Old Dec 09, 2012, 02:53 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Originally Posted by yarg View Post
My quadrotor yaws slightly to the right, but only when applying thrust. It's slight enough that it doesn't really effect things too badly, but enough so that I have to stop and correct the direction I'm facing as I'm practicing.
Any idea what's causing it? I admit, my props aren't balanced, but I'm not sure if that would be enough to cause this.
If your frame is at all flexible this will happen.
brontide is offline Find More Posts by brontide
Old Dec 09, 2012, 06:16 PM
Sudsy is online now
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
I am copying this from another thread I watch and just commented on.
I hope I can explain this.
On my quad if I remove the food container that I use for a cover I can turn my quad upside down and rest it on the prop spinners. Do this on a flat surface like a table. Rotate each prop and see if the blades remain parallel to the flat surface. Try to adjust as needed to assure that all props are directing their thrust in a pure downward direction. If one if the motors is tilted to the left or right it will induce yaw in the machine. I have two Turnigy Talon frames and the motors become misaligned even after just a hard landing. I must keep a close eye on this and have found this to be a problem with those frames.
Sudsy
Sudsy is online now Find More Posts by Sudsy
Old Dec 09, 2012, 06:20 PM
zenman is offline
Find More Posts by zenman
zenman's Avatar
Joined Jul 2012
unequal prop thrust
I have been having tha same problem off and on (yawing, pitching, rolling, or droping and arm) and was having a hard time figuring out the source of the problem. So I built a little test rig that shows me the thrust of a prop. Checking at full throttle I can see that thrust values can vary greatly even on brand new props, sometimes even up to 30% or more.
The props I have been buying are cheap so I guess you get what you pay for.
I have been using these because I tend to break alot learning acro.
But having unequal lift doing acro probabably contributes to my crashes.
Maybe some of you can suggest a good source for props that are not too expensive
In the meantime I have been experimenting making the prop thrust even by twisting the props a bit. Having good results with this so far.
zenman is offline Find More Posts by zenman
Old Dec 09, 2012, 06:31 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Originally Posted by srepfler View Post
KK2 on cold wind and sub zero temperature (-5 .. -7 C).
isus se
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Dec 09, 2012, 07:14 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
[QUOTE=zenman;23485546]I have been having tha same problem off and on (yawing, pitching, rolling, or droping and arm) and was having a hard time figuring out the source of the problem. So I built a little test rig that shows me the thrust of a prop. Checking at full throttle I can see that thrust values can vary greatly even on brand new props, sometimes even up to 30% or more.
/QUOTE]
You should also check to make sure each blade of a prop
tracks in the same path as the other blade. A lot of the props
I've bought are not true in their track. One blade will track
higher or lower that the other.
harrym is offline Find More Posts by harrym
Old Dec 09, 2012, 07:18 PM
zenman is offline
zenman's Avatar
Joined Jul 2012
[QUOTE=harrym;23485986]
/QUOTE]
mostly what I'm finding on these rctimer props is the shape,pitch is not consistant.
Old Dec 09, 2012, 07:26 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hello I'm wanting to talk to a kk2 guru on the phone please. I need to be able to get my auto lvl to work. If you know how to program this board please help me and pm me your number. Ill pay you for your help thanks.
flohio117 is offline Find More Posts by flohio117
Old Dec 09, 2012, 07:27 PM
Sudsy is online now
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
/QUOTE]
It's not very important to "track" a prop on a fixed pitch rotor system. That is critical in a CCP helo but not so much with a fixed pitch prop. If the prop lays pretty much flat on a table out of the box that should be fine. The little 5 " props on my micro quads are very easily bent and I just gently bend them back. Balance it as best you can. I prefer the scotch tape on the light blade method and keep the tape as far out the blade as possible.Less weight the further from center.
I once had the opportunity to "track" a Navy SH-3 using the flag and crayon method. We marked the blade tips with different color crayons and with the rotor turning 100% and the pilot holding slightly up collective I had to get the flag into position so each blade hit the flag as it passed by. I only did this once. That was enough for me.
