First off you want to start with your p gain
Latest blog entry: Win a frame
What is your servo doing
What does it do with autolevel on
It becomes slightly easier to keep it in a hover, but still quite a bit of jitter/drift.
With autolevel off it get much worse. Currently ive got it on P-Gain=25, P-Limit=100, I-Gain=0, I-limit=100 With this I can just barely keep it under control, but its atrocious compared to my old KKuk board. Are there any values that would run the same as the old KKuk with 4.7 firmware, pitch/roll pots set to about 20%? |
From efx
"Each esc setting is...brake - off, batt type -li-xx, cut off - soft cut, cut off voltage - med, start mode - very soft, timing - middle, music - none, gov - off" Some of those settings are not the standard used for Multicopter use, so may cause issues. Brake off - good Batt type usually set to Nicad even though using Lipo's. Cut off - soft ok Cut off Voltage should be min or off (thats why you use battery monitor) Start Mode usually normal or fast. Timing depends on motor but medium should be ok. The main reason for setting battery to Nicad and low or no cut off is so you do not get power drop off to the motors at an inopportune moment. With Lipo and Med volt set you will likely get one ESC shutting off power before the others, good way to crash. Use of battery monitor for individual cells highly recommended, that beeps when cell gets low. You can get ones that you can set alarm voltage at required value cheaply enough. Deyrick |
Front right = counter clockwise Tail = counterclockwise I can confirm all rotations and servo movement is in the correct direction, as I can maintain a bumpy flight. Pitch/Roll is P-Gain=35, P-Limit=100, I-Gain=40, I-Limit=30 Yaw is P-Gain=50, P-Limit=30, I-Gain=40, I-Limit=20 Selflevel is P-Gain=40, P-Limit=20 Ive jacked stick scaling up to 100 because I hate lazy sticks. And here I was, thinking this would be simpler than setting up a multiwii controller.. -_- |
United States, NY, Albany
Joined Sep 2012
Don't worry, probably still easier than MWC since you would have 10 times the buttons and knobs to play with and half the time the BT connection would not save the settings anyways ( presuming the software didn't crash first for no apparent reason ).
