove the old motor backing and install it on the new motor, but I can't tell from the pictures if they're the same diameter, but it doesn't look like it, but you should be able to test it easily.
The other option is to drill out the stock backing so it's diameter matches the new motor, but that's not as easily done if you're not handy with a drill press and centering.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Jun 20, 2012, 08:15 AM
rcfocus is offline
Joined Jun 2012
Originally Posted by MassiveOverkill View Post
Unscrew the set-screws on the new motor mount and remove it. Tape it to your plastic mound making sure it's centered, mark new holes and drill them using the plastic mount as a template.
Thanks for the quick reply. I was hoping there would be an easier option, like an adaptor i could perhaps buy and use. However you're right, that would be the best way to go about making it fit, if nobody else can enlighten me i'll have a go with the drill. Thanks again
Old Jun 21, 2012, 05:51 AM
rcfocus is offline
Joined Jun 2012
Ok, i went down the "gaffer tape fixes everything" route
Motor seems very secure, the CF2822 really churns out some power too!
Old Jun 21, 2012, 05:54 AM
Joined Feb 2011
Glad you got it worked out
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Jun 21, 2012, 11:25 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Are you saying that you taped the motor to the plane?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jun 21, 2012, 05:14 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Sorry if this sounds negative but the suggestion of drilling new holes in the new motor mount to fit the white adapter is the best fix. If you don't have the capacity to drill the holes you might be in the wrong hobby.
Rickochet is offline Find More Posts by Rickochet
Old Jun 21, 2012, 05:22 PM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
The hobby involves equal parts skill with hand and electric tools, understanding of electricity and electronics, basic mechanical skills and flying ability.
cryhavoc38 is online now Find More Posts by cryhavoc38
Question prop wont fit adapter thebuckeye Electric Plane Talk 10 May 29, 2012 01:03 PM
Discussion GT Power B606 charger - balance connector wont fit in. AndyBright Batteries and Chargers 2 Mar 28, 2012 01:37 PM
Power fan 400 adaptor wont fit himax 2024-4200 help nuspeed88 Electric Ducted Fan Jet Talk 1 Jan 09, 2005 10:08 AM
plug wont fit back in mold!! chris higdon Composites Fabrication 2 Nov 12, 2004 06:38 AM
hs225 servos wont fit logo 10_ suggest servos? hawleaboy Electric Heli Talk 30 Feb 04, 2002 11:51 PM
