Old Jan 01, 2013, 11:36 AM
wattie x is offline
Find More Posts by wattie x
wattie x's Avatar
France, Languedoc-Roussillon, Lunel
Joined Jan 2012
Originally Posted by kaptondave View Post
You have posted exactly the same thing previously posted by kaz. Applicable only to Atmel chips. Not compatible with the newer Turnigy Plush ESCs that are the subject of my question.
Hello, take a look at here for flashing silabs based esc.
http://oddcopter.com/2012/07/18/flas...heli-firmware/
theothercliff, excuse me, haven't seen your post before i posted
wattie x is offline Find More Posts by wattie x
Old Jan 01, 2013, 12:02 PM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Oh dear, I'm afraid that just isn't a pardonable offense, except for the hundred times I have done it!
theothercliff is offline Find More Posts by theothercliff
Old Jan 01, 2013, 12:16 PM
Diazapamjam is offline
Find More Posts by Diazapamjam
Bayou Boy
Diazapamjam's Avatar
United States, LA, Houma
Joined Nov 2012
Anybody know the best way to set up the kk on a f450 flamewheel? So holes have to be drilled?
Diazapamjam is offline Find More Posts by Diazapamjam
Old Jan 01, 2013, 12:36 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
When I drilled holes for my KK2 board into my 450mm DJI clone frame, I had to drill through a portion of the arms because 45mm was too wide.
They might have switched to 44mm to better fit 450mm frame centerplates.
AcroFPV is offline Find More Posts by AcroFPV
Old Jan 01, 2013, 12:37 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
double side foam tape
TheFernMan is offline Find More Posts by TheFernMan
Old Jan 01, 2013, 01:26 PM
Bayou Boy
Joined Nov 2012
Also why is a good motor I was looking at sunnysky angel 870 kv or the 1000kv
The motors I have now are only 90 watt and I think I need a bit more
One more thing how do I correct my quad from yawing on its own
Old Jan 01, 2013, 01:32 PM
badbill is offline
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
I have used the Align gel gyro mounting stuff on several now and it works great.
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Jan 01, 2013, 01:51 PM
TraxxasSweden is offline
Find More Posts by TraxxasSweden
Sweden, Södermanland County, Katrineholm
Joined Jul 2012
Why just doesn´t use double side foam tape (example from HK) ??
I use it on all my quads and it works great!
And my question, why does not people use the foam box that the KK board arrived in??
TraxxasSweden is offline Find More Posts by TraxxasSweden
Old Jan 01, 2013, 01:54 PM
Joined Jul 2012
Have just made a 6pin usb asp adapter and updated the firmware to V1.5.
Will test tomorrow and se what happens.
How do you sensor calibration you boards? Could anyone upload a picture? Because I don´t really know how to do it..
Old Jan 01, 2013, 02:23 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
I use the foam box it came in but havent flown it much. 3M auto trim tape doesnt stick good to the foam so I used quick grip and just glued it on to the CF plate.
jrjr is offline Find More Posts by jrjr
Old Jan 01, 2013, 02:35 PM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
I have a couple questions
It seems to me when doing acc calibration that one would want the props level and not really care about the board. After all, the props are what are going to keep the bird level. Am I wrong in my thinking? I spent a great deal of time shimming the frame with a 2' level across motor shafts each way and got it right on the money before calibrating. Seems to auto level well so far but my testing is limited. Seems that as long as the board doesn't move and is fairly level to start with it should be ok. I don't see the need to perfectly level the board with the props.
Also, M1 is the esc that powers the KK2, check.
My 3 other plush esc's (quadcopter) each have a 3A linear BEC. Does this mean that the rest of the motor outputs share 9A of available output from the other 3 esc's or is this not how it works? Just curious.
Old Jan 01, 2013, 03:01 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
1) Make sure yaw is trimmed
2) ESC calibration
3) Props and motors are not tipped
4) Stiffer frame
A small amount of yawing can be normal for the frame, a lot is usually indicative of something activly wrong in the setup.
brontide is offline Find More Posts by brontide
Old Jan 01, 2013, 03:03 PM
brontide is offline
Joined Sep 2012
Correct, the important thing is that the props should be "level"
Old Jan 01, 2013, 03:15 PM
Bayou Boy
Joined Nov 2012
Yep that's it I looked down the frame and I got around 1/4 inch tilt on every motor !
Just ordered a flamewheel450 gonna retire the x525 for now
Old Jan 01, 2013, 03:49 PM
DeepEastKilla is offline
Find More Posts by DeepEastKilla
low'n'slow is the way to go
DeepEastKilla's Avatar
United States, MN
Joined Sep 2008
Ive seen some posts in the scratchbuilt section where people have tilted their motors on purpose for better stability/handling so really it must be that it should be level in relation to the frame, no!?
DeepEastKilla is offline Find More Posts by DeepEastKilla
