Oh that's cool |
I Flashed my ESC's and updated the firm ware on my KK2 board to 1.5. That fixed the motor problem that caused the quad to drop. I then trimmed the quad using my radio. I didn't know that you had to trim it just like you would a plane. I thought all that, was taken care of within the KK2 board ![]() Before trimming I did set my "I" gains to "0" and my P gains to 20 I then got the self level hooked up and turned on and it is now actually flyable ![]() Now all I have left is the tuning and I think it will be good to go! Randy |
Here's the stats for the esc:
Thanks!
-Brake: enabled or disabled (disabled default) -Battery type: Li-Po or Ni-xx (Li-Po default) -Low Voltage Cut off type: soft or hard (soft default) -LVC setting, Low, Med, High: (Li-Po - L 2.6V,M 2.85V,H 3.1V)(Ni-xx - L disabled,M 45%,H 60%)(medium default) -Startup mode: normal, soft, super soft (normal default) -Timing: Low, med, high (Low 2-4poles, Med 6-10 poles, high 12+ poles) (medium default) |
Temple, GA, USA
Joined Jun 2009
![]() Next step is FPV!
Temple, GA, USA
Joined Jun 2009
Sure, but this is why they also tell us to use the cell alarms. You should also test to see what times you get on your own setup before going way up. I already found out what it's like to lose transmitter signal while the copter is up in the air, the battery was fine. I'm still working on this, but those settings seem like the standard options on most esc's. This is why I asked too. Good to know.
Okay, I just went out to test the new tx and receiver and although things looked fine, I thought okay, I'll take it up a bit...as it was going up I brought the throttle down a bit and when I tried to go up again, it's as if I lost signal again. So I'm not sure what's happening at the moment. The battery was fully charged and this happened less than five minutes into the flight. So I'm wondering if my antenna placement may also have something to do with it. I'm just scratching my head at the moment. I'll have to stop going out at night so I can see what happens. I could see it, but I know I didn't do anything that would cause that. Anyway, testing sucks.
I guess three is the one...third crash broke one leg tonight. One antenna is tied on the esc's going straight up and the other on along the white arm. I figured this would keep them away form the props, but now that I type this I'm wondering if this is causing a problem with my loss signals...any ideas feedback, feel free to let me know. The board was reset with this new receiver to make sure I started fresh and I seemed to have gotten the same problem as before. Anyway, moving the antennas is the first thing I'll do next once I change the arm.
There is a magnetic field generated along the power wires and the esc which could cause interference in the receiver. |
Yes, I think I had another noob moment and totally didn't even think about that. The worst part is the the quad felt so nice and smooth when I started going up...man it sucks to kill that. This happened maybe like twenty or thirty feet up and was not very far from me so whatever did it sure had a major effect on it. At the moment I'm just assuming it could have been that. Next time I'll do a long range flight lower to make sure no signal is lost so even if it were to go down it won't hit too hard.
been very cautious and haven't broke anything I can't replace at the hardware store. One reason I made my own frame to learn with. GLuck! |
I don't suppose you have a small pack to run the reciever by itself.. to rule it out from a power drop and self reset
you could try a power protection capacitor also ..if thats the problem the capacitor just plugs into a spare channel between pos and neg pins simular to a bind plug |
I actually did that to see if the receiver was good. It seemed to work fine, this is why I went ahead and installed it. I also checked the other one I have and it worked exactly the same, so they are both working from what I can tell. I'm currently changing all the motors, receiver and controller board to my other kit since I don't have those motors or controller. I'll just have to wait until tomorrow since I need to dremel out some of the arm material to make that top plate fit the other quad. So I'll be testing the other 40 amp esc's and see what happens there. I'll be taping the antenna's to the side arms instead to keep them out of the props and anything else that may cause a problem with them. The arms are plastic so I hope that will at least help there in case that were a problem.
