Old Feb 12, 2013, 09:53 AM
Specializing in RC since 1972
Temple, GA, USA
Joined Jun 2009
Originally Posted by Byrdman View Post
So with that 6 pin adapter, can you flash esc's too?
I bought my programmer and 6 pin adapters separately on eBay. My programmers came with 10 pin output, a 10 pin extender cable, and a 10 pin hood to allow you to do it the cheap (and difficult) way of soldering wire wrap wire to the 10 pin hood and tack soldering the wires to the ESC. That 10 pin hood is handy if you are going to "roll your own" connection to the ESC. You will also need some big heat shrink for the ESC boards.
The 6 pin adapter is for the KK2 and doesn't help for ESC's. ESC's require first of all determining the brand of CPU. I have Atmel CPU's in my ESC's and bought one of those HobbyKing $20 CPU clips. Expensive, but it makes the job a simple one. Once you know where the CPU is, carefully cut a flap in the heat shrink (unless there is a heat sink plate covering it). Connecting the ESC for programming is as quick as cutting the flap.
theothercliff is offline Find More Posts by theothercliff
Old Feb 12, 2013, 10:12 AM
Slovenia
Joined Jun 2008
Originally Posted by flarssen View Post
BECs on M2-M4 doesn't do anything as long as there are no servos connected, but usually it doesn't hurt to have them there either.
Fred
I will get new ESCs to test on mine. Only one ESC has BEC (TBS ESCs) I have 2 servos for gimbal on m7 and m8. Can i just connect input voltage from M1 to lets say M4?
Paps1984 is offline Find More Posts by Paps1984
Old Feb 12, 2013, 10:15 AM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
That is generally frowned upon because the KK2 does not have it's own voltage regulator and there is concern of brownouts or noise from servo sharing the 5v supply.
brontide is offline Find More Posts by brontide
Old Feb 12, 2013, 10:31 AM
Slovenia
Joined Jun 2008
OK. But isnt that the issues aswell as if you use ESC with BEC separately on M4 for example. So i guess best way would be to just use 4Cell NiMh or somthing on M5 maybe?
Old Feb 12, 2013, 10:40 AM
safer on the ground
teccer1234's Avatar
wilts, United Kingdom
Joined Jul 2006
setting v 1.5
I'm a bit of a dumbo regarding electronics ( it's my age, in my 70s now) so please bear with me on this, I've got two identical tricopters, one is running with KK2 v 1.2, it flies like a dream and was so easy to set up, now I've just flashed the other to V1.5 and I'm having a hell of a time trying to set it up
when the SL is off it's so aggressive so I've used stick scaling to make it more subtle, but it's still pretty rapid on the controls, when I put SL on (because of the stick scaling adjustments I made with SL off) it's much too docile, I can fly it sort of ok but not as good as the V1.2 tri so my question is what dim/stupid thing have I done wrong
you can see how my V1.2 flies so I'd like to get the 1.5 like it as well
Bolnuevo rocks with tri (5 min 0 sec)
I know all these figures are wrong but I'm sure some of you bright intelligent guys out there maybe able to get me somewhere nearer the mark
info, the left motor and the elevator motor are ccw and the right motor is cw
TIA
Ray
PI EDITOR
AL+EL
P 63
LIMIT25
I GAIN 5
LIMIT3
RU
P70
LIMIT25
I GAIN 50
LIMIT10
STICK SC
AL 12 EL 12 RU40 TH 100
SL
P60 LIMIT 20
MIXER ED
1 TH 100 AL-55 EL 60 RU 0 OFFSET 0
2 100 65 60 0 0
3 100 60 -100 -70 0
4 0 0 0 -95 20
teccer1234 is offline Find More Posts by teccer1234
Old Feb 12, 2013, 12:48 PM
Joined Feb 2013
Help please, Is there a way to use the KK2 board, fw 1.5, or a variation to use for camera gimbal autoleveling without using the transmitter and receiver. In other words, to use the KK2 board to self level a small hand held camera gimbal, sort of like a steadycam. Seems the the problem I am having experimenting with this is that I cannot find a way to activate the KK2 without the transmitter and not sure it will operate with no throttle. Any help would be appreciated... thanks.
llott70 is offline Find More Posts by llott70
Old Feb 12, 2013, 12:57 PM
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
There is no watch down and even if the programming "froze up" I don't see it generating drops like this*. Are those experiencing drops using height dampening? ACC should be absolute and unaffected by cold, but I would have to dig a little deeper.
* I would expect either catastrophic fall or big jump then fall, not these cut-outs that some people are reporting ( and I have seen it too in very cold weather ). Unfortunately I can't reproduce it in order to quantify or fix it.
I have been flying all day and I've seen it happen several times now.
It seed to worsen at night when temps got down to minus 8.
I have height dampening turned on, so I'll see if it happens again with it turned off tomorrow.
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 12, 2013, 01:03 PM
Joined Sep 2012
Thanks, if it only happens with height dampening on that gives me a solid lead that maybe the ACC is returning bad data ( height damp is based on acc-z value ). Then I can look for ways to identify and reject the errors. The SL rejects low-g readings, maybe we need to do the same for heigh dampening.
Old Feb 12, 2013, 01:27 PM
Joined Feb 2013
If you install OpenAero2 on the KK2 board, does that mean you do not need to upgrade from 1.2 to 1.5 of the standard KK2 firmware. Sorry if this is stupid question, I am brand new at this.
Old Feb 12, 2013, 01:34 PM
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Correct, no need to upgrade to V1.5. Just program with the OpenAero2 code.
Steveis is offline Find More Posts by Steveis
Old Feb 12, 2013, 01:54 PM
Rather be flyin
tom83's Avatar
Tucson, Arizona
Joined Mar 2008
Had a quick question about my KK2 board that I received yesterday. Everything looks great on the front of the board but when I turned it over there was soldering covering multiple pins. I have not powered up the unit for fear it may short. Can anyone tell if I will need to remove some solder?
tom83
tom83 is offline Find More Posts by tom83
Old Feb 12, 2013, 01:58 PM
goldsworthy's Avatar
United States, AZ, Tucson
Joined Mar 2012
tom83
Now thats quality! Hobby King quality! you dont find solder jobs like that one on a NAZA!
goldsworthy is offline Find More Posts by goldsworthy
Old Feb 12, 2013, 01:59 PM
AVR Dude
Joined Jul 2011
tom83
It's OK but not elegant. It's on the ground side of the connectors. You'll be fine.
Old Feb 12, 2013, 02:00 PM
JBPiantanida's Avatar
United States, FL, Tampa
Joined Mar 2006
tom83
Those are rows of ground pins... so them being shorted isn't a problem, but that is rather sloppy.
Edit: Steveis types faster than I do.
JBPiantanida is offline Find More Posts by JBPiantanida
Old Feb 12, 2013, 02:02 PM
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
tom83
I think it is supposed to be like that. One the esc side, you only need power on the first one and it will supply power on all the others. and on the Rec side, I think that is the ground side.
Byrdman is offline Find More Posts by Byrdman
