Espritmodel.com Heli Air
Old Feb 20, 2013, 08:54 PM
Joined Dec 2007
Originally Posted by jasmine2501 View Post
If it causes the motors to surge more, then it definitely will lose efficiency. Accelerating the motor uses a lot of power. Brushless motors are really efficient, but if the motor is surging and it's unnecessary to maintain stability, you are wasting energy. Think about the worst case and the best case - in the best case, your motors would run at a constant RPM and the quad would be stable. In the worst case, the motors are surging hard and the quad is wobbling - that wobbling motion is a waste of energy. The closer your gains are to 'correct' the more that wobbling is reduced - but it's still there, it's just so small you can't see it. That's how a quad copter works (it's constantly wobbling, if it wasn't, we wouldn't need the KK). So, in the middle of the gain range, you have worse efficiency than the best case.
However - depending on your particular quad, it may not make a significant difference at all. It will make a difference because you're closer to the 'worst' example than the 'best' but it may only cut your flight time by ten seconds and you'll never notice.
every wobble has one motor speeding up and one slowing down so probably net zero.
Rotorhead0207 is offline Find More Posts by Rotorhead0207
Old Feb 20, 2013, 11:16 PM
5th
Mediocre Pilot Extraordinaire
5th's Avatar
United States, OR, Eugene
Joined Jun 2012
I didn't read it on the internet. I was inferring it myself thinking along the lines of what jasmine2501 wrote. I don't think it would be a net zero because accelleration is far more expensive than constant rotation, but I might be convinced the difference is negligible. Still, a test might be easy enough. With a multi that is fairly stable at lower than average gains and a fully charged healthy battery, run five minutes hover on the lowest gains I can control. Then charge the battery and run another 5 minutes hover on the highest gains I can control. Charge again and compare mAh used per flight. Then again, the drift in conditions and the battery alone might cause an error greater than the effect I'd be trying to measure.
It was just a thought: I have a lot of them, and often they are worthless. But some are pretty good. I think of it like Edison finding the right filament to produce a working light bulb - he tried everything he could think of. I try to examine my ideas to see if they have merit. Sometimes I'm pleasantly surprised. In any case it rarely hurts to ask those that might know more. Correct or not, it's usually productive.
5th is offline Find More Posts by 5th
Old Feb 21, 2013, 12:25 AM
Joined Jan 2010
If your tests prove that you are correct then your conclusion is "don't fly fly with overly high gains because it reduces flight time by using too much power"?. I don't do that anyway, because for me it reduces flight time by causing oscillations that result in a crash.
kaptondave is offline Find More Posts by kaptondave
Old Feb 21, 2013, 01:02 AM
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Originally Posted by --Oz-- View Post
What frame rate does the KK2 v1.5 output to the ESC's (I am guessing it's higher than standard servo frame rate do to the ESC or Servo option in the KK2 menu)?
The ESC frame rate is 400Hz.
Steveis is offline Find More Posts by Steveis
Old Feb 21, 2013, 02:24 AM
numnutchris
Joined Sep 2009
Originally Posted by ripmax View Post
surely there must be a straight forward thread somewhere here?
Same place where you got the SW, I suppose:
http://lazyzero.de/en/modellbau/kkmu...ashtool/manual
You need the Flashtool, Java and some driver for your usb->atmega cable.
numnutchris is offline Find More Posts by numnutchris
Old Feb 21, 2013, 03:19 AM
Joined Sep 2012
Originally Posted by brontide View Post
Looks like you could clean up some ofu that Rx wiring, you only need one of the Gnd, +5v wires and the rest can just sit sideways connecting the signal wires as appropriate.
Balsa is light and at that weight it should be quite stable, but I don't know how durable that would be long term. A harder wood like basswood would give it a little more resiliency.
Thanks, yes. I have done that with my Reaktor 3d because I ran out of male-male linking cables.
I have already snapped one of the motor arms off and glued it back on. I just used some balsa leading edges from an old glider kit, as I love to use leftovers that cost nothing.
I need to replace the ply centre sections as they are inclined to split.
