Old Jul 16, 2012, 08:13 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
No. I wanted it to always turn off the motors when the throttle is at idle.
kapteinkuk is offline Find More Posts by kapteinkuk
Old Jul 16, 2012, 08:16 AM
Sandav is offline
Find More Posts by Sandav
Time to learn to fly
Sandav's Avatar
Netherlands, Overste, Zwolle
Joined Feb 2012
Is it possible to make it an option in the next firmware version?
Sandav is offline Find More Posts by Sandav
Old Jul 16, 2012, 08:34 AM
MHefny is offline
Find More Posts by MHefny
MHefny
MHefny's Avatar
Egypt, Al Qahirah, Qism El-Nozha
Joined Sep 2011
Hey, Is there any Schematic diagram for the new KK2 board.
I want to to develop my own firmware on it.
Kindly advise.
MHefny is offline Find More Posts by MHefny
Old Jul 16, 2012, 08:38 AM
edje is offline
Find More Posts by edje
Joined Dec 2006
Originally Posted by kapteinkuk View Post
That damage is on the ground plane and should be no problem.
Does the back light turn on?
Hi KK,
Immediately after the "failure" I disconnected everything and hooked M1 up to a ESC. Backlight then flickered a couple of times. After that no response.
Today I inspected the board with a microscope at work but I couldn't spot any visual damage.
I see a lot of test points on the board. Are there any specific points I could check to diagnose the prob? Thanks!
edje is offline Find More Posts by edje
Old Jul 16, 2012, 09:15 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Hi Guys
Can anyone tell me more about the SimonK esc firmware flashing?
I have 30amp RCtimer esc which i believe are the same as Turnigy Plush (they work with the same programming card)
I would like to flash my esc but i cant find a tutorial anywhere
My Google Fu is weak.....
Ben
Borneoben is offline Find More Posts by Borneoben
Old Jul 16, 2012, 09:19 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
here you are.
dutchcommando is offline Find More Posts by dutchcommando
Old Jul 16, 2012, 09:20 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Originally Posted by wazzer View Post
Hi Guys
Ben
Good luck
Ric
chiloschista is offline Find More Posts by chiloschista
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
http://www.rcgroups.com/forums/showthread.php?t=1513678
There you go Ben, choice of 3 links to same thread.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Jul 16, 2012, 11:26 AM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
I will add a configurable low pass filter for the servo outputs, to avoid excessive shaking and premature servo failure when using low-end servos.
Awesome. I'm very glad to hear this!
Though I can understand the benefit of using quality digital servos, lots of us bought this $30 board to maintain a low cost platform and use other low cost parts with it.
rcbif is offline Find More Posts by rcbif
Old Jul 16, 2012, 12:25 PM
Joined Jan 2005
Thanks Guys!!
This looks doable!!
will give it a shot, when i have all the parts.
Cheers
Ben
Old Jul 16, 2012, 12:59 PM
tacitapproval is offline
Find More Posts by tacitapproval
Joined Mar 2012
"JHD12864", 20 pin, 0.5mm pitch connector.
Thanks.
I managed to find individuals of the same module with a 0.8mm pitch connector, but not 0.5, of course.
I guess I will have to order another kk2 and share the lcd between the two boards (not that I mind the excuse for another all that much ), unless someone knows of a source.
tacitapproval is offline Find More Posts by tacitapproval
Old Jul 16, 2012, 01:42 PM
rizky_p is online now
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Those are some sick flying. I cant seems to track mine and lost orientation when flying further away
rizky_p is online now Find More Posts by rizky_p
Old Jul 16, 2012, 01:46 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
im starting to like this board more and more everyday..still tuning it a bit but i can hover it hands off with little to no drift depending on weather conditions....
can anyone tell me how the hight dampening works and what the "desired" setting might be? i havent touched that yet...any extra info would be great...and yes i did read the first page, but i would like to know know more on it than what is there...unless there really isnt much else to say??
thanks
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Jul 16, 2012, 02:04 PM
Switzerland
Joined Feb 2008
Hi,
I just did another set of flights.
Beside loving this board more and more, I started to play with height dampening.
At first I set it at 10, limit 30. It seemed to me that autolevel becomes more stable and smooth. I increased it up to 30, but I noticed that throttle becomes too much soft to fly a little hard. I risked an unwanted hard landing, because throttle was not responding as before on hard braking.
At this point autolevel seems to be trimmed offset vs, manual mode trims.
Programming a double flight condition with individual trims could help, but it is not very elegant. An autolevel trimming offset in the code could be a nice feature.
The autolevel at my actual settings seems really good to do FPV and have a sort of "position hold", to look around. But controls become almost unusable for me.
I confirm that with new RapidESCs the response of controls is amazing.
I'm increasing stick scale by step now.
Best regards,
Ric
Old Jul 16, 2012, 04:34 PM
knobby1 is offline
Find More Posts by knobby1
Australia, NSW, Bradbury
Joined Dec 2007
Hey All,
Received my KK2 board yesterday afternoon in the post ~3:30pm, was up and flying within 20mins, this included fitting, wiring up and setting PID's to suit ....I've never been able to do that with any other FC, I have FreeFlight, HK-2&3, Rabbit, and Crius MultiWii SE....none of these were as easy to setup and have running this quickly. The fact of not having to use a PC to setup is a great idea, the LCD screen must be the best idea I've seen in many years.
KK, you've really done a great job helping new quad flyers with this board.
I run a cheap HK $11 450 DJI clone frame in X mode and the motors and props must be near perfect balance with these frames otherwise the gyros and accelerometers get the "yips".....the KK2 flys it fine, none of the other boards with accelerometers are as good or as stable IMHO, the FreeFlight board comes close and is a great flyer for me but takes way longer to setup and tune to my liking.
Took me three short 1min flights to get the KK2 all trimed and dialed in non-AL mode.... and with AL armed it was pretty much a hands free, non-wobble hover in no wind conditions. I'm impressed.
Admittedly auto-level is a tad on the slow side but is great for first time & learner flyers.... and for FPV-AP work, non auto level is brilliant and you can throw your bird around with ease, at least as good as the other higher cost boards, the adjustability and ease of setup of this cheap board has to make it the best "bang for buck" FC board out there.....
Well done Kapteinkuk..I'll be buying more of these for sure.
Cheers,
Smithy.
knobby1 is offline Find More Posts by knobby1
