Old Dec 24, 2012, 12:05 PM
Diazapamjam is offline
Find More Posts by Diazapamjam
Bayou Boy
Diazapamjam's Avatar
United States, LA, Houma
Joined Nov 2012
Is there sort of secret code to post a video here ? I posted on you tube and tried to link to forum but no luck I'm sure everybody would live to see me clip a power line??? Hang it in a tree, chase myself across the lawn , and a few other awesome crashes ???
Diazapamjam is offline Find More Posts by Diazapamjam
Old Dec 24, 2012, 12:31 PM
Senator315 is offline
Find More Posts by Senator315
iMultirotors
Senator315's Avatar
Australia, NSW, Shellharbour
Joined Aug 2012
When posting, click the insert link (blue one) and paste your YT link. That's it.
Senator315 is offline Find More Posts by Senator315
Old Dec 24, 2012, 01:04 PM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
I bought a couple a few minutes ago, but I was wondering, can you mess with board orientation?
My mini tricopter demands the board to be mounted in with a corner up front as is KKuk tradition,
there are no holes to mount the flat side front as this KK2.0 board suggests (its hollow where they would be).
Trouble?
Freakazoid is offline Find More Posts by Freakazoid
Old Dec 24, 2012, 01:15 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Trouble?
Yes, trouble for a tricopter!
If it was a quad you could switch between quad-x and quad + configs but for a tri? I don't think you have an option.
HappySundays is offline Find More Posts by HappySundays
Old Dec 24, 2012, 01:21 PM
Freakazoid's Avatar
Joined Dec 2004
Hoo boy.. there goes my minitri taildroop quickfix.
My miniquad has the same forced orientation but atleast with that I can get away with quad+ to fly it as a quad-x.
Bit bummed about the tri though, I guess the only option for that now is some icky multiwii.
Old Dec 24, 2012, 02:11 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
Is there sort of secret code to post a video here ?.....
On YouTube just below the video is a "Share" button.
Click "Share" then copy that URL to here.
harrym is offline Find More Posts by harrym
Old Dec 24, 2012, 02:22 PM
Bayou Boy
Joined Nov 2012
I tried to upload from URL but no luck I guess I just post link
Old Dec 24, 2012, 02:30 PM
Bayou Boy
Joined Nov 2012
This is my first flight
Quad is a x525 with kk2.0
All videos are on same pack last video is my crash that ended my flying for the day
Maiden flight (1 min 27 sec)
Quadcopter (0 min 37 sec)
Quadcopter crash (0 min 33 sec)
I had flown around 7 min these are some of the vids
If you look good you can see that one boom is bent in last video causing my crash
I replaced aluminum with wood boom
Old Dec 24, 2012, 02:38 PM
Bayou Boy
Joined Nov 2012
First flight
This is the boom
augerN is offline
Find More Posts by augerN
Cheyenne, WY
Joined Oct 2010
Originally Posted by theothercliff View Post
It sounds like your PI settings are still too high for your ECS's. Make sure all your ESC's are configured properly if running stock firmware. Fastest startup is REQUIRED. Disable Low Voltage Cutoff and brake. Standard procedure is to turn off Self Level and zero all your P I settings (leave the limits at the defaults?), then start with P at 1/4 of default (necessary for unflashed ESC's). Move pitch and roll P (up or down to set it below oscillation point). Move pitch and roll I (eye not el) up till it oscillates and then back it down till it stops. Having yaw set too high can cause problems too. I would turn yaw P up till it fights you trying to twist it by hand and yaw I up to make it keep fighting and not give up like P alone does. If you want to use self level then start at 0 and work up from there by maybe 2 at a time?
Thanks! All good advice. As I said I did the overhead check, pitch and roll are fine,twist/yaw it goes bezerk,like the Yaw GYRO is Reversed. Sorry I didn't mean to imply that I had never set up or flown a Quad before. The thing is I'm using SimonK flashed ESCs. Also the whole set up worked fine before the crash. I pancaked it when I was doing flips and rolls, didn't even break a prop, but split an arm where the landing gear attaches, arm split from there to the motor mount bolts. Moved every thing to a new frame, went thru set up, won't fly, set PID as per post 1, won't fly. Acts like it has a reversed YAW GYRO but if is impossible for a gyro to get reversed on this board then I guess its something else. I've had all the gyros get reversed on a KK 5.5 board in a crash but its easy to recognize and easy to fix on that board. I'll just switch the board out if it flys i'll know the board was bad.
augerN is offline Find More Posts by augerN
Old Dec 24, 2012, 03:18 PM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Trouble?
There is a way to handle this. The mixer editor. You first need to understand the difference between X and +, and then do something similar by hand to the Y configuration. Do you understand trig basics?
theothercliff is offline Find More Posts by theothercliff
Old Dec 24, 2012, 03:25 PM
Rotorhead0207 is offline
Find More Posts by Rotorhead0207
Joined Dec 2007
an even easier fix is to stick it on with double sided gyro tape, the kind used for r/c heli's
Rotorhead0207 is offline Find More Posts by Rotorhead0207
Old Dec 24, 2012, 03:28 PM
Freakazoid's Avatar
Joined Dec 2004
Dont suppose I can get away with just turning on a deltamixer in my transmitter?
That little trick used to work back ways before we even had quad X and +.
But a tricopter has something else going on so that probably wont work?
Theres nothing to stick it to, its a hollow frame with the board suspended by its corners.
Old Dec 24, 2012, 03:37 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
You have to use the "Share" URL!
It will look something like this...
youtu.be/biyS-Q0eNBE
It will have http:// in front of it.
Old Dec 24, 2012, 03:38 PM
Temple, GA, USA
Joined Jun 2009
http://www.youtube.com/watch?v=gHBV7X-k2Xk&sns=em
http://www.youtube.com/watch?v=KAFBuZqBMUw&sns=em
http://www.youtube.com/watch?v=L-gWO97HH8w&sns=em
Man, start small! All at head height: Very slow ten foot circles left and right, then figure 8's, then everything a little faster with slightly banked turns instead of slow and flat. Try to keep the copter pointed in the direction it is moving. A bigger flying area gives you room to "punch out" instead of chopping the throttle and landing hard, but I understand if the front yard is very convenient!
With helis it is important to develop the "pinch the stick between the thumb and index finger" method instead of the "thumb on top" method. You need at least a neck strap or to be sitting in a chair to do this, but it is necessary for you to easily control the throttle at the same time as the rudder (yaw) that is on the same stick.
There is a feature on the KK2 (Misc Settings -> Height Dampening) that will help you control your height to not get up so high.
Just some things that I learned about the hard way.