My next goal is to do the chuck test that involves throwing it into the air like a frisbee and then giving it half throttle and see if it stabilizes. But looking for some long grass to do it above rather than the gravel of my driveway.
The main goal was to make something very light. I could still shorten the arms, and some of the wiring. I have set up the low voltage alarm on the KK2 so I don't need the accessory unit.
And I need some more flying hours to get accustomed to which way it is pointing when I am flying it!
Still haven't mounted my vidcam on it.
Gilbert Griffith is offline Find More Posts by Gilbert Griffith
Old Feb 21, 2013, 04:36 AM
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
From Landor
"There is still something strange: when I hit aileron left I have -104 Left, and when I hit rudder left I have +104 Left. Is this normal?
Can anybody tell me the correct settings for 9ch Tx an Kk2?
Are these settings ok?
I use a 9X (FlySky TH9X) with ER9X firmware.
My Rx Test values are the same polarity wise.
Rudder Left is +ve value, Aileron Left is -ve value.
Elevator back is +ve Value and throttle from 0 to 100.
As for Motor 1, someone replied to you ages back that running without props will cause one motor or other to increase in speed as the gyros are trying to get the craft level but it is not moving to level (Very basic but you get the idea).
How long is it running before it is hot, check for binding or rough bearings, if it is the type where the mount clamps onto a tube you may have screwed up to tight and squeezed the bearing, I have done that before.
Leave it powered off for a few minutes, does it spin free by hand.
Deyrick
Del-Dredd is offline Find More Posts by Del-Dredd
Old Feb 21, 2013, 07:20 AM
Joined Jan 2010
My next goal is to do the chuck test that involves throwing it into the air like a frisbee ....
Man, you have way more balls and way better flying skills than I do with these things. A balsa quadcopter would never survive the first toss in my hands. In fact I admire any first-timer with the guts to fly an all-balsa ship under any circumstances. Best of luck, but if it does not work out here is what I consider the best deal going for an inexpensive but tough first multi:
http://www.hobbyking.com/hobbyking/s...dproduct=24172
Old Feb 21, 2013, 10:55 AM
5th
5th's Avatar
Joined Jun 2012
Did you hear they changed that kit?
Old Feb 21, 2013, 11:14 AM
Joined Jan 2010
Nope.
Old Feb 21, 2013, 11:29 AM
Brazil, RS, Porto Alegre
Joined May 2012
Incredible
Incredible. Even a totally new multi rotor pilot can fly with the KK2 board. I am fascinated.
Tricóptero Tricopter V (1 min 58 sec)
It's a kind of warranty of fun.
dvloss is offline Find More Posts by dvloss
Old Feb 21, 2013, 11:30 AM
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
You mean this one...
http://www.hobbyking.com/hobbyking/s...B_Version.html
harrym is offline Find More Posts by harrym
Old Feb 21, 2013, 11:44 AM
Joined Jan 2010
Originally Posted by harrym View Post
I bought the one without the integrated PCB and added the power distribution board which has the battery and ESC power connectors installed.
Old Feb 21, 2013, 12:06 PM
taz007's Avatar
Joined Jul 2011
Originally Posted by Steveis View Post
Taz007, check out my blog. There is a V1.4 with a lower gyro limit of 490 for you. However, I don't hold out much hope as your gyro z looks too high. But if you don't send the board back, it's worth a try.
http://www.rcgroups.com/forums/showthread.php?t=1836243
Cheers my friend but sent it back. just waiting to see if its covered by the 30days cover, But going to buy another KK2 next week .
Thanks again
taz007 is offline Find More Posts by taz007
Old Feb 21, 2013, 01:22 PM
Joined Feb 2013
Originally Posted by Del-Dredd View Post
From Landor
Deyrick
I have swapped the plugs on KK2 board from CH1 (motor 1 & esc 1) with CH2 (motor 2 & esc2) and the problem transsfered from M1 to M2. So I understand that the board increases the rpm's. CH1 has a problem or it could be like Deyrick said above.
Motors and esc's are ok.
About the hot motor, it is hot compared to others.
I thing that it is getting hot because it spins faster than the others.
I have checked also the screws from motors. They are ok and motors are spinning easy by hand.
Landor is offline Find More Posts by Landor
