Joined Dec 2012
Great FC, you just have to go home/or connect to a computer to tune it. |
Tasmania, Australia
Joined Aug 2004
All systems have their stron and weak points and their bugs and problems. It is just a matter of how you work with them, and what you are trying to achieve. |
Tasmania, Australia
Joined Aug 2004
uk buddy code kk2 board
uk buddycode for kk2 board for 11.27 if anyone wants one..
http://www.hobbyking.com/buddy.asp?c...0-9FD9AA50DF91 |
Hope that helps. Pete. @ Kaz.... I am too slow. |
United States, KS, Overland Park
Joined Feb 2013
my idea: why code and design a whole new board, when great ones like the kk2.0 exist? so i figured i could let the kk2.0 handle the stability/motor control/leveling. then put an arduino between the receiver and the kk2.0. with channel 5 on my radio switched off, the arduino just passes channels 1 through 4 straight out my digital pins to the kk2.0. if i turn channel 5 on, the arduino takes over and gives the kk2.0 commands via code. (autopilot, versus controlling it via the transmitter) i've got the basics coded and working. just need to do some actual flight tests. i've coded in support for my MTK3339 gps unit. it locks quickly and is very accurate. the only thing i haven't implemented yet is a magnetometer. i can get heading via the gps, but that's only acquired if the craft is moving. i'm sure it'll be fun trying to tune the magnetometer with high current electronics on board, not to mention the magnets in the motors. oh well, should be a fun project. |
Joined Jan 2010
Some of the early KK2s had traces very close to the holes. The newer ones are better but it is still best to use nylon. Better still is to use double-side adhesive foam. That provides some vibration isolation and no possibility of shorts. When I want to stack the KK2 with a power distribution board, etc., I use a 50 mm plywood square as the top layer, with counter-sink holes for the threaded fasteners (metal OK) then stick the KK2 to that.
http://www.hobbyking.com/hobbyking/s...rol_Board.html And if you look under multi-rotor in the left menu you will find all you need to get started. |
