They also have the same servo that is not high voltage.
http://www.hobbyking.com/hobbyking/s...06sec_21g.html Quote:
I use them on the 450 heli tail. As for breaking when you crash, frankly I think almost any servo will get ruined if hit just right. Ofcourse some faster than others. I like these because at least I know or at least they feel that they would hold up in the air a bit more than the plastic gears while doing fast or sudden maneuvers. As for a crash on any servo, that I think is pretty much a toss up. If they survive, then that's just a good crash.
They also have these similar spec servos but should be lighter with the plastic case. They look pretty good, but since the price was closer to the others, I haven't tried them yet. http://www.hobbyking.com/hobbyking/s...05sec_16g.html http://www.hobbyking.com/hobbyking/s...10sec_16g.html Quote:
They have the default settings. Motors sound fine, no abnormal noises. I used 4 different batteries. 3-300/3S & 1-4000/3S and I'm using a Passport Ultra balance charger. I will reset to the lower Gains and see what happens. Tnx! |
Temple, GA, USA
Joined Jun 2009
![]() It may take 50 or so to correct a medium drift. Don't be afraid to jack in a larger number if a smaller one doesn't fix it completely. I think of it as 10th's of a degree "out of level". |
Temple, GA, USA
Joined Jun 2009
If you start out with the transmitter trims correct for rate mode (non-self-leveling), switch to self-level mode and change the transmitter trims to make it level, you have just unleveled the rate mode. Sure you can use the transmitter trims for self-level mode, but understand that every click of trim is making rate mode more out of level. Make it as correct as possible with the correct procedure first. Tx trims for rate mode, then acc trims for self-level mode. |
I'm using a "dynamite Passport Ultra" charger. I have been using "balance charge" on all 4 of my batteries. I happened to notice that the ma reading was only going to 700 then the charge would terminate and say it reached capacity. I thought that was odd. Also it would only take 17 minutes to charge a 3000mah battery. TaDa.... There is a setting called "Max Charge Capacity" that was turned on as a default and it was set for 700ma. So my batteries were only getting a 700ma charge. I turned it off and am charging all the batteries now. Thank you Casey at HobbyTown for helping on this! I kicked Murphy again!!!
Japan, Tokyo
Joined Jun 2011
On the tri, the servo is well protected, there is leverage from the motor atop the mount but it should pop the links or snap the horn before the shaft shears off... IMO. You can buy replacement gears for it but they are not widely available and reputedly have the same weakness. |
Can you upload a picture of that for me. I would like to see where they break as I have not seen that. Thanks.
Okay, I went out for another test and found out my tx stopped displaying the ppm on the screen. Everything turns on but apparently I have lost signal which caused another quad crash. Well at least I'm testing the durability of this quad and so far nothing has broken yet. It was pretty high up this time I'll post the video once I get that uploaded. In any case I opened up the futaba tx to take out the LED's I had put in it. I think that was taking up too much battery as I'm still using the original ni-cd as it works great. At the same time I thought I desolder the ppm lead from the trainer port to untangle it and make the wires a bit nicer. As I went to put the cover I noticed that the ppm was turning on and off on the screen, so I open the case again and checked the wires, everything seems fine, but still nothing on the screen. Everything else shows on the screen. I'm using the flydream DIY kit on this and the LED turns green like it's supposed to. Anyone have any idea on the ppm. I guess I got no signal until I can get that back to show up on the display. I have no idea what the heck happened, but I sure can't get the ppm or pcm letters to display on the screen. I can change the settings which I did just to see if it would work, but I changed it back to ppm and still nothing. I can get signal near the quad, but once I'm about 15 to twenty feet now, down it goes. Here's what I'm looking at. The module seems to turn on fine. Well now I know what it feels to lose complete signal, the quad likes to flip itself over and over until it hits the ground...
Japan, Tokyo
Joined Jun 2011
This is what happens when it lets go though...
Joined Dec 2007
