Old Jan 24, 2013, 02:49 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Originally Posted by yuri karlwithaka View Post
I have a
and I can't get power to servos on motor 7 and 8. from reading a big it looks like I need to get some power on m2-m4 but all my power comes in on m1 because thats where kk2.0 gets its power from (so i had to switch my motor 1 and 3 from my esc to compensate as described by this guy with a similar setup to me http://www.rcgroups.com/forums/showt...1711602&page=2 )
but ya. HOW DO I GET POWER TO M7 and M8 with my setup?
Unless your cables are configured differently, it appears that the cables at M7 and M8 are plugged in backwards.
Signal (white or light brown) goes to the right
Power (red or orange) goes in the center
Ground (black or dark brown) goes to the right
rcjose is offline Find More Posts by rcjose
Old Jan 24, 2013, 02:53 PM
rcjose is offline
Joined Aug 2010
Originally Posted by efx View Post
Good video jose, never thought about that red lead since I havent done too many. Here's the short video i did on them when I started too..i thingk the link to the pictures shows the process better.
https://www.youtube.com/watch?v=n-4Dvg78fHc
Old Jan 24, 2013, 02:55 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Plug a BEC into M5 or M6. Since your quattro powers the KK2 it is NOT recommended to use the same BEC for your servos.
brontide is offline Find More Posts by brontide
Old Jan 24, 2013, 03:07 PM
yuri karlwithaka is offline
Find More Posts by yuri karlwithaka
Canada, ON, Toronto
Joined Jan 2013
Sorry I'm kinda dumb when it comes to electronics, BEC has to be plugged into m1 for power to kk 2.0 board. How would i get another BEC for m7 and m8
(manual for my esc http://www.google.ca/url?sa=t&rct=j&...41524429,d.aWM )
yuri karlwithaka is offline Find More Posts by yuri karlwithaka
Old Jan 24, 2013, 03:32 PM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
A second BEC can be connected to centre (+) and right (-) pin on any of M2-M6. They are all free in your setup.
Fred
flarssen is online now Find More Posts by flarssen
Old Jan 24, 2013, 03:36 PM
Canada, ON, Toronto
Joined Jan 2013
Fred
how do i connect that to my esc?
Old Jan 24, 2013, 03:38 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Does anyone know where to find something like this for the 450 quad, but cheaper?
http://www.ebay.com/itm/Universal-Ca...item20cdcb1f38
efx is offline Find More Posts by efx
Old Jan 24, 2013, 03:47 PM
brontide is offline
Joined Sep 2012
In your setup m5 and m6 are empty, you don't need to connect it to your ESC, only to the middle(+) and outside (-) pins which are shared with your servos m7 and m8.
Old Jan 24, 2013, 03:53 PM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Originally Posted by GordonTarling View Post
Thanks Andrew, but good as it might be, that firmware can't be used on a hex. Certainly worth a try if you're flying a quad though.
Sorry missed the hex part. If you used CPPM then that would free up connections and I'd bet more than a cup of coffee that Steve could do a version that would do the job. But it's not for me to know.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jan 24, 2013, 03:54 PM
Canada, ON, Toronto
Joined Jan 2013
can you draw me a diagram or something please? i know its kinda out of your way but im still a bit confused
Old Jan 24, 2013, 03:56 PM
Son, Norway
Joined Sep 2004
Originally Posted by theothercliff View Post
I see no such thing (male in wide sleeve) in these pictures. Perhaps you confuse wire color with pin sex.
I'm not confused. I thought we were discussing the pictures in this thread. There is no right or wrong way to do this. As long as one is consistent, they will fit nicely together.
As I said, I avoid connecting a pack to another pack by separating the connectors on anything that connects to the battery (I usually drop the plastic here and use heat shrink on those in stead). Once you are used to connect one wire at a time, a bell should ring if you suddenly try to connect a pair against another.
Fred
Old Jan 24, 2013, 04:03 PM
Son, Norway
Joined Sep 2004
You need one like this.
Connector goes to M5 or M6, the input wires should be connected to the battery like your ESC is.
Fred
Old Jan 24, 2013, 05:47 PM
VENOMOUSDUCKY is offline
Find More Posts by VENOMOUSDUCKY
United States, MI, Morrice
Joined Jan 2013
Hello, I have been out of the hobby a while and decide to build myself a quad. Has anyone had problems with yaw drift? I have tried to research this problem, but only come up with tri yaw issues. Here is a pic of my set up, I am wondering if it has something to do with board placment.
VENOMOUSDUCKY is offline Find More Posts by VENOMOUSDUCKY
Old Jan 24, 2013, 06:03 PM
brontide is offline
Joined Sep 2012
Make sure you ESCs are calibrated and take a good hard look across your motors and props to see if one or more is tilted and creating directional thrust.
Old Jan 24, 2013, 06:16 PM
Joined Jan 2013
Thanks for the quick reply. That is one thing I have not done yet is calibrate the ESC's. For someone reason I think it will make them not work. Here we go!
