Old Jun 22, 2012, 12:25 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
But beware, it is still written in Evil Assembly!!
It's the only way
Steveis is offline Find More Posts by Steveis
Old Jun 22, 2012, 12:41 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by cryhavoc38 View Post
you get the sense that there is an entitlement within those words no?
Just order the dang thing.
Three days ago, I was perusing the HK web site and came across that board. thought it was pretty cool, but went on to other things and was going to come back to it.
Now they are all gone..grrr
So I signed up to be notified when they come back in stock.
For the money, this looks like a KILLER board for some low cost quad fun and even to experiment in a plank.
And you'll keep waiting since its going to take months to restock.
hefest is offline Find More Posts by hefest
Old Jun 22, 2012, 12:54 PM
BennettOZ84 is offline
Find More Posts by BennettOZ84
Swinger. Heli and planks!
BennettOZ84's Avatar
United States, OR, Foster
Joined Mar 2007
Originally Posted by jesolins View Post
Gents,
Here is a nice website by CrashingDutchman that collects and searches for HK buddy codes. Just type in KK2 in the seach window and you will see active HK buddy codes: http://hk.rc-international.info/SWARM
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Guess, I don't understand how the buddycode thing works. I click on the links from Crashing Dutchmans website and still shows the 29.99 price. Even if I do a checkout still says the normal price. Is it because its back ordered?
BennettOZ84 is offline Find More Posts by BennettOZ84
Old Jun 22, 2012, 01:46 PM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
You need to login to HK first
Then be sure you have the kk2 not in your chart already
Then click on the buddy code
Tchuss
E_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Jun 22, 2012, 04:34 PM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
Originally Posted by kapteinkuk View Post
- It has an option to use the Z axis Acc to dampen vertical movements. (not used in the video) Works very well in turbulent air.
Oh I like this! Not as good as baro Altitude Hold but I'll take it! I'm always having to mess with the throttle to keep a stable altitude! I didn't see in the Manual how to turn this on/off?
For the self-level... Do I have to take off from a level surface? How else would it know what is level without a magnetometer?
Felt lucky checking HK before work and getting one while it was in stock... Can't wait to tune and fly it!!
fallingdown is offline Find More Posts by fallingdown
Old Jun 22, 2012, 05:37 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
It may not be in the manual but it is in the menu. You just calibrate it on a level surface.
A magnetometer is for a compass. Nothing to do with autolevel.
HappySundays is offline Find More Posts by HappySundays
Old Jun 22, 2012, 10:45 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Wow, 3 days without following the threads, and then this. Things change every day ..., where will this stop?
manu
Originally Posted by HappySundays View Post
I second that question. Sure, I can draw it up (again) but I would love to NOT have to do it I just did the i86 board only last week LOL
alll is offline Find More Posts by alll
Old Jun 22, 2012, 10:59 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Can you put me in CC?
manu
I will send you a PM.
I just bought three with the buddy code
OK kapteinkuk, I realise you will open source it eventually but can you release the circuit to save me the effort reversing it? Pretty please?
What about the LCD? Can you point to any datasheets about driving it?
Any help is much appreciated.
Old Jun 22, 2012, 11:03 PM
pinguin is offline
Find More Posts by pinguin
pinguin's Avatar
Joined May 2009
Some more info:
- Each of the three gyro/acc chips has its own 3.3V Maxim low-noise voltage regulator.
- There is only one free IO pin, PortA0. It is tied to VCC, so a track must be cut. (it must not be used as a digital output during ADC operation) However, the ISP interface (three IO's) can be used with care as these is shared with three of the buttons. (For example, use only when armed, no buttons is supposed to be used then) Free output and input port can also be used of course.
- The gyros (IDG650 and ISZ650) has two outputs, 440 and 2000 deg/sec. It is selectable with a small solder jumper. It comes with 440 set.
- Output PWM rate is 400Hz.
If the gyro can work on 2000 deg/sec, why not make the 2000 deg/sec as the working output? Which solder jumper need to be mod?
pinguin is offline Find More Posts by pinguin
Old Jun 22, 2012, 11:23 PM
Joined Apr 2011
Okay, I thought that a 3 axis magnetometer was needed so the fc would always know its position, not just north/south but pitched up/down and rolled left/right? Like, if I calibrate it while on a level surface, then unplug the battery, roll it 30 degrees over and plug it back in... it knows it has been rolled 30 degrees? I get that it would know this if the power was on and it sensed it was being rotated... I just don't know how it would know if power was disconnected?
Or do you have to calibrate on a level surface every time a new battery goes in?
Old Jun 23, 2012, 01:14 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Well, I bought 2 boards at @$29.99 because I didn't see this thread with the buddy codes in it, but at least they have shipped and are on the way
lol, baros are terrible at altitude hold, you have to calibrate them against something else all the time eg an accelerometer. I mean what has barometric pressure really got to do with detecting Z axis movements? When a gust of wind comes through there is an accompanying change in pressure. You can't have air flowing with out air pressure change, that goes for wind, or a simple fan.
There is a force trying to accelerate the FC at 9.8M/sec ^2 in the Z axis all the time. It's called gravity. An accelerometer, once calibrated, is far more accurate at figuring what is level than a magnetometer, which can swing wildly with just a change in motor current! A magnetometer is really just used as a compass when you want the copter facing one way all the time for AP or something similar. Not much use for general flying.
Are you really going to do more than 440 deg/sec?
Erknie is offline Find More Posts by Erknie
Old Jun 23, 2012, 04:02 AM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Manual for HK KK2 Board..
For those who might want to look through the KK2's manual while waiting for delivery of the unit...or those waiting for them to come off backorder at HK.
Here is the KK2's manual: http://www.hobbyking.com/hobbyking/s...30X7478X47.pdf
-mike-
boiko is offline Find More Posts by boiko
Old Jun 23, 2012, 08:48 AM
tosjduenfs is offline
Find More Posts by tosjduenfs
Joined Jul 2006
I believe it has to do with the output resolution of the sensor. The sensor has a finite maximum output signal so if you set it to 440 then it is capable of detecting the angular rate more precisely since it is describing a smaller input range with a constant output range. This should lead to more stable flight
tosjduenfs is offline Find More Posts by tosjduenfs
Old Jun 23, 2012, 08:53 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Where did you hear that? The site says 10-25 days. All my backorders have been accurate so far.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Jun 23, 2012, 10:00 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Agreed just poor speculation.
Kris... is offline Find More Posts by Kris...
