Old Jul 18, 2012, 03:11 AM
drifter1949 is offline
Find More Posts by drifter1949
Helper
drifter1949's Avatar
Joined Jul 2011
Hi, would someone please list all the default tricopter settings for the KK2 board as I have been adjusting all the settings and don't know what the default settings were anymore, or is there a way to reset the board to the default settings, the only reference I can find is how to set the LCD contrast and that is not what I am looking for.
drifter1949 is offline Find More Posts by drifter1949
Old Jul 18, 2012, 03:52 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by eirikso View Post
I increased the stick scaling to 80% and got quicker flips and rolls, and still a pretty controllable quad:
Maybe stick scaling to 100% and EXPO to -40% will do...
Or as mentioned elsewhere in this thread as well: two flight modes on the TX.
what is that clicking we hear during the vid? , you use switches?, if so why?
jaccies is offline Find More Posts by jaccies
Old Jul 18, 2012, 04:59 AM
Toumal is offline
Find More Posts by Toumal
Joined May 2006
I have a quick question for Rolf:
What model of LCD is used on the KK2 board?
Toumal is offline Find More Posts by Toumal
Old Jul 18, 2012, 05:21 AM
muddyfox is offline
Find More Posts by muddyfox
Joined Sep 2008
Hi there,
I am a newbie to quads and have got myself a KK2 FC board.
My question is:
When connecting all four ESCs to the board should I leave any 3 red wires off the plug and supply power just with one ESC wire (red) to the board? Or can I just plug them in as they are?
As you see I am a little confused here and hope you could help me out on this.
Thanx to all.
muddyfox is offline Find More Posts by muddyfox
Old Jul 18, 2012, 05:35 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
Originally Posted by muddyfox View Post
Hi there,
My question is:
Thanx to all.
No need to remove any pins, only M1 output actually supplies power to the board.
Mike Barton is offline Find More Posts by Mike Barton
Old Jul 18, 2012, 06:05 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
Originally Posted by wazzer View Post
It should be perfectly feasible to get your Tri flying well without the Simonk firmware update.
However using the updated ESC firmware should allow you to make it better.
You need to make sure you are able to flash your ESC as the Plush series changed the microchip from Atmega to Silab if you have Silab then it cannot be done right now.
The only way to check is to remove the heat shrink from your esc and take a look.
Take a look at the thread dedicated to this topic
http://www.rcgroups.com/forums/showthread.php?t=1513678
Be warned its a very technical and LONG thread!
I will be kind and point you to this video it explains everything.
http://youtu.be/NZsT0agRZMY
I read the whole thread and figured out how to get the simonk esc update but can you just point to a video showing the effects of the updated and non-updated esc's on any multirotor platform
Akcopter is offline Find More Posts by Akcopter
Old Jul 18, 2012, 06:06 AM
muddyfox is offline
Joined Sep 2008
Thanx Mike for that greased lightning fast answer
I just asked so I would not fry my spick and span new KK2 board.
BTW: How much volts is the board able to take?
Cheers, Peter
Old Jul 18, 2012, 06:25 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
Hey hallstudio do you use simonk flashed esc's or are they just the usual lot.....,
And also I am a lousy pilot especially for quad's,and tri's...so if i take it slow with the kk2 board what settings should I use for stick scaling(I know that you use 80 on elevator,rudder and ailerons ) and if I decrease the stick sensitivity is there a need for me to increase the Pi gains
Old Jul 18, 2012, 06:32 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
Cheers, Peter
Hey muddyfox ,the board can take the 5v supplied by the esc's and only the M1 port is used to power the board,in case you want to use the board for applications which require servos to be connected on the other ports then you will need to provide power at any port from M2-M8.. also the bec's in the esc's provide 5v,no matter which battery you connect to those esc's (Obviously the esc must be compatible with your battery type) anyhow even if you connect the board with any number of esc'c having linear Bec's you wont fry the board
Old Jul 18, 2012, 07:16 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Originally Posted by fallingdown View Post
Yeah you really need a high speed digital servo... At a minimum spend $20 for a good one. I have a $5 analog metal gear on my tri and had to really turn down the gains and tune it to get rid of the wobble... after that it flies just like the original kk. But after upgrading the servo I could bring the gains back up to stock settings and is nice. FYI, metal gear servos will induce more vibration than nylon gear.
Any suggestions on an appropriate servo to get? Working towards my first tri so I'm expecting to crash quite a bit, so cost effective and durable rate highly.
thanks, Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jul 18, 2012, 07:21 AM
Banjo5 is offline
Joined Jun 2012
Originally Posted by kapteinkuk View Post
I will add a configurable low pass filter for the servo outputs, to avoid excessive shaking and premature servo failure when using low-end servos.
Do you have any rough idea on when this update would be available?
I'm not pestering, just wondering if it's days, weeks, months ... or I guess if shorter/longer than the time to get a new servo from China to Canada.
Thanks for all your efforts. Sure looking forward to trying a tri. I have just about all the parts now, so time to start building.
cheers,
Andrew
Old Jul 18, 2012, 07:50 AM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Already asked and answered a few pages back...
"JHD12864", 20 pin, 0.5mm pitch connector.
HappySundays is offline Find More Posts by HappySundays
Old Jul 18, 2012, 11:33 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Do a search on youtube for simonk and there are a few videos there.
not many showing a before and after comparison but allot of people in the esc flashing thread say how great it is.
Even KK him self has all the defaults on the KK2 to suit SimonK Flashed esc he wouldnt do that if it wasnt good.
Borneoben is offline Find More Posts by Borneoben
Old Jul 18, 2012, 11:44 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
http://youtu.be/EdFEfOQof1U
Now that's much tighter. Better, I think. You can still flip slower if you want. Just use less cyclic. Been busy all day today but I will try this with my quad again, probably tomorrow. In this regard, your posts have been super helpful. I feel much more confident trying flips this time around. Thank you very much!
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Jul 18, 2012, 11:53 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
I am not doubting the firmware I just want to know if it is worth it..I don't know if my turnigy plush is atmega or silab and to cut open the shrink tube will expose the electronics leaving me with nothing to cover them with....so just in a bit of a fix here...
