Old Jan 26, 2013, 06:05 AM
* fly fast - live slow *
Seebodener's Avatar
Seeboden in Austria
Joined Dec 2008
Originally Posted by GordonTarling View Post
Thanks, but not sure what you mean - change transmitter throw settings to give +120 and -120 on roll and pitch channels?
I was trying to get my camera gimbal to work this afternoon, but the servos only move to one end and stay there - changing settings in the KK2 didn't seem to make any difference. I've obviously got hold of the wrong end of the stick somewhere!
Gordon,
I had the same problems and I needed some time to figure out how to solve them.
I will describe how and what I did and at the end I will post some pics just in case my explanation aren´t that clear cause english is not my native language.
First I will say that the new Steveis SW is INCREDIBLE ...
I am only missing the possibility to swap from NORMAL to SL during flight via a switch
and YES: you can change the Roll-/Pitch-Offset during flight and it will level this new position
Pic. #1
Befor I flashed to Steveis SW I fitted the CamStabSetup to the needs of my gimbal.
Than I flashed KK2 with Ver 1.5_new.
Pic. #2:
As I use CPPM I only have one cable input to KK2.
Pic. #3:
On the right you can see:
M1 ... to M4 are set according your needs for Ail, Thro, Elev. Rud
M5 ... a SportsBEC is connected to provide power for the Servos
M6 ... not connected
M7 ... Roll-Servo
M8 ... Pitch-Servo
Pic. #4:
In my Tx I assigned Channel/Servo 5 + 6 each to a Knob/Poti to make the servos move. EndPoints + servo travel are set to maximum.
I hope I can do some video soon.
I hope my explanations are understandable ... hope they help
BR Jörg
Seebodener is offline Find More Posts by Seebodener
Old Jan 26, 2013, 06:11 AM
serjuro's Avatar
Romania, Europe
Joined Aug 2009
Originally Posted by WendoNZ View Post
The only reason you would need a second board, would be if you were flying an octo and had used all the outputs driving the motors
Hi again, so if I use just 4 outputs because I build a quad, I could use aonther 2 putputs for camera gimbal, so the board steers the quad and the gimbal IN THE SAME TIME ? If so, GREAT.......
serjuro is offline Find More Posts by serjuro
Old Jan 26, 2013, 07:06 AM
United States, MI, Morrice
Joined Jan 2013
Yes, you just need to flash 1.5 and have power to one of the M2 to M6 connections.
VENOMOUSDUCKY is offline Find More Posts by VENOMOUSDUCKY
Old Jan 26, 2013, 07:13 AM
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Jorg - thanks for taking the time to explain that - helps a lot. If you're using the Steveis firmware, it seems to only support a quad - I'm flying a hexa, so I don't think it will work.
GordonTarling is offline Find More Posts by GordonTarling
Old Jan 26, 2013, 07:18 AM
Currently living to fly...
Japan, Tokyo
Joined Jun 2011
Originally Posted by Akcopter View Post
My Yaw P Settings are 90 ,P limit is 100 , I is 0,
You need to increase I to at least 20 I'd guess - mine is 30-35?... I'd have to check.
All the props have come from the same pack of props as it is...
So they all rotate the same direction? They are all 100% identical? Not a problem on a TRI but on a Quad it'll just spin one way... uncontrollably I'd hazzard.
what is the tracking on my props????...
Making sure the two (or three) prop tips all rotate on the same plane, i.e. one tip isn't higher or lower than any of the others as it rotates past a certain point - look at tracking for helicopters - basically the same thing but will depend on if the prop is well seated on the motor/prop adapter shaft. Bad tracking can increase vibration.
I have somewhat solved the problem of the inadvertent yaw by using trims ,But now I have a problem with the quad gaining height when I apply yaw control using my sticks...when I yaw to the right the quad gains height but when I try to yaw keft It does not ...all it does is nicely yaw to the left...what I see here is the natural tendency of the craft to yaw to the left....I tried to decrease the stick sensitivity on the yaw axis and this again solved this problem somehow, but then yawing to the right became very difficult.... I thought some pro users here could help me with this problem by suggesting some changes in the mixer editor offset settings....(I used the offset settings to offset the tail servo on my tri-copter to provide better yaw compensation)...but here the situation is different as on a tricopter only the servo is used to control yaw so changing the offset there would help me with the yaw axis ...but on a quad two motors are used at a time to yaw...so I will have to change the offset setting on both of them..So I am experimenting and stumbling....
I'd think you'll need to reset the offsets to zero once you get the I value in range.
I flashed my esc's with the latest simonk release(2012 -09-10)....and then tried to see the difference by flashing the wii-esc firmware...I am yet to derive any conclusions from these tests...so i will most probably post a video illustrating my problems..........
Video is always good and Simonk also.
Keep going - and add that 'I' as theothercliff suggests.
thwaitm is offline Find More Posts by thwaitm
Old Jan 26, 2013, 07:31 AM
Joined Apr 2012
I will try that cliff...
