Old Feb 09, 2013, 08:32 PM
Senator315 is offline
Find More Posts by Senator315
iMultirotors
Senator315's Avatar
Australia, NSW, Shellharbour
Joined Aug 2012
Originally Posted by efx View Post
Does anyone know where I can find some motor shafts? I seem to need some of these now. I got some poictures at the bottom here. And please tell me they don't glue the shaft to the top cover. Mine seems to be. Well this sucks, this shaft seems to be in there pretty tight...
http://www.rcgroups.com/forums/showt...3#post24086515
Any 3.17mm shaft will fit, you just need to find one that's the right length or longer as you can cut them down. Something like this will fit.
They are just press fit, remove the set screw and tap the shaft out.
Senator315 is offline Find More Posts by Senator315
Old Feb 09, 2013, 08:38 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I figured they were. I have a vice so I'll do that later once I find some. I don't want to have to cut them yet, so I'll keep looking. Thanks for the link. I think I just saw some for 80 cents or something like that, so I'll just look for some cheap ones.
I'm wondering if these may be a tiny bit lose...they are almost perfect...
http://www.hobbyking.com/hobbyking/s..._Kit_20_S.html
efx is offline Find More Posts by efx
Old Feb 09, 2013, 09:37 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Or maybe this will work. I may have to cut it to size but that will save me a bit...if I don't kill the housing trying to take it out. Does anyone have any idea of what kind of steel these motors may use. Tool steel may be a bit too hard.
http://www.onlinemetals.com/merchant...=160&top_cat=0
Old Feb 09, 2013, 09:39 PM
theothercliff is offline
Find More Posts by theothercliff
Temple, GA, USA
Joined Jun 2009
The shafts have slots for E clips. Where the slots are, how many there are, and the shaft diameter are important. I bought some shafts on eBay when they were being clearanced. Is that what eBay would call an A2208?
I often find that you may as well buy a new motor (if found at a good price) rather than buy bearings or shafts.
theothercliff is offline Find More Posts by theothercliff
Old Feb 09, 2013, 09:45 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
You're right, this is the reason I just buy the cheap motors. I saw a few around, but haven't seen them in a while. I'll keep looking if not I'll give something like this a try. I have a dremel and a hobby lathe to make the grove for the eclip. It only has one at the bottom on these so as long as I can make one groove I think it would work. Yes more work than I would like, but since china is on vacation that will have to do if I can't find any. I'm not in a rush now so I'll see what comes up. Making my own shafts would take way too long so I rather get a piece of stock and just cut it. The motors do lool pretty decent inside.
Old Feb 09, 2013, 10:36 PM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
OctoTOWER SENATOR315-COCO2010 JOINT PROJECT
...wanna share some pix of our joint project...IT'S ALIVE !!!
...maiden video will follow .
BY : SENATOR315 & COCO2012
CO2X is offline Find More Posts by CO2X
Old Feb 09, 2013, 10:39 PM
CO2X is offline
CO2X's Avatar
Joined Oct 2010
OctoTOWER
...more
Old Feb 10, 2013, 04:47 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
People have used the shafts from an old CD/DVD computer drive.
There is one either side that the Laser bed runs along.
These are generally 3mm and just need to be cut down, just check with a digital caliper / micrometer..
Del-Dredd is offline Find More Posts by Del-Dredd
Old Feb 10, 2013, 05:14 AM
muddyfox is offline
Find More Posts by muddyfox
Joined Sep 2008
If I am in a need for a motorshaft like you, I use a stainless steel rod from old CD drives where the laser lens runs on. They have exactly 3,0 mm and work great as a motorshaft. Just cut them to size and use on the end where the motorbell is a collar, like the wheel stoppers on planes for example. Like this you don't need these e-clips.
Works fine for me every time. Hope that helped.
muddyfox is offline Find More Posts by muddyfox
Old Feb 10, 2013, 05:24 AM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
www.rctimer.com have a wide range of motor shafts at very cheap prices. I am sure you would find something there to fit your motors.
kaz1104 is offline Find More Posts by kaz1104
Old Feb 10, 2013, 06:16 AM
Todiolo is offline
Find More Posts by Todiolo
FlyingNotCrying
Joined Sep 2006
Wow! That is crazy! I'll be waiting for the movie.
Todiolo is offline Find More Posts by Todiolo
Old Feb 10, 2013, 07:56 AM
RobertSF is offline
Find More Posts by RobertSF
United States, NM, Santa Fe
Joined Feb 2013
Hey efx, getfpv.com has some motor shafts as well. They are in the motor section.
RobertSF is offline Find More Posts by RobertSF
Old Feb 10, 2013, 08:10 AM
Landor is offline
Find More Posts by Landor
Joined Feb 2013
Hello
This is my first quad copter and I have some problems with it.
I'm using kk2 board, flashed with 1.5 version and Turnigy 9X transmitter.
When I want to start motors, some of them have different rpm's; are spinning slowly. I have made ESC calibration (one by one, with receiver and also by pressing 1&4 buttons from kk2 board), but the problem is still there.
I tried to fly but it flips.
Now I think that it could be a problem from transmitter settings.
I'm attaching a picture with receiver test. First I have made the trim and subtrim adjustment, and I have moved only the Throttle.
It is normal to have those values for Aileron and Elevator when I'm moving only the Throttle?
Thank you!
Landor is offline Find More Posts by Landor
Old Feb 10, 2013, 08:20 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by Landor View Post
Hello
Thank you!
Are you using an Aeroplane model or a Heli model?
Sounds to me like you have something other than a NORMAL swash setup in Heli mode or you have some 'special' model of aeroplane selected.
thwaitm is offline Find More Posts by thwaitm
Old Feb 10, 2013, 08:25 AM
Landor is offline
Joined Feb 2013
I'm using an X quad copter (Bumblebee frame) and I have selected from TGY 9X the Heli 4 type.
The swash mix is like this:
PIT 60
AIL 60
ELE 60
