Old Jan 29, 2013, 12:20 AM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I think he means me or not, but if you read the description on the video I mentioned that I then chose the low setting again and have no problems at all which is what I wanted to use to begin with. I was just showing what happens when you push them I guess. I'm sure that setting will work with higher kv motors.
efx is offline Find More Posts by efx
Old Jan 29, 2013, 12:58 AM
RC_Adik is offline
Find More Posts by RC_Adik
RC flying addiction
Joined Dec 2012
Originally Posted by harrym View Post
I seem to have run into a bit of a problem and I'd like some input!
Both my quads are 600-650 mm
Total weight with 3K/3S battery = 1224g / 2.7lb - 1353g / 3lb
FC - Both have KK2 v1.5
Setup #1 (DIY)
Speed Controllers - Turnigy Plush 25a (Stock)
Motors - Turnigy 2217 20turn 860kv
Props - HobbyKing HCB-09 9x5 / GemFan - 10x4.5
Battery - Turnigy 3000/3S (New) & Turnigy 4000/3S (New)
Setup #2 (X525)
Speed Controllers - Turnigy Plush 30a (Stock)
Motors - iPower 2217-930 (930kv)
Tnx!
I wouldn't think that a 10x4.5 would be over propped on a 860 or 930kv motor on 3S, but are they hot and/or the ESC's hot??
Is the ESC timing low, (default in most cases)?
The PI tuning may be a contributor to your battery consumption, but I suspect there is more to it than that.
My 450 Quad with camera weighs about 1000g, has 920kv motors, 10x4.5 props and uses 1600 to 1700mAH consistently for a 8 minute flight with the KK2 v1.4.
RC_Adik is offline Find More Posts by RC_Adik
Old Jan 29, 2013, 01:03 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by Freakazoid View Post
75? Thats triple the gain ive got and its like herding a strung out cat already. Isn't standard settings like, 35 or something?
Dont tell me this is one of those 0=100% kinda deals.. Because then ive been going the wrong direction.
Not sure what unit gain is, but it's not % like the old KK. Anyhow higher number means more gain. As a reference, on the old KK board it would oscillate above 30%. 75 was not a maximum value. I will try to test it some more this evening. Need to calibrate the ESCs through the new board first.
Fred
flarssen is offline Find More Posts by flarssen
Old Jan 29, 2013, 01:07 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
efx
tech69x is offline Find More Posts by tech69x
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Originally Posted by RC_Adik View Post
... but are they hot and/or the ESC's hot??
Is the ESC timing low....
The esc's & motors are just barely warm after 2-3 min. About as warm as
when it flew for 7-9 minutes before tuning. Nothing out of the ordinary.
I'm going to back the tuning down close to defaults and see what happens.
Nothing else has changed and it is odd to be doing it on both setups.
These are stock esc's. I guess they are set for low.
Everything was fine until I messed with the Gains.
That's why I posed the question about Gains & power consumption.
Tnx!
harrym is offline Find More Posts by harrym
Old Jan 29, 2013, 01:31 AM
RC_Adik is offline
RC flying addiction
Joined Dec 2012
Tnx!
You also mention going from 9x5 props to 10x4.5 props and that has to effect something. It may have taken the motors out of their
most efficient zone, but that is only speculation on my part.
My Pitch and Roll = P Gain 70, Limit 80. I Gain 20, Limit 20.
Yaw is default of v1.4, stick scaling is default also.
I would think for a good, (yours) 550 setup your values might be slightly higher.
I also do not have Simon K ESC's.
It will be interesting to hear your results after turning the gains down.
Old Jan 29, 2013, 02:04 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Originally Posted by yuri karlwithaka View Post
I'm getting jittering with one of my servos mainly on pitch, details in youtube link
is the problem bad or weak servos? (also i'm aware that its not setup perfect yet on the control board)
http://www.youtube.com/watch?v=keVMZ7-67Ww
Similar problem over here was found to be the servos:
http://www.rcgroups.com/forums/showthread.php?t=1818034
Steveis is offline Find More Posts by Steveis
Old Jan 29, 2013, 02:05 AM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
yeah them too
I already have mine tho, from a trade on here a while back
I know where to get replacements now tho thanks
Originally Posted by efx View Post
Or you can just get this one which works just as well and it's cheaper. I know, I have a couple of them on my 450 tails.
http://www.hobbyking.com/hobbyking/s...05sec_21g.html
irun4fundotca is online now Find More Posts by irun4fundotca
Old Jan 29, 2013, 03:08 AM
Flying Wood For Fun
Joined Jan 2012
Hey I found two of those same servos in my box I had for spare parts I will test them out and see what difference there is between a few others I have, and let you know what happens
Old Jan 29, 2013, 03:51 AM
teccer1234 is offline
Find More Posts by teccer1234
safer on the ground
teccer1234's Avatar
wilts, United Kingdom
Joined Jul 2006
Originally Posted by theothercliff View Post
32 bit is usually the easiest. I understand that there are some geek hoops to jump through for 64 bit with LazyZero.
thanks
ray
teccer1234 is offline Find More Posts by teccer1234
Old Jan 29, 2013, 04:00 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Originally Posted by Steveis View Post
I have a trial version on my blog. I don't have CPPM so can't test but it should work, given my previous version worked with CPPM Roll and Pitch CPPM channels are on CPPM channels 6 & 7. Please post feedback on my blog if it doesn't work as expected.
Many thanks - I'll download it and flash it later today, but it might now be tomorrow before I get to test it.
GordonTarling is offline Find More Posts by GordonTarling
Old Jan 29, 2013, 04:20 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
While preparing my Quad with the MegaPirate board, and allow WayPoints navigations ...
I did want to make a quick check with the always reliable and easy to trim KK 2.0
I did upgrade to 1.5 the Firmware ... use almost the stock setting ... just increase some parameter by few units, since I have SimonK ESC in this quad ...
And ... here is the result on the cold ... it was around -5 while I was testing it.
Here is the result:
Aerial Video - HobbyKing Quadcopter Frame V1 + KK2.0 + KeyCam #11 (0 min 0 sec)
All in all .. the KK2.0 proven to be an excellent board, now autolevel is much more accurate, and it give better confidence on flying.
Only minus for me ... missing Magnetometer ... and no GPS connectivity.
I'm sure that KK firmware with these extended functionality will make immediately useless all the other control board
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Jan 29, 2013, 04:31 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Here is the result:
http://www.youtube.com/watch?v=9kvwyAbyjC4
Tchuss
e_lm_70
Sure does look cold and ya a GPS for this FC sure would be nice how have you been btw
Old Jan 29, 2013, 04:51 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Winter time is a slow time
I got interested on MultiWii first, and then on MegaPirate
Too many projects on going ...
Since the KK2.0 is very stable, maybe it can make sense to:
- Add magnetometer ... hacking the code for it should be easy ... add the magnetometer module cost 5$
- Add GPS ... external navigation board 7$ ... GPS 23$ ...
Not sure I will do any of this project
I'm also working on making a ultra portable TX ... acceleration based TX
So ... too many things going on ...
Anyhow ... respect for the KK2.0 board ... I'm sure that if Mr KK will adopt the same chip as Teensy 3.0 ... add a magnetometer ... then it will have lot of power for have GPS as optional, and full navigation with the same format and with same LCD ... it will be mega cool
Old Jan 29, 2013, 04:57 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
I wish you would this board with a mag and GPS it would make the big boys stand up and take a look
