Old Dec 15, 2012, 04:12 AM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Hi! I'm now using firmware 1.5. Self leveling is awesome. Just slight unstable yaw. Anyone knows how to correct this? P gain in self levelling is 75. I gain is 10. What should i increase?
DYORD is offline Find More Posts by DYORD
Old Dec 15, 2012, 04:13 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Got my first KK2 board and other stuff on the way from HK - I understand that v1.5 firmware supports CPPM input which I'd really like to use - can anyone please point me to where I can find the info on using this, particularly how/where to connect it? Thanks!
GordonTarling is offline Find More Posts by GordonTarling
Old Dec 15, 2012, 05:40 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
The board as shipped supports cppm, but the labels are reversed in the editor. If you don't even know how to connect it I suggest starting with the manual.
brontide is offline Find More Posts by brontide
Old Dec 15, 2012, 06:41 AM
srepfler is offline
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
In PI Editor increase Yaw P to 100 or even 150.
srepfler is offline Find More Posts by srepfler
Old Dec 15, 2012, 07:03 AM
IIIBonesAirForce is offline
Find More Posts by IIIBonesAirForce
Grounded Pilot
IIIBonesAirForce's Avatar
USA, MN, Rochester
Joined Jul 2007
I have KK V 1.2 FW. Also have Turnegy 25 Amp ESCs I noticed that the response time for Roll and Pitch is very slow. Short of getting SimonK flashed ESCs. Does anyone know if changing stick scaling or the P and/or I gains would speed up motor response in this case? I searched this forum and did not see any discussion linking speed of right stick motor response to gains adjustment. Do you all think that it would be fair to conclude that a SimonK flashed ESCs is the answer? Thanks for any insights.
IIIBonesAirForce is offline Find More Posts by IIIBonesAirForce
Old Dec 15, 2012, 07:15 AM
Joined Mar 2001
Thanks for that - I thought I studied the latest manual and could find no sign of how to connect CPPM, hence my question - perhaps I was looking at an older version.
Old Dec 15, 2012, 07:16 AM
Grounded Pilot
USA, MN, Rochester
Joined Jul 2007
I just saw post number 8379 stating that flashing ESCs with SimonK solved the response problem and made craft more agile. Thanks Cadriel
Old Dec 15, 2012, 08:18 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
I just did a check (search this topic for all posts by kapteinkuk with CPPM in them).
CPPM was added in the 1.1 release
and the labels were fixed in 1.3.
regards,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Dec 15, 2012, 08:35 AM
Banjo5 is offline
Joined Jun 2012
CPPM & Feature Requests
Speaking of CPPM, I've been wondering for a while if more than 5 input channels are available if CPPM is enabled?
If so then I have a couple of feature requests/suggestions:
A switched "lost model" alarm would be possible. Be able to turn on the beeper with a channel switch. This would be better than the current feature where the beeper starts after a period of inactivity.
Having lost an mQx and had a few longer searches when flying in my hayfield I really like this feature. I have a separate beeper connected to an extra RX channel right now, but this would be simpler. Also, unless I can keep the RX sending PPM signals out of some channels as well as CPPM I couldn't use the external beeper if I went CPPM, which would be a tough choice.
Secondly, switch the output of unused motor outputs, which could then be used to drive LED's, etc, (or even a lost model beeper I guess ). This would be useful even if it was still a servo type output, or perhaps could be configured as a logic signal.
Anyway, all these are mute if additional channels aren't available. I suspect that both could be done with fairly modest code changes.
The first one would be a simple feature, and sufficiently straightforward.
I could see vetoing all, or parts of, the second one on complexity grounds as it pushes the boundaries of simple enough for mass consumption.
Comments?
cheers,
Andrew
Old Dec 15, 2012, 08:41 AM
brontide is offline
Joined Sep 2012
Andrew,
I believe it can, but the problem is lack of code space. Without some major rewrites there is not room for a lot of new features. KK already pulled the debug menu to squeeze in camstab.
Old Dec 15, 2012, 08:56 AM
Joined Mar 2001
regards,
Andrew
Thanks for that - very helpful! I'll do some more browsing and reading.
Old Dec 15, 2012, 10:49 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Still running v1.0 on my board :P
Flys great gyros only
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 15, 2012, 10:57 AM
Creepy1 is offline
Find More Posts by Creepy1
Mother warned you about me!
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
Stick scaling can definately do this for you. Try around 80.
Creepy1 is offline Find More Posts by Creepy1
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
The current lost model alarm implementation is great. Let's say the receiver gets smashed or the antenna gets torn off in a crash. What happens to your switch now? Perhaps a receiver signal could be used to actively inhibit the potentially annoying beeps, but it shouldn't be used to enable it.
Your perceived dilemma is addressed by a signal to inhibit alarm.
The CPPM receiver I'm using (after-market offering for the Hitec Aurora 9) is an eight channel unit which can be configured to send CPPM out on the port normally used for channel 1 and RSSI on the port normally used for channel 2; and spare receiver ports are available for other uses:
As the PPM signal is usually used to drive the primary flight controls,
servo connector channels 5, 6, 7, 8 will shift to become channels 6, 7, 8
and 9 respectively to allow additional auxiliary devices to be
connected.
Dragging extra features into the KK2 will potentially lead to complexity and compromises that we probably don't need.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Dec 15, 2012, 11:00 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Comments?
cheers,
Andrew
If you continually arm or disarm the KK2, it beeps. When you lose it, just continually disarm it to hear the beeper.
Steveis is offline Find More Posts by Steveis
