Old Mar 01, 2013, 04:44 PM
Steveis is online now
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Originally Posted by rexless View Post
Greetings.
Has anyone noticed if the bottom of their KK2's look like this? I just received this one from hobbyking a couple of weeks ago and the solder on the outer edge of the pins looks like it all runs together. I'm not sure if this is the way they share the voltage across the pins or if I have a poorly built KK2. My other one is mounted and I can't see the pins as there's tape over that section. I don't recall noticing this.
It's fine, it's the ground connection.
Steveis is online now Find More Posts by Steveis
Old Mar 01, 2013, 04:46 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Originally Posted by brontide View Post
No, while they use the same CPU, the ftdi serial adapters are meant to program chips with arduino bootloader code.
Funny enough you can use the usbasp to program most multiwii boards if the ISP pins are populated.
Thanks, Brontide. Thought I'd ask before I spend the $4 something plus shipping at HobbyKing
I'll get one ordered up. I want to get 1.5 installed.
Sixinarow is offline Find More Posts by Sixinarow
Old Mar 01, 2013, 04:56 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Thanks!
rexless is offline Find More Posts by rexless
Old Mar 01, 2013, 05:27 PM
alumina is offline
Find More Posts by alumina
Joined Oct 2012
Originally Posted by Panzlflyer View Post
Is it possible that the gimbal is swinging and overcorrecting causing a shift in weight? try a flight with the gimbal servo unplugged.
so far the gimbal servos are not connected, I'm waiting for a ubec...
Also added weight usually means the gains will not be the same and need tweaking.
you mean like raising the gains? P and I?
alumina is offline Find More Posts by alumina
Old Mar 01, 2013, 06:48 PM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
Added weight makes it harder for the controller to handle the quad so try raising them a little.
Panzlflyer is offline Find More Posts by Panzlflyer
Old Mar 01, 2013, 08:02 PM
theothercliff is offline
Find More Posts by theothercliff
Temple, GA, USA
Joined Jun 2009
$7.76 shipped (buy it now) on eBay if that is any cheaper.
You can also order the USBASP and 10to6pin adapter separately. The USBASP's are all 10 pin and the KK2 is 6 pin.
theothercliff is offline Find More Posts by theothercliff
Old Mar 01, 2013, 08:46 PM
dfruehwald is offline
Find More Posts by dfruehwald
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Got my props balanced out last night but unfortunately the weather didn't cooperate and it was more windy than I like for a maiden on a new vehicle. Maybe I'll have better luck tomorrow. Sounds much better now with props in balance, since it was way late yesterday I've punted on dynamically balancing the rotor bells for now. Need to clear of the table to do some grooming on my shaggy dogs.
dfruehwald is offline Find More Posts by dfruehwald
Old Mar 01, 2013, 10:54 PM
--Oz-- is offline
Find More Posts by --Oz--
Quadaholic
--Oz--'s Avatar
United States, CA, Newport Beach
Joined Mar 2006
Originally Posted by --Oz-- View Post
I seen the nice protection box that is specifically made for the KK2 but is almost the cost of a new KK2 after shipping to the USA.
I came across this box witch needs some slight modding. Cut height down 1/2 inch or so, open up the bottom to be able to view the LCD and buttons access. Another hole for the buzzer and a couple of holes for zip tie it down to the quad frame. You leave the KK2 in the black foam that is came in, then slide the box over the top of the KK2 and zip tie to frame. They are very sturdy boxes, I had a 300lb friend step on the box, no problems.
PN Stanley Vidmar BN-25-44 (black version is CBN-25-44)
Plastic Bin 3 Inch X 3 Inch X 2-1/8 Inch
Couple of places to find them is;
http://www.stanleyvidmar.com/quicksh...44-plastic-bin
http://www.grainger.com/Grainger/STA...099?Pid=search
I will probably install my FrSly D6FR 6ch Rx in the box also, photos coming when done.
I finished my KK2 protection box. Just need to add LED's to the arms and landing gear.
I used a Dremal tool with router bit and quickly carved out the stock Anti-static foam to accommodate the wires (Rx to FC, FC to ESC, buzzer and telemetry wires) and 6ch FrSky D6FR Rx. It is mounted with 4 zip ties and is semi clean looking (comparing to my old setup). This box is robust, easily hold 300 lbs weight straight down.
Now to final tune my scratch-build 400mm quad with the excellent KK2. Thanks for all the help guys!
--Oz-- is offline Find More Posts by --Oz--
Old Mar 02, 2013, 06:02 AM
DEBAY777 is offline
Find More Posts by DEBAY777
Joined Aug 2009
is there a reason I cannot regiter with kkmulticopter.com?
DEBAY777 is offline Find More Posts by DEBAY777
Old Mar 02, 2013, 07:26 AM
srepfler is offline
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
After many hours of flight it is time to oil ball bearings
Scorpion Brushless Motor Bearing Oil (1 min 23 sec)
http://www.hobbyking.com/hobbyking/s...405&aff=448825
srepfler is offline Find More Posts by srepfler
RobertSF is offline
Find More Posts by RobertSF
United States, NM, Santa Fe
Joined Feb 2013
Very cool video, jcarte! The aerial shots of the aerobatic planes are great!
Originally Posted by jcarte View Post
Tricopters at FX3D both on KK2
http://vimeo.com/60394595
RobertSF is offline Find More Posts by RobertSF
Old Mar 02, 2013, 07:32 AM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
no doubt that it's no different than 3in1 oil with some coloring, specially made in china
I'm a firm beleiver ,always buy oils or chemicals from a reputable usa or canadian company that follows strict guildlines, atleast you know what your getting
irun4fundotca is online now Find More Posts by irun4fundotca
Old Mar 02, 2013, 08:25 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Nice clean install. Good job.
kaptondave is offline Find More Posts by kaptondave
Old Mar 02, 2013, 04:37 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I ordered one of those, but just so you know, roller blades bearing oil also works great. I just haven't found any around me, okay I haven't bother to really look for it, but I bought some years ago and it's what I have been using. My bottle is almost out, hence the need for some more oil, but I need the needle too.
http://youtu.be/PT49As5_vFI
efx is offline Find More Posts by efx
Old Mar 02, 2013, 05:58 PM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
I've been using that Scorpion bearing oil for years. Started using it after loosing a few tail blade grip bearings on my 450 heli's and also on my 500, motors, head bearings, belt drive bearings, then on all bearings even new ones before installing them, etc. It's really good stuff but as posted above not on oneway bearings. I use silicone grease on them. My buddy put it in a oneway on his 450 and within 2 flights it was slipping and then locked up.
Rotorhead0207 is offline Find More Posts by Rotorhead0207
