Old Feb 13, 2013, 09:09 PM
Bhamflyer is offline
Find More Posts by Bhamflyer
Joined Apr 2009
Jrjr and Steveis,
You guys hit it right on the nose! Turned stick scaling up to 100 and voila the motors went to full throttle. I was thinking in terms of expo where no expo gives you complete control of the stick imputs. This is what I love about this hobby. Guys willing to help another guy with a problem just because. BTW this was about the fourth problem solved based on the information fom this thread. I'll be flying for sure as soon as this dern rain quits. Thanks,
Martin
Bhamflyer is offline Find More Posts by Bhamflyer
Old Feb 13, 2013, 09:44 PM
5th is offline
5th
Find More Posts by 5th
5th
Mediocre Pilot Extraordinaire
5th's Avatar
United States, OR, Eugene
Joined Jun 2012
Whoa. Wait. I hadn't thought of that.
I recently rebuilt my F450 clone. Before, with 10" props, I had gobs of power. Then I went from X to +, flashed the KK2.0 to v1.5 FW, added LEDs, and SimonKed the ESCs. Now it's got no get up and go. It hovers at about 75% throttle, despite not being significantly heavier since the rebuild. I just noticed my throttle scaling is at 50.
I should get more range on the throttle with that set to 100, right? Or am I understanding this wrong?
[looks at charger to see if the batt is ready...]
EDIT: Wow. Turning the throttle stick scaling up to 100 gave me my quad back. It has POWER again. Hovers at 45% throttle now.
I can't believe I missed that. Doh!
Thank you. Forums rule.
5th is offline Find More Posts by 5th
Old Feb 13, 2013, 10:37 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
@KK2 gurus... Is there any downside to having all of the throttle range available on the throttle stick?
For example: You're in SL mode, you give it full gas and then there's a gust of wind. If the throttle is maxed out does the KK2 reduce throttle on the 'up' side to maintain level? Or do you need to reduce throttle before there is SL headroom available?
Would running Throttle Stick Scaling at 90 compensate with a little drop off in absolute oomph?
thwaitm is offline Find More Posts by thwaitm
Old Feb 14, 2013, 12:06 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by cmavr8 View Post
The servos I tried in ports M2-8 are just buzzing a bit. They stop buzzing when I am in the menu.
Sounds like you are using analog servos while output PWM rate is set to high. Try setting it to "low" (in mixer editor menu, I think it was located).
Fred
flarssen is offline Find More Posts by flarssen
Old Feb 14, 2013, 12:11 AM
flarssen is offline
Son, Norway
Joined Sep 2004
Originally Posted by kaptondave View Post
It is a whole lot easier and cheaper to make a simple tool to hold the buttons down hands free. I used a couple of old-fashioned wooden clothespins, modified to widen the jaw opening. My cost was zero because I borrowed the clothespins from the wife.
No need to, if using newer firmware, as there is a timeframe for pushing the buttons after powerup.
Old Feb 14, 2013, 12:49 AM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Originally Posted by jonesy40001 View Post
Do you have a power source for M2-M8? Power from M1 BEC is isolated from the others
Yes, this is my case! I was plugging the BEC at M1.
Tried the BEC at M2 but nothing happens. KK2 doesn't start, neither does the Rx. (according to mmerry2 on youtube)
Also tried the other M3-M8, but nothing happens. The KK2 only works with the BEC at M1.
Can I just make a Y harness to power M1 and say M8 (to feed back to the servos) from the same BEC?
Thanks Jonesy!
EDIT: On second thought, maybe I'll have my ESC's bec connected to M1 for powering the KK2, and my (external) UBEC on M8 to power the servos. Would that be viable or will I fry anything?
cmavr8 is offline Find More Posts by cmavr8
Old Feb 14, 2013, 12:50 AM
cmavr8 is offline
Chris
Joined Sep 2010
Fred
Thanks, checked that last night, it wasn't the case...
TY
I also reset to factory defaults and only changed the motor layout but still no go..