And It works Awesome .....Thank you cliff ...It makes me realize now how someone who thinks he is good at tuning PID's may have to start all over again...at a beginner's level and learn to do it all over again.....thank you... It was the I term indeed which helped me stabilize the yaw......and now I can summarize what was happening ...increasing the yaw P gain caused the motors which were supposed to compensate the yaw to the left to speed up very fast causing the copter to gain height this was because the other two motors did not slow down enough to let the yaw torque take effect due to high Pand I gains on the roll and pitch axes which were stopping the copter from pitching or banking......so I decreased the yaw P gain and increased the Yaw I gain gradually...then I saw my problem was getting solved as I slowly moved the I gain up and then found the sweet spot...because of the I gain the error was getting accumulated over time as my copter was yawing to the left and then the accumulated error helped the copter provide adequate compensation...So I am happy now that others can learn from what I went through......(Gosh !! Tuning PID's can really be frustrating ......)
Akcopter is offline Find More Posts by Akcopter
Old Jan 26, 2013, 07:35 AM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
I'll have to look, but I think you are correct, if you want Tx gimbal offset controll you need another input and it comes at the expense of 1 more motor pin and there are only 8 ( 6 + 3 = 9 ). The stock 1.5 does work with hex + gimbal.
That said I am working on a CPPM only firmware that will integrate gimbal control and support octo + gimbal since we can reclaim the inputs for motors. It's just taking time since I want to better understand the underlying code before mucking with PWM generation.
brontide is offline Find More Posts by brontide
Old Jan 26, 2013, 07:44 AM
Joined Apr 2012
thwaitm::::---
I DID THIS AND YES THE I TERM WAS THE SOLUTION.....
YUP I CHECKED MOTOR AND PROP SPIN DIRECTIONS AND EVERYTHING WAS PERFECT.....
TRACKING IS SOMETHING NEW I HAVE LEARNT .... SO I CHECKED AND THE PROPS SIT FINE ON THE MOTORS ..VIBRATIONS ARE MINIMAL ALMOST ZERO... I USE LASER BALANCING... SO VIBRATIONS-NO ISSUE
YUP I DID THAT AND IT WORKS GREAT
I USED THE SIMONK AND THE WII-ESC BOTH OF THEM AND I FOUND THAT BOTH OF THEM DO THE JOB EXTREMELY WELL...MY SETUP IS DT750 MOTORS WITH 10X4.7 PROPS AND F-30 ESC'S...I FOUND THE WII-ESC'S A BIT MORE QUITE AND SMOOTH ..THE WAY MY MOTORS SOUND ON WII-ESC'S IS BETER THAN THE SIMONK (2010-09-10) RELEASE.. SO I AM GONNA STICK WITH THOSE BUT YOU CAN GO WITH ANY OF THEM ..AND IT WILL BE GREAT....
THANK YOU SO MUCH EVERYONE FOR ADDRESSING MY PROBLEM..I THOUGHT I HAD A GENUINE PROBLEM HERE BUT THEN I TURNED OUT TO BE NOTHING BUT GOOD OLD PI TUNING...
Old Jan 26, 2013, 08:12 AM
Seebodener's Avatar
Seeboden in Austria
Joined Dec 2008
correct, so far the new Steveis SW for Gimbal Control only works with Quads
that would be a great way to solve the actual limited field of application ...
and maybe it could be possible to integrate the possibility to change flight-modes (Normal + SL) via a switch as it is possible with orig. Ver 1.5
Jörg
Old Jan 26, 2013, 09:11 AM
Joined Sep 2012
Jörg
Yes, the SL on AUX would be unaffected in the CPPM firmware since all channels would be there and usable.
Old Jan 26, 2013, 01:22 PM
Joined Dec 2012
piezo output
Are there any details on the piezo output? Is it just 5v logic, or is it a square wave for directly driving a piezo element? My KK2 came from Hobbyking without a piezo, and I'd like to hook something up for low voltage alarm.
dack42 is offline Find More Posts by dack42
Old Jan 26, 2013, 02:09 PM
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Ive been trying to figure this out using the videos but I just cant get it right..
I just cant seem to see the difference between having P too high and having I too high.
Maybe its because of the size of this copter though..
What are good starter PI values for a small tricopter like this one?
I get P values around 15 where it barely becomes flyable, but that just seems too low.
I think I need to do something with I gains to get the wiggle out?
Freakazoid is offline Find More Posts by Freakazoid
Old Jan 26, 2013, 02:29 PM
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Anyone know if its possible to have the camera gimbal controlled by radio and also being stabilized by the board?
metalfred is offline Find More Posts by metalfred
Old Jan 26, 2013, 02:47 PM
V-tail is KING
RC911's Avatar
Norway, Troms, Tromsø
Joined Aug 2012
If you got a quad then you can use this firmware: http://www.rcgroups.com/forums/showp...51&postcount=1
RC911 is offline Find More Posts by RC911
Old Jan 26, 2013, 03:10 PM
Specializing in RC since 1972
Temple, GA, USA
Joined Jun 2009
Originally Posted by VENOMOUSDUCKY View Post
I did calibrate the ESC's with no noticable difference, but after I went to bed I realized that the power wires on the M2 to M4 ESC's were not connected. Does this matter? If not, my next step is to increase the I gain.
Stock settings were used after the 1.5 flash. I did try to increase the I gain on 1.2 but no luck there either.
For a multicopter with no servos, you don't need power on M2-M8. It is OK to disconnect the power wires on the ESC servo connectors. I would not disconnect the ground wires or the signal wires though. You will get a ground via M2 ESC -> battery -> M1 ESC -> KK2, but you can get a voltage differential across the cabling between ESC's and the battery. There isn't really a perfect way to do this given 4 separate ESC's.
I gain (and perhaps I limit) on yaw in particular.
theothercliff is offline Find More Posts by theothercliff