Oh yea, we do it with optics now!
Sudsy
Old Dec 09, 2012, 09:20 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
[QUOTE=Sudsy;23486095]
Originally Posted by harrym View Post
.....It's not very important to "track" a prop on a fixed pitch rotor system.
Balance the blades.
Balance the hub.
Do a track check.
It all leads to less vibration and more efficiency on ANY flying machine.
You don't have to get technical on the track check.
Just put a ruler along the bottom of your prop balancer,
spin the prop and see where the tips track.
Old Dec 09, 2012, 10:29 PM
urbansniper is offline
Find More Posts by urbansniper
United States, TX, Houston
Joined Nov 2012
I broke two quad arms with the below settings, can you help me adjust?
The settings worked fine in my drive way...but when i went out to a field; i beleive all it took was a strong gust of wind to send my Quad into an increasingly violent oscillation. i could be flying fine for a minute and then all the sudden it starts with a slow rock/oscillation...and then rocks further and further out of control.
self level
P gain : 30
P limi : 50
Misc
Height dampening : 10
height Dampening limit : 20
P&I
Elevation/Aileron
P gain : 30
P Limit : 100
I Gain : 20
I Limit : 20
Rudder
P gain : 20
P limit : 20
I gain : 20
I limit : 10
KK2 firmware 1.5
DJI 450 frame
750 kv motors, 40A turnigy plush ESC's
urbansniper is offline Find More Posts by urbansniper
Old Dec 09, 2012, 11:06 PM
harrym is offline
HeliHarry
harrym's Avatar
Joined Dec 2006
Here's what I used, Wind Speed: N9/G17 mph. No oscillations on my 392 Quad.
Self Level Settings - P Gain: 75 P Limit: 20 ACC Trim Roll: 0 ACC Trim Pitch: 0
Misc. Settings - Min Throttle: 10 Height Dimen: 10 Height D. Limit: 30 Alarm 1/10 Volts: 100 Servo Filter:50
Axis: Roll (Aileron) 45 100 25 20
Axis: Pitch (Elevator) 45 100 25 20
Axis: Yaw (Rudder) 45 20 30 10
KK2.0 v1.5
Old Dec 10, 2012, 01:35 AM
srepfler is offline
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
Originally Posted by helizrnew2me View Post
cool pictures .....
Thanks, it is snapshot from gopro video,
I just putted new gopro firmware and on snow really good video (sharp and clear).
srepfler is offline Find More Posts by srepfler
Old Dec 10, 2012, 05:08 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
did you try flashing your new board?i`m afraid to try now ,dont wanna brick another board .especially now that its up and flying again .
Yes with no problems using Lazy Zero tool. I did try it on 1.2 ( as it came with it) but found it hard to tune out the shakes so flashed to 1.5 and it was the difference of chalk and cheese high p type shakes stopped self level works
I still have some more tweaking to do but the weather here in Essex UK has been very windy
Jeff
Upup is offline Find More Posts by Upup
Old Dec 10, 2012, 05:34 AM
brontide is offline
Joined Sep 2012
self level
P gain : 30
P limi : 50
Misc
P&I
Elevation/Aileron
P gain : 30
P Limit : 100
I Gain : 20
I Limit : 20
Rudder
P gain : 20
P limit : 20
I gain : 20
I limit : 10
KK2 firmware 1.5
DJI 450 frame
Doesn't sound like settings, what's your battery situation?
Old Dec 10, 2012, 06:45 AM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
Loss of Signal
Hi
I was getting ready to fly my quad and set the aux switch for self level. After setting
up I disconnected the battery and was surprised to see no backlight on the lcd.
On checking further I discovered there was no signal from the RX.
I have swopped the RX,checked ALL connections and diconecceted the aux from both board and rx..
It starts with a beep and red light flash then just reverts to safe mode with no backlight.
Any ideas please
geedee is offline Find More Posts by geedee
