Temple, GA, USA
Joined Jun 2009
Edit: I see in the video that refresh is set to "high" and he seems to be trying to change it, but it stays on high. |
Philippines, NCR, Quezon City
Joined Apr 2012
Hi! I just flashed my KK2 to fw 1.5. Self leveling gets better than the fw1.2. I still have to adjust the trims because my multi is drifting slightly to the right. And yawing to the right as well. What will happen if I trim it using my radio? How does ACC trim works anway?
elk
Joined May 2001
But first change H. damp settings. |
Joined Sep 2012
question on arming kk2 v1.5 while on an uneven surface:
I have done my acc calibration on a very level floor and i went outside to fly. What i noticed is that when you arm and disarm your quad on a surface that is uneven, the pitch and roll angle on the home screen will read '0', as if it has been calibrated to the floor's angle of incline. does that mean my auto level performance will be affected since the quad thinks it is level while in actual fact it is already at an angle? without re calibrating the acc, i found a level spot and placed it there. the roll and pitch angle on the home screen showed it had about 4 degrees each. i then proceeded to arm and then disarm the quad. now the roll and pitch angles said '0' degs each. it's as if every time i arm the quad, it is calibrating it's level datum. can someone please explain what's going on? thanks! |
It's working fine. Fly it! Sudsy |
United Kingdom, England, Cnwll
Joined Jul 2011
The rate stays high if set to ESC. |
Joined Nov 2012
I first built a warthox style frame (flydduino.net) with 25 cm aluminum arms. It was fine, but then i tried to make it smaller with 20cm arms. That was fine too. But the big change happened when i decided to go back to wooden arms. I think people underestimate wood when it comes to absorbing vibrations. Having wooden arms absorbes vibrations from each motor indipendently. I noticed a big change and i love it. There are many advantages of using wood i can think of i am not going to list them now.
Here are some pictures, you can go right for a couple more https://www.icloud.com/photostream/i...3-57A8954618C2 Quote:
Joined Sep 2012
yes ok. will try once it stops raining. but why does the roll and pitch angle show zero when you arm it on a different level surface?
Not had any issues flying without it either, just add or remove throttle as required and use all controls together to make the craft do what you want. |
Defective KK2 Board
Hey Guys,
i received my second KK2 Board from Hobbyking. Before wiring everything up, i wanted to flash V1.4 to the Board. This worked fine. But after putting everything on my SK450 together, only M1 starts spinning! I tried the other ESCs/Motors at connector M1 and they work fine. I tried setting back to factory setting and reflash with every possible FW Version, but it changes nothing. In the End i tried flashing OpenAero, but after that the LCD lights up but stays blank. So I think the Board must be defective. I also flashed my first KK2 Board with V1.5 to check if there is any problem with my USBASP-Programmer. But my first KK2 still works fine. Does someone know about this failure or if it is fixable? Thanks in advance and best regards Sebastian |
Temp <=> height changes
I have done yesterday a test outside with an Eagle Tree logger , logging the throttle and the amp's . The logging of the throttle signal is done on the leads coming from the reciever. The temp. inside was 23° C and outside 2° C . What I can see on the graphics is that the throttle signal of the reciever goes up and down while trying to keep the throttle stick in the same position. In my opinion it is not directly the board that is suffering under the low temp. but the transmitter throttle signal moves up and down in the cold temp.'s.
The first flight was reasonable OK ( 5 minutes ) but the second and the third flight the quad is going up and down without changing the throttle stick. |
