Old Feb 18, 2013, 09:32 AM
teccer1234 is offline
Find More Posts by teccer1234
safer on the ground
teccer1234's Avatar
wilts, United Kingdom
Joined Jul 2006
Originally Posted by Del-Dredd View Post
With the 1.4 or 1.5 firmware you can turn down the Self Level gain in the settings which will slow the response.
The default was to harsh for me so i reduced it by 10-15 i think and it made it a lot smoother.
thanks to all on this forum who have helped me with my setting up my V 1.5,
in acro mode all's set ok and I think I've just about got the A/L setting correct now but I'd like others opinions on it, in S/L settings I've got P 34 and limit 37, I don't think I want to go much lower as I'll lose more authority on the sticks if I do, in the vid there's a couple of times when there's a slight wobble but I've put that down to the S/L working as it should, am I right?
let me know if you think my settings are ok after looking at the vid
setting up self level on my KK2 V 1 5 (5 min 17 sec)
many thanks guys
ray
teccer1234 is offline Find More Posts by teccer1234
Old Feb 18, 2013, 10:56 AM
jdr00ejr is offline
Find More Posts by jdr00ejr
United States, IN, Indianapolis
Joined Oct 2012
Hi Everyone. I'm looking for help and someone suggested this thread. I bought an Armattan Quad from the For Sale Multirotors section. I haven't adjusted anything but my Stick Scaling for Pitch and Roll at the moment. When I turn on Self Level I find that my quad is drifting forward and right. I'm trying to determine how best to adjust that. I found the below post when trying to do a search through this thread. Is this what I need to do or am I misinterpreting things?
Does changing the ACC Settings change normal flight or anything? Does it just adjust self level?
I assume I would decrease Roll to give it more left? And increase Pitch to give it more back? Is this right? In what increments should I try these adjustments?
Originally Posted by romans1015 View Post
"TUNING" my quad was the most challenging part of my build process.
2) Switch self-level on and take off. Do not adjust transmitter trims. Instead
see which way it is drifting and then land it. Disarm and then adjust the
ACC trims in the KK2 self level menu.(see pic below)
In the ACC self level menu
If you want it to drift more left or more forward = negative(decrease the numbers)
If you want it to drift more right or back = positive(increase the numbers)
Left and Right would be the Roll
Forward and Backward would be the Pitch
jdr00ejr is offline Find More Posts by jdr00ejr
Old Feb 18, 2013, 11:52 AM
Cyberdactyl is offline
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
I'm somewhat new to this board, but my initial guess is you could have a CG issue. One crude fix is to "trick" the multi-rotor that you're level when your not. Done here by Hallstudio.
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old Feb 18, 2013, 12:14 PM
jdr00ejr is offline
Joined Oct 2012
That's an interesting approach to the problem. I may give this a try.
Old Feb 18, 2013, 12:25 PM
Senator315 is online now
Find More Posts by Senator315
iMultirotors
Senator315's Avatar
Australia, NSW, Shellharbour
Joined Aug 2012
The OctoTower is flying. For the full story, click here.
OctoTower Maiden flight (1 min 27 sec)
Senator315 is online now Find More Posts by Senator315
Old Feb 18, 2013, 12:41 PM
taz007 is offline
Find More Posts by taz007
taz007's Avatar
United Kingdom, Higham
Joined Jul 2011
Please help a noob, I bought the KK 2 board from HK ,
Got 4 x turnigy plush ESC's,
4x DT750 hextronic motor's,
TX is a 9X on ER9x, with HK TR6A v2 rx,
I have followed install video's and got to plug everything in,
But Am getting the following Error
"Warning Sensor Calibration data out of limits.
Check your settings."
I do a sensor check getting
Gyro X: 533 OK
Gyro Y: 497 Not OK
Gyro Z: 614 OK
Acc X: 622 OK
Acc Y:612 OK
Acc Z: 814 OK
But if i move the board the "Not OK " changes to "OK" but then changes back
Please help!!!!
Thanks in advance
taz007 is offline Find More Posts by taz007
Old Feb 18, 2013, 01:28 PM
iMultirotors
Senator315's Avatar
Joined Aug 2012
taz007, I had the same issue with a brand new board, had to send it back to HK.
Your Gyro Y is only just out, it needs to be at least 500, so close.
You can try to flash the board, but that usually doesn't help as it's most likely a faulty gyro.
Old Feb 18, 2013, 01:46 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
many thanks guys
ray
Looked very smooth to me, looks nothing like the UK though.
Did not notice it wobbling, maybe a slight one but that was when decending vertically which is usual, due to dropping through its own downwash.
Increase the Stick Scaling for Aileron and Elevator to give more authority, I set mine at 90 ish for flips/rolls but use dual rates on the Tx to give me 65% for fast circuit flying as it is smoother and still gives excellent control.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Feb 18, 2013, 02:01 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
If using the stock 1.2 firmware thats what it will seem like as it is a bit slow to level out but it does work, I flew with 1.2 for ages before switching to 1.4 which is how self level should be.
I turned my Self level P gain down a bit to make it smoother on my Tricopter.
Write down your 1.2 settings first as it will go back to defaults, Flash it to 1.4 or 1.5 (if you need camera stab), load correct motor layout, do calibration and receiver test, put in your recorded values, leave Self Level Gain and trims at default until you test fly it.
How do I find out which firmware version my kk fc is running on? its new from hk, is it easy to update the firmware if mine is 1.2? sorry I'm being lazy, must in in this thread somewhere...thanks again for any help anyone can give
ripmax is offline Find More Posts by ripmax
Old Feb 18, 2013, 02:11 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Very easy to update. Use lazyzero flash tool. That program contains the file to flash your kk2. Or the files are on the first post of this thread.
TheFernMan is offline Find More Posts by TheFernMan
Old Feb 18, 2013, 02:12 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
The firmware version is shown for a second or two on power up.
Steveis is offline Find More Posts by Steveis
Old Feb 18, 2013, 02:13 PM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
http://youtu.be/trP2JRbIdgg
NICE gotta love it when things you put together actually work! Congratulations!
Rotorhead0207 is offline Find More Posts by Rotorhead0207
Old Feb 18, 2013, 02:43 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
http://www.hobbyking.com/hobbyking/s...occessors.html
Can I use this to update the firmware? or think I have a cable to update from an old kk board, will that work?
Old Feb 18, 2013, 02:48 PM
Steveis is offline
AVR Dude
Joined Jul 2011
That's the programmer but you should be able to use your old kk board one.
Old Feb 18, 2013, 02:50 PM
taz007 is offline
taz007's Avatar
Joined Jul 2011
Iv already flashed the board to 1.5 , so do i flash it back to 1.4 of just send it back???