Old Feb 14, 2013, 01:52 AM
flarssen is offline
Son, Norway
Joined Sep 2004
That is the correct way of doing it. But I assumed you already had power on the M2-M8? Servos don't buzz without power.
Anyway, on KK2, servos will not operate until you apply some throttle.
Fred
Old Feb 14, 2013, 02:11 AM
cmavr8 is offline
Chris
Joined Sep 2010
Fred
Ok, works like this! I hope it doesn't matter what I plug in first... I to plug the ESC+BEC that powers the KK2 board first.
So, the servos DO buzz without power! (to be clear: just a slight buzz. not the normal "can't find the spot" or stall buzz of a servo. Maybe some voltage is leaking through the KK2 board to the +V connector of the servos... dunno)
"on KK2, servos will not operate until you apply some throttle."
Can I change that without flashing OpenAero?
Having this on a glider, I need stabilization/autoleveling to always work, even without the motor running...
Thanks all for your help
Old Feb 14, 2013, 02:35 AM
flarssen is offline
Son, Norway
Joined Sep 2004
No, this can not be changed in current versions.
Old Feb 14, 2013, 03:03 AM
cmavr8 is offline
Chris
Joined Sep 2010
Ok, I found a work-around, until my USBASP is here and I can use openaero:
I noticed that the servos start working before the motor starts.
So I set min throttle to 0, and then trimmed my throttle (on TX) up a bit.
Now at zero throttle stick, the servos etc work (M2-8) but the motor doesn't. When I throttle up everything seems to work OK
I believe the following has to change, especially #2 and #3!:
Originally Posted by kapteinkuk View Post
Airplane use:
1: setup the TX as described in the manual.
2: Connect the motor ESC to the RX as ordinary.
3: Connect a BEC to output#8, to supply the servos. Leave output#1 unused.
4: Using the mixer editor, find and connect the servos to the other outputs.
5: If you need to reverse a function (aileron, elevator, rudder), negate all mixing values for that function on all servos that are used by that function.
6: If you need to reverse a servo, negate the mixing value for that function on the servo in question.
7: adjust the stick scaling to get the required stick response.
8: adjust the mixing values to change the throw.
I recommend setting the I gains to zero when testing.
Old Feb 14, 2013, 05:55 AM
symon is offline
Find More Posts by symon
Joined Apr 2007
Hi,
Built my second quad..
DJI 330 Frame
KK2 Board 1.5FW
Turnigy plush esc's 30amp
SK3 2822 1275 KV motors
All settings done,and correct...subtrims to zero ...self leveling..reciver check..etc
On take off it wants to flip to the left......when i tried reversing yaw,it flips to the right...all motors are getting power to them,have tried each one individually,,
Have a second quad,almost the same..and have tried all the TX settings from that on other quad,and still the flip..so can only assume its the KK2 board settings..
symon is offline Find More Posts by symon
Old Feb 14, 2013, 06:06 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Originally Posted by symon View Post
Hi,
DJI 330 Frame
KK2 Board 1.5FW
Check the motor layout in the kk2 menu. It may be incorrect for your setup.
Steveis is offline Find More Posts by Steveis
Old Feb 14, 2013, 07:18 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Where did you get that? The instructions in the manual have not been changed and this is the first I have heard that.
kaptondave is offline Find More Posts by kaptondave
Old Feb 14, 2013, 07:32 AM
Backwall is offline
Find More Posts by Backwall
Racquetball Lives!
Backwall's Avatar
United States, AL, Prattville
Joined Jul 2010
KK2 arrived
Just wondering if the KK2 supplier is downsizing because employees must be going all out to keep their jobs. I'd seen pictures other have submitted where the solder job is so sloppy, but mine arrived with some of the best solder work I've seen in a while. Some assemblers must be trying to impress their boss. I haven't hooked it up yet, so hopefully the assembly was as good as the solder work. No complaints from me. Just trying to fit all the components and keep a good CG for flight. Shold be soon, I hope!
Dave
Backwall is offline Find More Posts by Backwall
